what is UART1(ttyTHS0) default function,a debug uart? for system login?
thanks
Please check J501 usb port - #10 by Trumany
The debug uart is through the micro-B port on Xavier developer kit. Please connect it to a host PC through USB type-A to micro-B adapter and run minocom or picocom on the host. You shall see the log.
thanks DaneLLL,
so uart1 is not debug UART.
UART1 is a normal uart.
Hint: If the group of permissions from “ls -l” is “tty”, then it is a console; if the group is instead “dialout”, then it is not console.
