Is there any alternate node available for import USD prim data as it seems to be deprecated further USD Composer 2023.2.2?
Not sure. Let me find out and get back to you.
Please let me know. Thanks.
According to this page, it is recommended to use ReadPrim nodes instead. However, in my experience, the ReadPrim node has less functionality; for instance, it lacks the ‘import transform’ feature.
Hi @Richard3D ,
Could you please check my previous post? It seems that the ‘ReadPrim’ node is replacing the former ‘Import USD Prim Data’ node. However, as I mentioned, the new node has fewer functions, such as lacking the ‘import transform’ feature. As a result, the output bundle does not contain transform data, making it challenging to achieve object animation along curves using the following tutorials:
Could you please let me know if there is an alternative way to achieve object (like camera) animation along curves? Thank you.
Ok so you are correct. We have replaced “import usd prim data” omni graph node with “Read Prim” node. Sadly this appears to have broken the Motion Path system unexpectedly in 2023.3 onwards. It does work in 2023.2 and I am verifying this. We apologize and we will get it fixed. I will post more info as I find it.
