Android on nano
I know it only exists on certain Jetson boards, can we get it here? Is there an unofficial port I missed? Or maybe debian? Android is better by a long shot for some things.
Might be able to get this to work with some effort
Thanks. I will mess with it.
https://forum.xda-developers.com/nintendo-switch/nintendo-switch-news-guides-discussion--development/rom-switchroot-lineageos-15-1-t3951389
:p
Anyone successful with andriod on Nano?
maybe use the tk1 android and port it?
The TK1 is 32-bit, Nano is 64-bit. It would be at minimum difficult to port since all of the libraries and tools would have to run in compatibility mode.
one can try porting from nintendo-switch,but anyone tried it?
good catch, even tho it may work losing 64bit is a big hit
This exists, but I am not sure if this will work on the developer kit.
I think it is designed for this
I just found it at around the same time I found this thread. I will try to build it one of these days/weeks
Any success with the Dev kit?
I haven’t even tried it yet. I went our of town for a couple of weeks right after posting that. Since then, I have been working on an automation project (sort of) on the nano. I will probably wrap it in a few days. I will check it out afterwards.
So I have tried the process suggested by the antmicro github README. The exact link is:
https://github.com/antmicro/kvm-aosp-jetson-nano
Its not working. You can see the issue listed in the issues. While the process makes an example for the antmicro baseboard + jetson nano module, it should have also worked for vanilla jetson nano Dev board since the android in running a VM with QEMU+KVM.
Probably best option is to ask on Switchroot and Linux4Switch Discords. Guys there are really helpfull.
actually it works.
