We need to use 2xUARTs to communicate with our devices.
Pin99/101 UART0/ttyTHS0 works fine.
Pin236/238 UART2/ttyTHS1 default function is debug console and we tried to disable the console function without ‘console-port’, but still failed.
Can you help to give the guide to change ttyTHS1 as a general UART port.
$dmesg | grep 'tty'
[ 1.457214] 3100000.serial: ttyTHS0 at MMIO 0x3100000 (irq = 47, base_baud = 0) is a TEGRA_UART
[ 1.458631] 3110000.serial: ttyTHS1 at MMIO 0x3110000 (irq = 48, base_baud = 0) is a TEGRA_UART
[ 1.459492] 3140000.serial: ttyTHS4 at MMIO 0x3140000 (irq = 49, base_baud = 0) is a TEGRA_UART
[ 1.460844] console [ttyTCU0] enabled
We modified dtsi file hardware\nvidia\platform\t19x\jakku\kernel-dts\common\tegra194-p3668-common.dtsi as follow:
serial@3100000 {
compatible = "nvidia,tegra186-hsuart";
status = "okay";
serial@3140000 {
status = "okay";
combined-uart {
/*console-port;*/
combined-uart;
status = "okay";
If we changed ‘enable_combined_uart’ and ‘spe_uart_instance’, the NX can’t boot up.
enable_combined_uart = 0;
spe_uart_instance = 0xff;
$Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-bct-misc-l4t.cfg
Thanks so much.
hello Ciya.Jiang,
could you please check similar discussion thread, Topic 145106 for reference,
thanks
Hi JerryChang,
I have checked and followed this topic, but this topic wasn’t solved his problem?
FYI,
here’re steps to disable debug console.
please refer to cfg file,
$OUT/Linux_for_Tegra/bootloader/t186ref/BCT/tegra194-mb1-soft-fuses-l4t.cfg
please have modification to update “Verbosity” property,
for example,
Verbosity = 0; # 0: Disabled: 1: Critical, 2: Error, 3: Warn, 4: Info, 5: Debug
you may flash the board to update board configure file,
for example,
$ sudo ./flash jetson-xavier mmcblk0p1
hello Ciya.Jiang,
there’re 3 UARTs available,
UART0 to M2
UART1 to 40PIN
UART2 to debug
may I know what’s your mean about changing the NX debug UART/ttyTHS1 to a general UART function.
thanks
Hi JerryChang,
We want to use UART2(debug) as a general uart such as UART1(40PIN) function and don’t need uart for debug information.
hello Ciya.Jiang,
please refer to documentation, please modify environment configuration to Disable Console over UART .
thanks
wwwaaa
March 6, 2021, 3:13am
12
hello, @Luna2020
Disable Console over UART is marked as solution here, but my test is failed, do you really success to use UART2(debug) as a general uart such as UART1(40PIN) ?
Hi suchb,
Sorry.
I tried saveral methods but no one works fine, so I abandoned it.
wwwaaa
March 7, 2021, 1:52am
14
@JerryChang Hi,Jerry
Could you please show the detailed steps to use ttyTCU0 and ttyTHS0 as a general uart such as UART1(40PIN) ?
by following developer guide or related topics,all my test is failed.
hello suchb,
let’s follow-up this in Topic 170116 for further supports.
thanks
