Hi, I found pin namings in PDF but since Jetson’s used a lot, I assume somebody already made a library for it.But I couldn’t find anything.Have you found one?
Hi ardublocktr,
Are you using the devkit or custom board for Xavier NX?
Sorry that I’m not aware of Altium library, could you elaborate on your use case?
Hi, thanks for your response.
I have a devkit with only nwme, power jack and ethernet port.Since I couldn’t use it, I don’t know the Jetpack version.Thats why I want to create a custom carier board for module.I’m planing to use it for object recognition on my homamade UAV for a project competition.
What’s the module on the dekvit?
Xavier NX module with internal eMMC? Or Xavier NX module with SD slot?
Why you can not use it?
We would suggest verifying on the devkit first, then you can refer to it and design the custom carrier board for your specific use case.
Ok, so I realized its not a Xavier, but a Jetson Nano. That doesn’t matter for DDR4 slot or carier board as far as I know.
Module has an eMMC, but on the carier board there is only etherner port, power jack and nvme ssd soldered, other components (including ics, resistors and capacitors). Thats why I can’t use it.
Please share the result of the following command on your board.
$ cat /etc/nv_tegra_release
$ cat /etc/nv_boot_control.conf
If your board can not boot, please just share the picture of your board with the board spec info.
Are you describing for a custom carrier board designed by you?
