So, we tried reverting to factory defaults, switched LAN Cables and LAN Ports. Its still faulty.
It is NOT pingable from outside until i start pinging from the switch to other machines (10.0.100.146)
tcpdump ARP is getting more and more AFTER i used ping from console. Before it was rather low. Weird behaviour.
mx4 [standalone: master] # mx4 [standalone: master] # show interfaces mgmt0
Interface mgmt0 status:
Comment :
Admin up : yes
Link up : yes
DHCP running : no
IP address : 10.0.100.145
Netmask : 255.255.0.0
IPv6 enabled : yes
Autoconf enabled: no
Autoconf route : yes
Autoconf privacy: no
DHCPv6 running : yes (but no valid lease)
IPv6 addresses : 1
IPv6 address:
fe80::526b:4bff:fef4:fd30/64
Speed : 1000Mb/s (auto)
Duplex : full (auto)
Interface type : ethernet
Interface source: bridge
MTU : 1500
lines 1-23 HW address : 50:6B:4B:F4:FD:30
Rx:
748655546 bytes
7397224 packets
0 mcast packets
0 discards
0 errors
0 overruns
0 frame
Tx:
3503019 bytes
26117 packets
0 discards
0 errors
0 overruns
0 carrier
0 collisions
0 queue len
lines 22-44/44 (END) mx4 [standalone: master] # sh interfaces mgmt0 configured
Interface mgmt0 configuration:
Comment :
Enabled : yes
DHCP : no
DHCP Hostname : yes
Zeroconf : no
IPv6 enabled : yes
DHCPv6 enabled : yes
IPv6 addresses : 0
Speed : auto
Duplex : auto
MTU : 1500
mx4 [standalone: master] # show ip route
Flags:
F: Failed to install in H/W
B: BFD protected (static route)
i: BFD session initializing (static route)
x: protecting BFD session failed (static route)
VRF Name default:
Destination Mask Flag Gateway Interface Source
AD/M
default 0.0.0.0 10.0.254.254 mgmt0 static
1/1
10.0.0.0 255.255.0.0 0.0.0.0 mgmt0 direct
0/0
mx4 [standalone: master] # mx4 [standalone: master] # tcpdump -i mgmt0 arp
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on mgmt0, link-type EN10MB (Ethernet), capture size 262144 bytes
11:42:41.187479 ARP, Request who-has 10.0.40.170 tell 10.0.100.201, length 46
11:42:41.414540 ARP, Request who-has 10.0.40.115 tell 10.0.254.254, length 46
11:42:41.423851 ARP, Request who-has 10.0.40.155 tell 10.0.254.254, length 46
11:42:41.911195 ARP, Request who-has 10.0.10.200 tell 10.0.40.135, length 46
11:42:42.414526 ARP, Request who-has 10.0.40.115 tell 10.0.254.254, length 46
11:42:42.423809 ARP, Request who-has 10.0.40.155 tell 10.0.254.254, length 46
11:42:43.376184 ARP, Request who-has 10.0.220.222 tell 10.0.220.3, length 46
mx4 [standalone: master] # ping 10.0.254.254
PING 10.0.254.254 (10.0.254.254) 56(84) bytes of data.
— 10.0.254.254 ping statistics —
33 packets transmitted, 0 received, 100% packet loss, time 32000ms
mx4 [standalone: master] # ping 10.0.100.145
PING 10.0.100.145 (10.0.100.145) 56(84) bytes of data.
64 bytes from 10.0.100.145: icmp_seq=1 ttl=64 time=0.045 ms
64 bytes from 10.0.100.145: icmp_seq=2 ttl=64 time=0.047 ms
64 bytes from 10.0.100.145: icmp_seq=3 ttl=64 time=0.046 ms
64 bytes from 10.0.100.145: icmp_seq=4 ttl=64 time=0.047 ms
64 bytes from 10.0.100.145: icmp_seq=5 ttl=64 time=0.045 ms
64 bytes from 10.0.100.145: icmp_seq=6 ttl=64 time=0.045 ms
AFTER pinging itself and the other maschine (10.0.100.146) suddenly ping works from outside remote host and ARP works more.
11:45:43.400435 ARP, Request who-has 10.0.40.205 tell 10.0.254.254, length 46
11:45:43.415670 ARP, Request who-has 10.0.40.155 tell 10.0.254.254, length 46
11:45:43.670091 ARP, Request who-has 10.0.10.200 tell 10.0.34.105, length 46
11:45:43.694971 ARP, Request who-has 10.0.10.200 tell 10.0.34.105, length 46
11:45:44.400438 ARP, Request who-has 10.0.40.205 tell 10.0.254.254, length 46
11:45:44.415638 ARP, Request who-has 10.0.40.155 tell 10.0.254.254, length 46
11:45:45.400293 ARP, Request who-has 10.0.40.205 tell 10.0.254.254, length 46
11:45:45.415544 ARP, Request who-has 10.0.40.155 tell 10.0.254.254, length 46
11:45:46.419348 ARP, Request who-has 10.0.40.115 tell 10.0.254.254, length 46
11:45:46.438702 ARP, Request who-has 10.0.40.155 tell 10.0.254.254, length 46
11:45:46.462978 ARP, Request who-has 10.0.10.200 tell 10.0.34.105, length 46
11:45:47.419341 ARP, Request who-has 10.0.40.115 tell 10.0.254.254, length 46
11:45:47.431649 ARP, Request who-has 10.0.40.155 tell 10.0.254.254, length 46
11:45:48.419348 ARP, Request who-has 10.0.40.115 tell 10.0.254.254, length 46
11:45:48.431642 ARP, Request who-has 10.0.40.155 tell 10.0.254.254, length 46
11:45:48.449022 ARP, Request who-has 10.0.115.20 tell 10.0.100.170, length 46
11:45:48.761626 ARP, Request who-has 10.0.254.254 tell 10.0.117.200, length 46
11:45:49.403327 ARP, Request who-has 10.0.40.205 tell 10.0.254.254, length 46
11:45:50.403320 ARP, Request who-has 10.0.40.205 tell 10.0.254.254, length 46
11:45:50.415558 ARP, Request who-has 10.0.40.155 tell 10.0.254.254, length 46
11:45:51.403313 ARP, Request who-has 10.0.40.205 tell 10.0.254.254, length 46
11:45:51.415546 ARP, Request who-has 10.0.40.155 tell 10.0.254.254, length 46
11:45:52.415634 ARP, Request who-has 10.0.40.155 tell 10.0.254.254, length 46
11:45:52.438487 ARP, Request who-has 10.0.216.184 tell 10.0.110.135, length 46
11:45:53.427496 ARP, Request who-has 10.0.40.155 tell 10.0.254.254, length 46
