I’m trying to install AMGX on my PC, but VS gave me some compiling error. (I’ve successfully installed amgx on my ubuntu 24.04)
The environment of PC is given as follow:
- OS: [Windows 11]
- Compiler version: [MSVC 19.40.3381]
- CMake version: [3.30]
- CUDA used for AMGX compilation: [CUDA 12.5.0]
- MPI version (if applicable): [MS-MPI v10.1.2]
- AMGX version or commit hash [f20a12db5cb6ad6a66e2ba6f9356456fed7af73f]
The cmake config info is:
1> CMake generation started for default configuration: 'x64-Debug'.
1> Command line: "C:\Windows\system32\cmd.exe" /c "%SYSTEMROOT%\System32\chcp.com 65001 >NUL && "C:\PROGRAM FILES\MICROSOFT VISUAL STUDIO\2022\COMMUNITY\COMMON7\IDE\COMMONEXTENSIONS\MICROSOFT\CMAKE\CMake\bin\cmake.exe" -G "Ninja" -DCMAKE_BUILD_TYPE:STRING="Debug" -DCMAKE_INSTALL_PREFIX:PATH="D:\Develop\AMGX\out\install\x64-Debug" -DCMAKE_C_COMPILER:FILEPATH="C:/Program Files/Microsoft Visual Studio/2022/Community/VC/Tools/MSVC/14.40.33807/bin/Hostx64/x64/cl.exe" -DCMAKE_CXX_COMPILER:FILEPATH="C:/Program Files/Microsoft Visual Studio/2022/Community/VC/Tools/MSVC/14.40.33807/bin/Hostx64/x64/cl.exe" -DCMAKE_MAKE_PROGRAM="C:\PROGRAM FILES\MICROSOFT VISUAL STUDIO\2022\COMMUNITY\COMMON7\IDE\COMMONEXTENSIONS\MICROSOFT\CMAKE\Ninja\ninja.exe" "D:\Develop\AMGX" 2>&1"
1> Working directory: D:\Develop\AMGX\out\build\x64-Debug
1> [CMake] -- The C compiler identification is MSVC 19.40.33811.0
1> [CMake] -- The CXX compiler identification is MSVC 19.40.33811.0
1> [CMake] -- The CUDA compiler identification is NVIDIA 12.5.40
1> [CMake] -- Detecting C compiler ABI info
1> [CMake] -- Detecting C compiler ABI info - done
1> [CMake] -- Check for working C compiler: C:/Program Files/Microsoft Visual Studio/2022/Community/VC/Tools/MSVC/14.40.33807/bin/Hostx64/x64/cl.exe - skipped
1> [CMake] -- Detecting C compile features
1> [CMake] -- Detecting C compile features - done
1> [CMake] -- Detecting CXX compiler ABI info
1> [CMake] -- Detecting CXX compiler ABI info - done
1> [CMake] -- Check for working CXX compiler: C:/Program Files/Microsoft Visual Studio/2022/Community/VC/Tools/MSVC/14.40.33807/bin/Hostx64/x64/cl.exe - skipped
1> [CMake] -- Detecting CXX compile features
1> [CMake] -- Detecting CXX compile features - done
1> [CMake] -- Detecting CUDA compiler ABI info
1> [CMake] -- Detecting CUDA compiler ABI info - done
1> [CMake] -- Check for working CUDA compiler: C:/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v12.5/bin/nvcc.exe - skipped
1> [CMake] -- Detecting CUDA compile features
1> [CMake] -- Detecting CUDA compile features - done
1> [CMake] -- Found MPI_C: C:/Program Files (x86)/Microsoft SDKs/MPI/Lib/x64/msmpi.lib (found version "2.0")
1> [CMake] -- Found MPI_CXX: C:/Program Files (x86)/Microsoft SDKs/MPI/Lib/x64/msmpi.lib (found version "2.0")
1> [CMake] -- Found MPI: TRUE (found version "2.0")
1> [CMake] -- Found OpenMP_C: -openmp (found version "2.0")
1> [CMake] -- Found OpenMP_CXX: -openmp (found version "2.0")
1> [CMake] -- Found OpenMP: TRUE (found version "2.0")
1> [CMake] -- Found CUDAToolkit: C:/Program Files/NVIDIA GPU Computing Toolkit/CUDA/v12.5/include (found suitable version "12.5.40", minimum required is "10.0")
1> [CMake] This is a MPI build:TRUE
1> [CMake] CMake Deprecation Warning at thrust/CMakeLists.txt:9 (cmake_policy):
1> [CMake] The OLD behavior for policy CMP0104 will be removed from a future version
1> [CMake] of CMake.
1> [CMake]
1> [CMake] The cmake-policies(7) manual explains that the OLD behaviors of all
1> [CMake] policies are deprecated and that a policy should be set to OLD only under
1> [CMake] specific short-term circumstances. Projects should be ported to the NEW
1> [CMake] behavior and not rely on setting a policy to OLD.
1> [CMake]
1> [CMake]
1> [CMake] -- Found libcudacxx: D:/Develop/AMGX/thrust/dependencies/libcudacxx/lib/cmake/libcudacxx/libcudacxx-config.cmake (found suitable version "1.8.1.0", minimum required is "1.8.0")
1> [CMake] -- Found Thrust: D:/Develop/AMGX/thrust/thrust/cmake/thrust-config.cmake (found version "2.1.0.0")
1> [CMake] -- Found CUB: D:/Develop/AMGX/thrust/dependencies/cub/cub/cmake/cub-config.cmake (found suitable version "2.1.0.0", minimum required is "2.1.0.0")
1> [CMake] -- Configuring done (28.9s)
1> [CMake] -- Generating done (0.1s)
1> [CMake] -- Build files have been written to: D:/Develop/AMGX/out/build/x64-Debug
1> Extracted CMake variables.
1> Extracted source files and headers.
1> Extracted code model.
1> Extracted toolchain configurations.
1> Extracted includes paths.
1> CMake generation finished.
Here are the compiling error:
error 1
Error calling a **host** function("std::_Iterator_base12::_Iterator_base12(const ::std::_Iterator_base12&)") from a **host** **device** function("std::_Iterator_base12::_Iterator_base12 [subobject]") is not allowed D:\Develop\AMGX\out\build\x64-Debug\AMGX D:\Develop\AMGX\thrust\thrust\detail\allocator\allocator_traits.inl 370
error2
Error calling a **host** function("std::_Iterator_base12::<del>_Iterator_base12()") from a **host** **device** function("std::_Iterator_base12::</del>_Iterator_base12 [subobject]") is not allowed D:\Develop\AMGX\out\build\x64-Debug\AMGX D:\Develop\AMGX\thrust\thrust\detail\allocator\allocator_traits.inl 370
Is there anyone could help me with it ?
