Ceramic_Tiles_Glazed_Paseo
display name is “Glazed Ceramic Tiles” but should be “Glazed Paseo Tiles - Dark Blue”
Mortar_Moist
extraneous space at end of display name
Glass_Optical
Glass_Optical_PSK
display name for both is “Glass Clear - Phosphate Dense Crown”
Ground_Aggregate_Exposed - all
Ground is misspelled Gound in both display name and export name
Blued_Steel_Cold_Worn
Blued_Steel_Cold_Matte_Smudged
display name for both is “Blued Steel - Cold Blued Matte Smudged”
Brass_Knurling_Gold
Brass_Knurling_Gold_Rough_Dirty
display name for both is “Brass Knurling Gold - Rough Dirty”
Brass_Knurling_Red
Brass_Knurling_Red_Rough_Dirty
display name for both is “Brass Knurling Red - Rough Dirty”
Brass_Scratched_Red_Polished_Subtle_Dark_Scratches
Brass_Scratched_Red_Subtle_Worn_Scratches
Brass_Scratched_Red_Medium_Glossy_Scratches
Brass_Scratched_Red_Medium_Glossy_Deep_Scratches
Brass_Scratched_Red_Heavy_Worn_Scratches
display name states Gold instead of Red
Bronze_New
Bronze_New_Stained
display name is “Bronze - …”, but should be be “Bronze Gold - …”
OR
Bronze_Shiny_Handled
Bronze_Worn
Bronze_Rough_Worn
display name is “Bronze Gold - …”, but should be be “Bronze - …”
Nickel_Foil
Nickel_Foil_Smudged_Foil
Nickel_Foil_Shiny_Wrinkled
Nickel_Foil_Matte_Wrinkled
Nickel_Foil_Heavy_Glossy_Wrinkles
Nickel_Foil_Heavy_Matte_Wrinkled
display names state Chromium instead of Nickel
*_Scratched_Light_Bumpy metals
display names use all lowercase “bumpy” inconsistent with proper case used everywhere else
PCB_Solder_Mask_White
PCB_Solder_Mask_White_Fast
display names use all lowercase “white” inconsistent with proper case used everywhere else
Polycarbonate_Opaque
Polypropylene_Opaque
display name uses “Diffuse”, all other variants use “Opaque”
Devil_Black_Clean_Pollished
Rosa_Beta_Clean_Pollished
Volga_Blue_Deep_Pollished
Polished is misspelled Pollished in both display name and export name
Terrazzo_Dry_Matt
Matte is misspelled Matt in both display name and export name
Not an annotation error…
Ground/Asphalt_Fine file extension is xmdl instead of mdl
