I have set up an installation of Openstack Juno on 8 nodes: one cloud controller and 7 Nova compute nodes. The nodes are all equipped with Mellanox ConnectX-3 Infiniband HCA. Openstack networking (Neutron) is configured to work over the Infiniband interface using the eth_ipoib driver for ethernet para-virtualization. The ethernet interface created by eth_ipoib is used by Openstack networking services over 2 UFM (version 4.8.0) partitions:
- one pkey is used for the private network between cloud nodes. It is defined as a local network and it is only connected to the Logical Server Group of the cloud nodes
- the other pkey is used for the Openstack/Neutron external network. It is defined as a local network and it is connected to the Logical Server Group of the cloud nodes and to 2 Infiniband gateways SX6036G (Mellanox OS 3.3.5006) configured in load balancing Active-Active mode (load balancing algorithm: ib-base-ip)
Neutron is configured with the new Distributed Virtual Router (DVR) feature of Juno (Neutron/DVR - OpenStack Neutron/DVR - OpenStack ). With DVR enabled, NAT services are distributed across all the nodes (controller and compute). One node (our cloud controller) provides only SNAT to VMs and all the other compute nodes provides DNAT to VMs.
Networking over the private network it’s working fine. Instead, on the external network problems arise when assigning floating IPs to the VMs. DVR manages floating IPs by creating a FloatingIP router namespace, the Floating IP agent gateway (FIP), on each node that runs a VM to which is assigned a floating IP. Each floating IP of a VM is then assigned to the DVR namespace of the tenant network.
I guess that floating IPs are not always reachable from the internet because, sometimes, the gateways map IP addresses with the wrong IB-MAC addresses in the ARP table.
For example, now the ARP tables of the external network (proxy-arp 7) of the 2 gateways contains
root@master# xdsh gw -l admin --devicetype IBSwitch::Mellanox “show ip arp interface proxy-arp 7”
sx60g01: Mellanox MLNX-OS Switch Management
sx60g01:
sx60g01: Total number of entries: 16
sx60g01: Address Type Hardware Address Interface
sx60g01: ------------------------------------------------------------------------
sx60g01: XXX.XXX.XX.188 Dynamic ETH 00:24:F7:14:7A:C1 proxy-arp 7
sx60g01: XXX.XXX.XX.189 Dynamic ETH 00:24:F7:14:B4:C1 proxy-arp 7
sx60g01: XXX.XXX.XX.190 Dynamic ETH 00:00:0C:07:AC:83 proxy-arp 7
sx60g01: XXX.XXX.XX.130 Dynamic IB 50:05:07:00:5B:01:7E:11 proxy-arp 7
sx60g01: XXX.XXX.XX.132 Dynamic IB 50:05:07:00:5B:01:7E:11 proxy-arp 7
sx60g01: XXX.XXX.XX.134 Dynamic IB 50:05:07:00:5B:01:80:0D proxy-arp 7
sx60g01: XXX.XXX.XX.136 Dynamic IB 50:05:07:00:5B:01:80:0D proxy-arp 7
sx60g01: XXX.XXX.XX.138 Dynamic IB 50:05:07:00:5B:01:7F:E5 proxy-arp 7
sx60g01: XXX.XXX.XX.142 Dynamic IB 50:05:07:00:5B:01:78:19 proxy-arp 7
sx60g01: XXX.XXX.XX.144 Dynamic IB 50:05:07:00:5B:01:7F:D5 proxy-arp 7
sx60g01: XXX.XXX.XX.146 Dynamic IB 50:05:07:00:5B:01:7F:D5 proxy-arp 7
sx60g01: XXX.XXX.XX.148 Dynamic IB 50:05:07:00:5B:01:7E:11 proxy-arp 7
sx60g01: XXX.XXX.XX.152 Dynamic IB 50:05:07:00:5B:01:7F:D5 proxy-arp 7
sx60g01: XXX.XXX.XX.154 Dynamic IB 50:05:07:00:5B:01:7F:E5 proxy-arp 7
sx60g01: XXX.XXX.XX.158 Dynamic IB 50:05:07:00:5B:01:78:19 proxy-arp 7
sx60g01: XXX.XXX.XX.160 Dynamic IB 50:05:07:00:5B:01:7E:CD proxy-arp 7
sx60g01:
sx60g02: Mellanox MLNX-OS Switch Management
sx60g02:
sx60g02: Total number of entries: 12
sx60g02: Address Type Hardware Address Interface
sx60g02: ------------------------------------------------------------------------
sx60g02: XXX.XXX.XX.188 Dynamic ETH 00:24:F7:14:7A:C1 proxy-arp 7
sx60g02: XXX.XXX.XX.189 Dynamic ETH 00:24:F7:14:B4:C1 proxy-arp 7
sx60g02: XXX.XXX.XX.190 Dynamic ETH 00:00:0C:07:AC:83 proxy-arp 7
sx60g02: XXX.XXX.XX.129 Dynamic IB 50:05:07:00:5B:01:7E:11 proxy-arp 7
sx60g02: XXX.XXX.XX.133 Dynamic IB 50:05:07:00:5B:01:7E:B1 proxy-arp 7
sx60g02: XXX.XXX.XX.135 Dynamic IB 50:05:07:00:5B:01:7E:CD proxy-arp 7
sx60g02: XXX.XXX.XX.137 Dynamic IB 50:05:07:00:5B:01:80:0D proxy-arp 7
sx60g02: XXX.XXX.XX.139 Dynamic IB 50:05:07:00:5B:01:78:19 proxy-arp 7
sx60g02: XXX.XXX.XX.141 Dynamic IB 50:05:07:00:5B:01:7F:E5 proxy-arp 7
sx60g02: XXX.XXX.XX.143 Dynamic IB 50:05:07:00:5B:01:7E:B1 proxy-arp 7
sx60g02: XXX.XXX.XX.145 Dynamic IB 50:05:07:00:5B:01:7F:D5 proxy-arp 7
sx60g02: XXX.XXX.XX.147 Dynamic IB 50:05:07:00:5B:01:7E:B1 proxy-arp 7
sx60g02:
So, for example, the IP address XXX.XXX.XX.133, that is unreachable from the internet, is defined on sx60g02 with IB-MAC 50:05:07:00:5B:01:7E:B1. However the node that is running the VM to which that floating IP is assigned, has MAC address 50:05:07:00:5b:01:7e:cd.
Moreover, looking at the ARP table of sx60g01, you can see that there are entries for the following IPs
I have assigned these floating IPs to VMs more that a week ago. At the moment no nodes, either virtual or real, have these IPs assigned.
Why are they still present in the ARP table of the gateway?
Thank you very much in advance
Ale
