AGX xavier use spi2_clk & spi2_miso SFIO1 function of uartg_tx & uartg_rx. I do a lot work ,but not get throuth
  1. I use the Jetson_AGX_Xavier_Series_Pinmux_Configuration_Template_v1.6.xlsm general out the right function of spi2_clk & spi2_miso SFIO1 function to uartg_tx & uartg_rx. Then use pinmux-dts2cfg.py general out the cfg file .replace the right file in the bootloader/t186ref/BCT .
    The sudo cat /sys/kernel/debug/pinctrl/2430000.pinmux/pinconf-groups | grep -n -B12 -A5 “func=uartg” show like this:
8-9 (spi2_sck_pcc0):
139- pull=2
140- tristate=0
141- enable-input=0
142- open-drain=0
143- io-reset=1
144- rcv-sel=1
145- io-hv=1
146- schmitt=1
147- pull-down-strength=0
148- pull-up-strength=0
149- drive-type=0
150: func=uartg
151- pad-power=0
152- gpio-mode=1
153-10 (spi2_miso_pcc1):
154- pull=2
155- tristate=1
156- enable-input=1
157- open-drain=0
158- io-reset=1
159- rcv-sel=1
160- io-hv=1
161- schmitt=1
162- pull-down-strength=0
163- pull-up-strength=0
164- drive-type=0
165: func=uartg
166- pad-power=0
167- gpio-mode=1
In kernel dts ,i add the uartg in tegra194-p2888-0001-p2822-0000-common.dtsi like this:
&serial@c290000 {
compatible = “nvidia,tegra186-hsuart”;
status = “okay”;
pinctrl-names = “default”;
pinctrl-0 = <&uartg_tx_pcc0 &uartg_rx_pcc1>; // 引用具体的配置
clock-names = “serial”, “parent”;
clocks = <&bpmp_clks TEGRA194_CLK_UARTG>,
<&bpmp_clks TEGRA194_CLK_PLLP_OUT0>;
assigned-clocks = <&bpmp_clks TEGRA194_CLK_UARTG>;
assigned-clock-parents = <&bpmp_clks TEGRA194_CLK_PLLP_OUT0>;
&pinmux {
/* 配置 GPIO3_PCC.00 为 UARTG_TX /
uartg_tx_pcc0 {
nvidia,pins = “spi2_sck_pcc0”; /
引脚的硬件名称 /
nvidia,function = “uartg”; /
要切换的功能 */
nvidia,pull = <TEGRA_PIN_PULL_NONE>;
nvidia,tristate = <TEGRA_PIN_DISABLE>;
nvidia,enable-input = <TEGRA_PIN_ENABLE>;
/* 配置 GPIO3_PCC.01 为 UARTG_RX */
uartg_rx_pcc1 {
	nvidia,pins = "spi2_miso_pcc1"; /* 引脚的硬件名称 */
	nvidia,function = "uartg";      /* 要切换的功能 */
Add in tegra194-p2888-0001-p2822-0000.dts
&uartg {
status = “okay”;
pinctrl-0 = <&pinmux_uartg>; // 引用 Pinmux 配置
&pinmux {
pinmux_uartg: uartg {
spi2_sck_pcc0 {
nvidia,pull = <TEGRA_PIN_PULL_UP>;
nvidia,tristate = <TEGRA_PIN_ENABLE>;
spi2_miso_pcc1 {
nvidia,pins = “spi2_miso_pcc1”;
spi2_mosi_pcc2 {
nvidia,pins = “spi2_mosi_pcc2”;
nvidia,enable-input = <TEGRA_PIN_DISABLE>;
spi2_cs0_pcc3 {
nvidia,pins = “spi2_cs0_pcc3”;
Then after these work ,i can have the device /dev/ttyTHS6 ,but its not work in communicate .
does some one can help?
Hello @automationboy!
Based on the title and content of your topic, it looks like it may receive better visibility and feedback in a different category. We took the liberty of moving it for you.
If this was an incorrect assessment, please send me a direct message.
Disclaimer: this moderation suggestion and message were generated with AI assistance.
~0624
Hi automationboy,
Are you using the devkit or custom board for AGX Xavier?
Could you share the full dmesg and device tree fo further check?
