Carpet_Woven
display_name is “Carpet Woven - White”, all others in file are “Woven Carpet - XXXX”
key_words has “brown” instead of “white”
Stainless_Steel_Punched_Small_Circular
display_name is “Stainless Steel Punched - Small Circular Punch”, all others in file are “Stainless Steel - XXXX Punch”
Brass_Foil_Gold_Flat_Smudged
display_name is “Brass Foil Gold - Heavy Matte Wrinkles” but should be “Brass Foil Gold - Flat Smudged”
Brass_Foil_Red_Flat_Smudged
display_name is “Brass Foil Red - Heavy Matte Wrinkles” but should be “Brass Foil Red - Flat Smudged”
Iron_Sheet_Punched_Small_Circular
display_name is “Iron Sheet - Circular Punch” but should be “Iron Sheet - Small Circular Punch”
Platinum_Sheet_Punched_Small_Circular
display_name is “Platinum Sheet - Circular Punch” but should be “Platinum Sheet - Small Circular Punch”
Silver_Sheet_Punched_Hexagonal_Small
display_name is “Silver Sheet - Hexagonal Punch” but should be “Silver Sheet - Small Hexagonal Punch”
Volga_Blue_Imperfections
display_name is “Volga Blue Bright Blue” but should be “Volga Blue - Imperfections”
The following are not annotation errors, but contain duplicate materials. If they were left for backwards compatibility, then ignore…
Plastic/PET_Clear.mdl and Plastic/Polyethylene_Clear.mdl are near duplicates. Was PET_Clear supposed to have been removed?
Metal/Stainless_Steel.mdl and Metal/Stainless_Steel_Punched.mdl both have the same punched materials. Were punched materials supposed to have been removed from the first file?
