Hi There,
I am trying it integrate omni.kit.window.splash-1.0.4 into our application.
This is the process i have followed.
1. This opens splash screen.
[dependencies]
“omni.kit.window.splash” = {}
[settings.exts.“omni.kit.window.splash”]
imagePath = “${app}/data/startup.png”
2. This stops splash screen, added in start up extension.
async def run_hide_splash(self):
# Acquire the splash screen interface
splash_interface = omni.splash.acquire_splash_screen_interface()
for _ in range(5): # wait 5 frames
await omni.kit.app.get_app().next_update_async()
splash_interface.close_all()
run_coroutine(self.run_hide_splash())
It looks working, but the problem is its blocking main thread, so application hangs few seconds, it blocking gRpc api calls from c# that are need on starting of application.
I cannot use as below after api calls completed as its too late to show splash.
async def show_splash():
# Create a splash image
splash = splash_interface.create("${resources}/splash/splash.png", 1.0)
So any solution for this?
Any asynchronous way of using omni.kit.window.splash available?
