SN2100 MLAG link down and stuck in passive mode
We have 2 brand new SN2100 running Onyx 3.9.0914 which I’m trying to connect to a pair of Nexus switches. On the Nexus side our netops configured a vPC, on the Mellanox side I followed the guide here: https://mymellanox.force.com/mellanoxcommunity/s/article/how-to-configure-mlag-on-mellanox-switches#jive_content_id_MLAG_Interface and also read through https://community.mellanox.com/s/article/mellanox-mlag-and-cisco-vpc-configuration-and-troubleshooting
Whatever I try, the links stay down, I have tried shutting down and no shutdown on the mlag-port-channel, the members, and mlag.
EDIT: Extra detail and move switch config to here instead of reply
We are using 40G to 4x10G breakout cables. 2x10G from each breakout to each Nexus Switch
Switch 1 abridged config:
Running database “initial”
Generated at 2020/07/06 17:05:49 +0000
Hostname: VTC-PS01-140B02
Product release: 3.9.0914
Running-config temporary prefix mode setting
no cli default prefix-modes enable
Interface Split configuration
interface ethernet 1/3 module-type qsfp-split-4 force
MLAG protocol
protocol mlag
Interface Ethernet configuration
interface mlag-port-channel 90
interface port-channel 1
interface ethernet 1/3/1-1/3/4 speed 10G force
interface ethernet 1/3/1-1/3/4 mtu 9216 force
interface mlag-port-channel 90 mtu 9216 force
interface ethernet 1/1-1/2 channel-group 1 mode active
interface ethernet 1/3/1-1/3/4 mlag-channel-group 90 mode active
interface mlag-port-channel 90 switchport mode trunk
interface mlag-port-channel 90 no shutdown
LAG configuration
lacp
port-channel load-balance ethernet source-destination-mac
VLAN configuration
vlan 202
vlan 205-207
vlan 218
vlan 227
vlan 231
vlan 4000
interface mlag-port-channel 90 switchport trunk allowed-vlan none
interface mlag-port-channel 90 switchport trunk allowed-vlan add 1
interface mlag-port-channel 90 switchport trunk allowed-vlan add 202
interface mlag-port-channel 90 switchport trunk allowed-vlan add 205-207
interface mlag-port-channel 90 switchport trunk allowed-vlan add 218
interface mlag-port-channel 90 switchport trunk allowed-vlan add 227
interface mlag-port-channel 90 switchport trunk allowed-vlan add 231
STP configuration
no spanning-tree
L3 configuration
ip routing vrf default
interface vlan 4000
interface vlan 4000 ip address 192.168.100.2/24 primary
DCBX PFC configuration
dcb priority-flow-control enable force
interface port-channel 1 dcb priority-flow-control mode on force
MLAG configurations
mlag-vip mlag-vip1 ip 10.96.97.236 /25 force
no mlag shutdown
mlag system-mac 00:00:5E:00:01:5D
interface port-channel 1 ipl 1
interface vlan 4000 ipl 1 peer-address 192.168.100.4
Network interface configuration
no interface mgmt0 dhcp
interface mgmt0 ip address 10.96.97.227 /25
Other IP configuration
hostname VTC-PS01-140B02
ip domain-list redacted
ip name-server 10.96.110.2
ip route vrf default 0.0.0.0/0 10.96.97.129
Other IPv6 configuration
no ipv6 enable
Switch 2 abridged config:
Generated at 2020/07/06 17:13:09 +0000
Hostname: VTC-PS01-140B04
MLAG protocol
protocol mlag
interface ethernet 1/3/1-1/3/4 mtu 9000 force
interface mlag-port-channel 90 mtu 9000 force
LAG configuration
lacp
VLAN configuration
vlan 202
vlan 205-207
vlan 218
vlan 227
vlan 231
vlan 4000
STP configuration
no spanning-tree
L3 configuration
interface vlan 4000
interface vlan 4000 ip address 192.168.100.4/24 primary
MLAG configurations
no mlag shutdown
interface vlan 4000 ipl 1 peer-address 192.168.100.2
interface mgmt0 ip address 10.96.97.228 /25
hostname VTC-PS01-140B04
no ipv6 enable
Hi Darien,
I understand that ports 1/3/1-1/3/4 on both switches are the ones connected to the nexus switches.
By default the split ports are at speed of 25G, this is the expected speed that you want to link at or you need 10G speed on those ports?
You can change speed (need to remove the ports from MPO 90 before):
(config)# no interface ethernet 1/3/1-1/3/4 mlag-channel-group
(config)# interface ethernet 1/3/1-1/3/4 speed 10G force
(config)# interface ethernet 1/3/1-1/3/4 mlag-channel-group 90 mode active
Hi Eddie,
Yes the ports are 10G, I had already set them before adding to the channel group. I have edited the original post with that information.
Hi Darien,
Can you open a support case with support@mellanox.com ? Nvidia Mellanox Technical Support will continue working with you from the case.
