I try to configure a factory-resetted Mellanox SX6036SX. I need the VPI functionality, therefore I try to setup Proxy-ARP. The software versions are the following:
MLNX-OS 3.6.8010
PPC_M460EX 3.6.8010 2018-08-20 18:04:16 ppc
I configure the switch as described in the manual like the following:
ibsw2 [standalone: master] (config) # system profile vpi-single-switch
switch-6314f4 [standalone: master] (config) # no ip routing
% Unrecognized command “routing”.
Type “no ip ?” for help.
switch-6314f4 [standalone: master] (config) # no ip igmp snooping
switch-6314f4 [standalone: master] (config) # no ib sm
switch-6314f4 [standalone: master] (config) # vlan 100
switch-6314f4 [standalone: master] (config vlan 100) # exit
switch-6314f4 [standalone: master] (config) # ip proxy-arp
switch-6314f4 [standalone: master] (config) # interface proxy-arp 1
switch-6314f4 [standalone: master] (config interface proxy-arp 1) # ip address 10.0.53.199
switch-6314f4 [standalone: master] (config interface proxy-arp 1) # ip netmask /24
switch-6314f4 [standalone: master] (config interface proxy-arp 1) # ip vlan 100
switch-6314f4 [standalone: master] (config interface proxy-arp 1) # ip pkey 0x7fff
switch-6314f4 [standalone: master] (config interface proxy-arp 1) # no shutdown
switch-6314f4 [standalone: master] (config interface proxy-arp 1) # show interfaces proxy-arp 1
After the last command, the configuration of the proxy-arp should be displayed, however, it is not. When looking at the web frontend, the checkbox “IP Proxy-ARP” is checked, however, all other options are greyed out (see screenshot).
I attached the resulting configuration of the system to this message.
Even worse, if I reboot the switch with this configuration, parts of the web interface (System / Ports) do not work (see screenshot). Moreover, all Infiniband ports are dead. If I disable the checkbox “IP Proxy-ARP” and reboot, the system is functional again.
I also had a look at the log (see attached file). In line 8180 one can see the command to enable the Proxy-ARP. Then in line 8258 something seems to go wrong:
Nov 19 19:37:42 switch-6314f4 prad[5352]: TID 1230881936: [prad.NOTICE]: prad_update_virtual_port: Enable swid=2 dev=1 lcl=66 idx=130 gda=false
Nov 19 19:37:42 switch-6314f4 prad[5352]: TID 1230881936: [prad.NOTICE]: prad_exec_enable, IN
Nov 19 19:37:42 switch-6314f4 prad[5352]: TID 1230881936: [prad.NOTICE]: prad_get_port_guid not ready, try 0
Nov 19 19:29:40 switch-6314f4 prad[5352]: TID 1230881936: [prad.ERR]: prad_get_port_guid(), prad_logic.c:86, build 1: prad_get_port_guid timed out waiting for valid /smad/state/swid_guid_map/2/port_guid
Nov 19 19:29:40 switch-6314f4 prad[5352]: TID 1230881936: [prad.ERR]: prad_exec_enable(), prad_logic.c:1477, build 1: failed to read guid, error is 14031
The log entry “Enable swid=2” seems strange to me: I have only one switch in this configuration?
Does anyone have a clue what’s happening here? Is this a configuration issue, software bug or hardware issue?
Best Regards,
Hermann
log(1).txt (550 KB)
config-6036G-211119.txt (1.2 KB)
