I use g+±10 to compile the latest version of Qt6 and get an error. The instruction set is not supported. How to solve it?
[8230/11513] Running ninja for QtWebEngineCore in /home/zhou/Downloads/Qt/qt-everywhere-src-6.7.0/build/qtwebengine/src/core/Release/aarch64
ninja: Entering directory `/home/zhou/Downloads/Qt/qt-everywhere-src-6.7.0/build/qtwebengine/src/core/Release/aarch64'
[84/30831] CXX obj/base/allocator/partition_allocator/allocator_base/stack_trace.o
FAILED: obj/base/allocator/partition_allocator/allocator_base/stack_trace.o
/usr/bin/c++ -MMD -MF obj/base/allocator/partition_allocator/allocator_base/stack_trace.o.d -DUSE_UDEV -DUSE_AURA=1 -DUSE_OZONE=1 -DOFFICIAL_BUILD -DTOOLKIT_QT -D__STDC_CONSTANT_MACROS -D__STDC_FORMAT_MACROS -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -DNO_UNWIND_TABLES -DNDEBUG -DNVALGRIND -DDYNAMIC_ANNOTATIONS_ENABLED=0 -DIS_PARTITION_ALLOC_IMPL -Igen -I../../../../../../qtwebengine/src/3rdparty/chromium -Wall -U_FORTIFY_SOURCE -D_FORTIFY_SOURCE=2 -Wno-unused-local-typedefs -Wno-maybe-uninitialized -Wno-deprecated-declarations -fno-delete-null-pointer-checks -Wno-comments -Wno-packed-not-aligned -Wno-dangling-else -Wno-missing-field-initializers -Wno-unused-parameter -Wno-psabi -fno-ident -fno-strict-aliasing --param=ssp-buffer-size=4 -fstack-protector -Wno-unknown-pragmas -Wno-address -Wno-parentheses -Wno-sign-compare -Wno-stringop-overflow -Wno-stringop-overread -Wno-psabi -Wno-multichar -Wno-format-zero-length -fno-unwind-tables -fno-asynchronous-unwind-tables -fPIC -pipe -pthread -mbranch-protection=standard -fno-omit-frame-pointer -g0 -fvisibility=hidden -O3 -fdata-sections -ffunction-sections -Wno-narrowing -Wno-class-memaccess -Wno-attributes -Wno-class-memaccess -Wno-subobject-linkage -Wno-invalid-offsetof -Wno-return-type -Wno-deprecated-copy -Wno-deprecated-copy -Wno-expansion-to-defined -std=gnu++20 -fno-exceptions -fno-rtti -fvisibility-inlines-hidden -c ../../../../../../qtwebengine/src/3rdparty/chromium/base/allocator/partition_allocator/partition_alloc_base/debug/stack_trace.cc -o obj/base/allocator/partition_allocator/allocator_base/stack_trace.o
{standard input}: Assembler messages:
{standard input}:41: 错误: selected processor does not support `xpaclri'
{standard input}:59: 错误: selected processor does not support `xpaclri'
{standard input}:142: 错误: selected processor does not support `xpaclri'
{standard input}:156: 错误: selected processor does not support `xpaclri'
{standard input}:201: 错误: selected processor does not support `xpaclri'
{standard input}:247: 错误: selected processor does not support `xpaclri'
{standard input}:258: 错误: selected processor does not support `xpaclri'
{standard input}:287: 错误: selected processor does not support `xpaclri'
{standard input}:332: 错误: selected processor does not support `xpaclri'
{standard input}:352: 错误: selected processor does not support `xpaclri'
{standard input}:420: 错误: selected processor does not support `xpaclri'
{standard input}:433: 错误: selected processor does not support `xpaclri'
[97/30831] CXX obj/base/allocator/partition_allocator/allocator_core/partition_root.o
ninja: build stopped: subcommand failed.
[8322/11513] Building CXX object qtgrpc/src/protobuf/CMakeFiles/Protobuf.dir/qprotobufserializer.cpp.o
FAILED: qtwebengine/src/core/Release/aarch64/QtWebEngineCore.stamp qtwebengine/src/core/Release/aarch64/obj/tools/v8_context_snapshot/v8_context_snapshot.stamp qtwebengine/src/core/Release/aarch64/QtWebEngineCore /home/zhou/Downloads/Qt/qt-everywhere-src-6.7.0/build/qtwebengine/src/core/Release/aarch64/QtWebEngineCore.stamp /home/zhou/Downloads/Qt/qt-everywhere-src-6.7.0/build/qtwebengine/src/core/Release/aarch64/obj/tools/v8_context_snapshot/v8_context_snapshot.stamp /home/zhou/Downloads/Qt/qt-everywhere-src-6.7.0/build/qtwebengine/src/core/Release/aarch64/QtWebEngineCore
cd /home/zhou/Downloads/Qt/qt-everywhere-src-6.7.0/build/qtwebengine/src/core && /usr/bin/ninja -C /home/zhou/Downloads/Qt/qt-everywhere-src-6.7.0/build/qtwebengine/src/core/Release/aarch64 QtWebEngineCore
[8336/11513] Building CXX object qttools/src/designer/src/lib/CMakeFiles/Designer.dir/cmake_pch.hxx.gch
A user has shared a script:
QT6 on Jetson Orin Nano from Source - #3 by DaneLLL
Please give it a try.
I tried this method, but it still doesn’t work
[14609/20822] Performing install step for 'gn'
[0/2] Generating gn
ninja: Entering directory `/home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/build/qtwebengine/src/gn/Release'
ninja: no work to do.
[1/2] Install the project...
-- Install configuration: "Release"
-- Installing: /home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/build/qtwebengine/install/bin/gn
[14693/20822] Run gn for target WebEngineCore in /home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/build/qtwebengine/src/core/Release/aarch64
-- Found Gn: /home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/build/qtwebengine/install/bin/gn (found suitable exact version "6.6.1.qtwebengine.qt.io")
-- Running gn in /home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/build/qtwebengine/src/core/Release/aarch64
-- GN command:
/home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/build/qtwebengine/install/bin/gn gen /home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/build/qtwebengine/src/core/Release/aarch64 --script-executable=/usr/bin/python3 --root=/home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/qtwebengine/src/3rdparty/chromium
-- GN arg file:
/home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/build/qtwebengine/src/core/Release/aarch64/args.gn
-- GN args:
angle_enable_swiftshader=false
blink_symbol_level=0
build_dawn_tests=false
build_with_tflite_lib=false
chrome_pgo_phase=0
chrome_root_store_supported=false
custom_toolchain="/home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/build/qtwebengine/src/core/target_toolchain:target"
dawn_use_swiftshader=false
dcheck_always_on=false
devtools_fast_bundle=false
devtools_skip_typecheck=false
enable_background_contents=false
enable_background_mode=false
enable_basic_printing=true
enable_extensions=true
enable_hangout_services_extension=true
enable_ipc_fuzzer=false
enable_ipc_logging=false
enable_library_cdms=true
enable_location_source=false
enable_media_remoting=false
enable_message_center=false
enable_nacl=false
enable_oop_printing=false
enable_pdf=true
enable_plugins=true
enable_precompiled_headers=false
enable_print_preview=true
enable_printing=true
enable_remoting=false
enable_reporting=false
enable_resource_allowlist_generation=false
enable_screen_ai_service=false
enable_screen_capture=true
enable_session_service=false
enable_spellcheck=true
enable_supervised_users=false
enable_swiftshader_vulkan=false
enable_vr=false
enable_vulkan=true
enable_web_speech=false
enable_webrtc=true
enable_widevine=true
fatal_linker_warnings=false
forbid_non_component_debug_builds=false
has_native_accessibility=false
host_cpu="arm64"
host_pkg_config="/usr/bin/pkg-config"
host_toolchain="/home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/build/qtwebengine/src/core/host_toolchain:host"
icu_use_data_file=true
init_stack_vars=false
is_cfi=false
is_clang=false
is_component_build=false
is_debug=false
is_gcc=true
is_mingw=false
is_msvc=false
is_official_build=true
is_qtwebengine=true
is_shared=true
is_unsafe_developer_build=false
jumbo_build_excluded=["browser"]
jumbo_file_merge_limit=8
optimize_webui=false
ozone_auto_platforms=false
ozone_extra_path="/home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/qtwebengine/src/core/ozone/ozone_extra.gni"
ozone_platform="qt"
ozone_platform_external=true
ozone_platform_headless=false
ozone_platform_x11=true
pdf_use_skia=true
pdfium_use_system_libpng=true
pdfium_use_system_libtiff=false
pdfium_use_system_zlib=true
proprietary_codecs=false
qtwebengine_target="/home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/build/qtwebengine/src/core/Release/aarch64:QtWebEngineCore"
rtc_use_pipewire=false
rtc_use_x11=true
safe_browsing_mode=0
skia_use_dawn=false
strip_absolute_paths_from_debug_symbols=false
symbol_level=0
toolkit_views=false
treat_warnings_as_errors=false
trial_comparison_cert_verifier_supported=false
use_allocator_shim=false
use_alsa=true
use_bluez=false
use_browser_spellchecker=false
use_bundled_fontconfig=false
use_cups=false
use_cups=true
use_custom_libcxx=false
use_dawn=false
use_embedded_config=false
use_gio=false
use_glib=false
use_gnome_keyring=false
use_gold=false
use_gtk=false
use_jumbo_build=true
use_kerberos=false
use_libpci=true
use_lld=false
use_ozone=true
use_partition_alloc=true
use_partition_alloc_as_malloc=false
use_pulseaudio=true
use_qt=false
use_static_angle=true
use_sysroot=false
use_system_ffmpeg=false
use_system_freetype=true
use_system_harfbuzz=false
use_system_icu=false
use_system_lcms2=true
use_system_libevent=true
use_system_libjpeg=true
use_system_libopenjpeg2=true
use_system_libvpx=false
use_system_libwebp=true
use_system_libxml=false
use_system_libxslt=false
use_system_minizip=true
use_system_opus=true
use_system_re2=true
use_system_snappy=true
use_thin_lto=false
use_udev=true
use_v8_context_snapshot=true
use_vaapi=false
use_vaapi_x11=false
use_xkbcommon=true
v8_symbol_level=0
v8_use_external_startup_data=true
-- GN Done. Made 17525 targets from 2859 files in 18166ms
[14693/20822] Running ninja for QtWebEngineCore in /home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/build/qtwebengine/src/core/Release/aarch64
ninja: Entering directory `/home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/build/qtwebengine/src/core/Release/aarch64'
[2306/30837] CXX obj/skia/skia_core_and_effects/SkTaskGroup.o
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/skia/src/core/SkTaskGroup.cpp: In lambda function:
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/skia/src/core/SkTaskGroup.cpp:25:23: warning: implicit capture of ‘this’ via ‘[=]’ is deprecated in C++20 [-Wdeprecated]
25 | fExecutor.add([=] {
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/skia/src/core/SkTaskGroup.cpp:25:23: note: add explicit ‘this’ or ‘*this’ capture
At global scope:
cc1plus: note: unrecognized command-line option ‘-Wno-stringop-overread’ may have been intended to silence earlier diagnostics
[2496/30837] CXX obj/skia/skia_core_and_effects/SkPath.o
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/skia/src/core/SkPath.cpp: In lambda function:
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/skia/src/core/SkPath.cpp:2268:33: warning: implicit capture of ‘this’ via ‘[=]’ is deprecated in C++20 [-Wdeprecated]
2268 | auto setComputedConvexity = [=](SkPathConvexity convexity){
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/skia/src/core/SkPath.cpp:2268:33: note: add explicit ‘this’ or ‘*this’ capture
At global scope:
[3058/30837] CXX obj/third_party/angle/src/libANGLE/renderer/vulkan/angle_vulkan_backend/vk_internal_shaders_autogen.o
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/angle/src/libANGLE/renderer/vulkan/vk_internal_shaders_autogen.cpp:13: warning: "USE_SYSTEM_ZLIB" redefined
13 | #define USE_SYSTEM_ZLIB
<command-line>: note: this is the location of the previous definition
[4037/30837] ASM obj/third_party/dav1d/dav1d_arm/filmgrain.o
FAILED: obj/third_party/dav1d/dav1d_arm/filmgrain.o
/usr/bin/cc -MMD -MF obj/third_party/dav1d/dav1d_arm/filmgrain.o.d -DUSE_UDEV -DUSE_AURA=1 -DUSE_OZONE=1 -DOFFICIAL_BUILD -DTOOLKIT_QT -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -DNO_UNWIND_TABLES -DNDEBUG -DNVALGRIND -DDYNAMIC_ANNOTATIONS_ENABLED=0 -DCONFIG_LOG=0 -DHAVE_PTHREAD_GETAFFINITY_NP=1 -DDAV1D_API= -Igen -I../../../../../../qtwebengine/src/3rdparty/chromium -I../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d -I../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/include -I../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/include/dav1d -I../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/config/linux/arm64 -I../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/version -fPIC -fno-ident -fno-strict-aliasing --param=ssp-buffer-size=4 -fstack-protector -Wno-unknown-pragmas -Wno-address -Wno-parentheses -Wno-sign-compare -Wno-stringop-overflow -Wno-stringop-overread -Wno-psabi -Wno-multichar -Wno-format-zero-length -fno-unwind-tables -fno-asynchronous-unwind-tables -fPIC -pipe -pthread -std=gnu11 -mbranch-protection=standard -g0 -c ../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S -o obj/third_party/dav1d/dav1d_arm/filmgrain.o
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S: Assembler messages:
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:414: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:414: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:415: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:415: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:416: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:416: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:417: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:418: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:419: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:420: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:421: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:422: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:423: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:424: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:425: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:425: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:558: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:558: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:559: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:559: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:560: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:560: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:561: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:562: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:563: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:564: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:565: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:566: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:567: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:568: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:569: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:569: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:772: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:772: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:773: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:773: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:774: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:774: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:775: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:776: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:777: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:778: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:779: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:780: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:781: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:782: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:783: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:783: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:786: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:794: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:799: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:807: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:812: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:816: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:821: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:825: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:1087: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:1087: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:1088: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:1088: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:1284: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:1284: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:1285: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:1285: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:1368: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:1554: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:1555: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:1556: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:1557: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:1679: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:1680: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:1681: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:1849: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain.S:1998: 错误: selected processor does not support `autiasp'
[4038/30837] ASM obj/third_party/dav1d/dav1d_arm/filmgrain16.o
FAILED: obj/third_party/dav1d/dav1d_arm/filmgrain16.o
/usr/bin/cc -MMD -MF obj/third_party/dav1d/dav1d_arm/filmgrain16.o.d -DUSE_UDEV -DUSE_AURA=1 -DUSE_OZONE=1 -DOFFICIAL_BUILD -DTOOLKIT_QT -D_FILE_OFFSET_BITS=64 -D_LARGEFILE_SOURCE -D_LARGEFILE64_SOURCE -DNO_UNWIND_TABLES -DNDEBUG -DNVALGRIND -DDYNAMIC_ANNOTATIONS_ENABLED=0 -DCONFIG_LOG=0 -DHAVE_PTHREAD_GETAFFINITY_NP=1 -DDAV1D_API= -Igen -I../../../../../../qtwebengine/src/3rdparty/chromium -I../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d -I../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/include -I../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/include/dav1d -I../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/config/linux/arm64 -I../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/version -fPIC -fno-ident -fno-strict-aliasing --param=ssp-buffer-size=4 -fstack-protector -Wno-unknown-pragmas -Wno-address -Wno-parentheses -Wno-sign-compare -Wno-stringop-overflow -Wno-stringop-overread -Wno-psabi -Wno-multichar -Wno-format-zero-length -fno-unwind-tables -fno-asynchronous-unwind-tables -fPIC -pipe -pthread -std=gnu11 -mbranch-protection=standard -g0 -c ../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S -o obj/third_party/dav1d/dav1d_arm/filmgrain16.o
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S: Assembler messages:
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:341: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:341: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:342: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:342: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:343: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:343: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:344: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:345: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:346: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:347: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:348: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:349: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:350: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:351: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:352: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:352: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:436: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:436: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:437: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:437: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:438: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:438: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:439: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:440: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:441: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:442: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:443: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:444: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:445: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:446: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:447: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:447: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:592: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:592: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:593: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:593: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:594: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:594: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:595: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:596: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:597: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:598: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:599: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:600: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:601: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:602: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:603: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:603: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:606: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:621: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:626: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:642: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:647: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:666: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:671: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:684: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:694: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:708: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:957: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:957: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:958: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:958: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:1167: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:1167: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:1168: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:1168: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:1252: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:1479: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:1480: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:1481: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:1482: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:1622: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:1623: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:1624: 错误: selected processor does not support `paciasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:1819: 错误: selected processor does not support `autiasp'
../../../../../../qtwebengine/src/3rdparty/chromium/third_party/dav1d/libdav1d/src/arm/64/filmgrain16.S:1985: 错误: selected processor does not support `autiasp'
[4050/30837] CC obj/third_party/dav1d/dav1d/cdf.o
[14708/20822] Run gn for target Pdf in /home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/build/qtwebengine/src/pdf/Release/aarch64
-- Running gn in /home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/build/qtwebengine/src/pdf/Release/aarch64
-- GN command:
/home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/build/qtwebengine/install/bin/gn gen /home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/build/qtwebengine/src/pdf/Release/aarch64 --script-executable=/usr/bin/python3 --root=/home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/qtwebengine/src/3rdparty/chromium
-- GN arg file:
/home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/build/qtwebengine/src/pdf/Release/aarch64/args.gn
-- GN args:
chrome_pgo_phase=0
custom_toolchain="/home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/build/qtwebengine/src/pdf/target_toolchain:target"
enable_vr=false
host_cpu="arm64"
host_toolchain="/home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/build/qtwebengine/src/pdf/host_toolchain:host"
is_cfi=false
is_clang=false
is_debug=false
is_gcc=true
is_mingw=false
is_msvc=false
is_qtwebengine=true
is_shared=true
pdf_enable_v8=false
pdf_enable_xfa=false
pdf_enable_xfa_bmp=false
pdf_enable_xfa_gif=false
pdf_enable_xfa_png=false
pdf_enable_xfa_tiff=false
pdfium_use_qt_libpng=false
qt_freetype_config="/home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/build/qtwebengine/src/pdf/Release/aarch64:qt_freetype_config"
qt_harfbuzz_config="/home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/build/qtwebengine/src/pdf/Release/aarch64:qt_harfbuzz_config"
qt_libjpeg_config="/home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/build/qtwebengine/src/pdf/Release/aarch64:qt_libjpeg_config"
qt_libpng_config="/home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/build/qtwebengine/src/pdf/Release/aarch64:qt_libpng_config"
qtwebengine_target="/home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/build/qtwebengine/src/pdf/Release/aarch64:QtPdf"
symbol_level=0
use_dawn=false
use_gold=false
use_lld=false
use_ml_inliner=false
use_qt_freetype=false
use_qt_harfbuzz=false
use_qt_libjpeg=false
use_sysroot=false
use_thin_lto=false
v8_symbol_level=0
-- GN Done. Made 17609 targets from 2870 files in 16921ms
[15305/20822] Automatic QML type registration for target Graphs
Warning: Refusing to generate non-lowercase name "TouchInputHandler3D" for unknown foreign type
[15433/20822] Building CXX object qtgraphs/src/graphs/CMakeFiles/Graphs.dir/data/qbardataproxy.cpp.o
/home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/qtgraphs/src/graphs/data/qbardataproxy.cpp: In member function ‘QPair<float, float> QBarDataProxyPrivate::limitValues(int, int, int, int) const’:
/home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/qtgraphs/src/graphs/data/qbardataproxy.cpp:768:87: note: parameter passing for argument of type ‘std::pair<float, float>’ when C++17 is enabled changed to match C++14 in GCC 10.1
768 | int startColumn, int endColumn) const
[15459/20822] Building CXX object qtgraphs/src/graphs/CMakeFiles/Graphs.dir/engine/bars3dcontroller.cpp.o
/home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/qtgraphs/src/graphs/engine/bars3dcontroller.cpp: In member function ‘virtual void Bars3DController::adjustAxisRanges()’:
/home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/qtgraphs/src/graphs/engine/bars3dcontroller.cpp:572:78: note: parameter passing for argument of type ‘std::pair<float, float>’ when C++17 is enabled changed to match C++14 in GCC 10.1
572 | categoryAxisX->max());
[15513/20822] Building CXX object qtgrpc/src/grpc/CMakeFiles/Grpc.dir/qgrpchttp2channel.cpp.o
FAILED: qtwebengine/src/core/Release/aarch64/QtWebEngineCore.stamp qtwebengine/src/core/Release/aarch64/obj/tools/v8_context_snapshot/v8_context_snapshot.stamp qtwebengine/src/core/Release/aarch64/QtWebEngineCore /home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/build/qtwebengine/src/core/Release/aarch64/QtWebEngineCore.stamp /home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/build/qtwebengine/src/core/Release/aarch64/obj/tools/v8_context_snapshot/v8_context_snapshot.stamp /home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/build/qtwebengine/src/core/Release/aarch64/QtWebEngineCore
cd /home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/build/qtwebengine/src/core && /usr/bin/ninja -C /home/zhou/Downloads/Qt/qt-everywhere-src-6.6.1/build/qtwebengine/src/core/Release/aarch64 QtWebEngineCore
[15527/20822] Building CXX object qtgrpc/tests/auto/protobufgen/CMakeFiles/tst_qtprotobufgen.dir/qt_protobuf_generated/folder/qtprotobufnamespace/tests/mapmessages.qpb.cpp.o
hello I have the same problem. How did you solve it
