I’m using a synchronized stereo pair and ran the Argus sample syncSensor but the performance is low. The cameras are capable of 60fps at 752x480.
I modified the example and timed the calls to ScopedCudaEGLStreamFrameAcquire. I found that for one camera it takes about 60ms to return from cuEGLStreamConsumerAcquireFrame while for the other one it takes only 1ms. Can you explain why this happen?
*** Loop ***: 66.28 ms
ScopedCudaEGLStreamFrameAcquire: 59.35 ms
ScopedCudaEGLStreamFrameAcquire: 1.09 ms
*** Loop ***: 65.08 ms
ScopedCudaEGLStreamFrameAcquire: 62.92 ms
ScopedCudaEGLStreamFrameAcquire: 1.21 ms
*** Loop ***: 69.17 ms
ScopedCudaEGLStreamFrameAcquire: 58.50 ms
ScopedCudaEGLStreamFrameAcquire: 1.36 ms
*** Loop ***: 66.15 ms
ScopedCudaEGLStreamFrameAcquire: 60.45 ms
ScopedCudaEGLStreamFrameAcquire: 0.15 ms
I added the timer to the Multisensor sample on both the PreviewConsumer and JPEGConsumer threads. I get the following results:
JPEGConsumerThread: 120.47 ms
PreviewConsumerThread: 1.90 ms
JPEGConsumerThread: 150.67 ms
PreviewConsumerThread: 0.76 ms
JPEGConsumerThread: 115.27 ms
PreviewConsumerThread: 0.46 ms
This happens even if I commented out JPEG->writeJPEG to discard disk i/o time.
My ScoptedTimer is like this in case you want to try on your end:
@nzkspdr
So what your concern is why the ScopedCudaEGLStreamFrameAcquire need more time than others?
That because the frame send to GPU do post processing. I believe the post processing is the most time consumer.
