Mellanox SN2410 How to see running-config and configure "new" port according to running-config
I would like to ask how do i see running config and configure “new” port according to the running-config output.
I have Mellanox SN2410 and below is the running config output. I would to configure port 9-12 the same setting, also port 11 and 12 will configure with vlan 712
MLAG protocol
protocol mlag
Interface Ethernet configuration
interface mlag-port-channel 1-8
interface port-channel 1
interface ethernet 1/1-1/8 mtu 9216 force
interface mlag-port-channel 1-8 mtu 9216 force
lines 1-23
interface ethernet 1/1 mlag-channel-group 1 mode active
interface ethernet 1/2 mlag-channel-group 2 mode active
interface ethernet 1/3 mlag-channel-group 3 mode active
interface ethernet 1/4 mlag-channel-group 4 mode active
interface ethernet 1/5-1/8 switchport mode hybrid
interface ethernet 1/55-1/56 channel-group 1 mode active
interface mlag-port-channel 1 switchport mode hybrid
interface mlag-port-channel 2 switchport mode hybrid
interface mlag-port-channel 3 switchport mode hybrid
interface mlag-port-channel 4 switchport mode hybrid
interface mlag-port-channel 1-8 no shutdown
LAG configuration
lacp
interface mlag-port-channel 1-8 lacp-individual enable force
interface ethernet 1/1-1/4 lacp port-priority 10
interface ethernet 1/1-1/4 lacp rate fast
VLAN configuration
lines 24-46
vlan 712
vlan 4000
interface ethernet 1/5-1/8 switchport access vlan 712
interface ethernet 1/5-1/8 switchport hybrid allowed-vlan all
interface mlag-port-channel 1 switchport access vlan 712
interface mlag-port-channel 1 switchport hybrid allowed-vlan all
interface mlag-port-channel 2 switchport access vlan 712
interface mlag-port-channel 2 switchport hybrid allowed-vlan all
interface mlag-port-channel 3 switchport access vlan 712
interface mlag-port-channel 3 switchport hybrid allowed-vlan all
interface mlag-port-channel 4 switchport access vlan 712
interface mlag-port-channel 4 switchport hybrid allowed-vlan all
vlan 712 name “iSCSI Storage”
STP configuration
interface ethernet 1/1-1/8 spanning-tree bpdufilter enable
interface ethernet 1/1-1/8 spanning-tree port type edge
interface ethernet 1/1-1/8 spanning-tree bpduguard enable
L3 configuration
lines 47-69
ip routing vrf default
interface vlan 4000
interface vlan 4000 ip address 10.10.10.2/24 primary
Thanks & Regards,
Jayden
Hi Jayden,
The following lines should work:
interface mlag-port-channel 9-12
interface ethernet 1/9 mlag-channel-group 9 mode active
interface ethernet 1/10 mlag-channel-group 10 mode active
interface ethernet 1/11 mlag-channel-group 11 mode active
interface ethernet 1/12 mlag-channel-group 12 mode active
interface mlag-port-channel 9-12 switchport mode hybrid allowed-vlan all
interface mlag-port-channel 9-12 lacp-individual enable force
interface mlag-port-channel 9-10 switchport mode hybrid
interface mlag-port-channel 11-12 switchport access vlan 712
interface mlag-port-channel 9-12 mtu 9216 force
interface mlag-port-channel 9-12 spanning-tree bpdufilter enable
interface mlag-port-channel 9-12 spanning-tree port type edge
interface mlag-port-channel 9-12 spanning-tree bpduguard enable
interface mlag-port-channel 9-12 no shutdown
I noticed that you have configured mlag-port-channels but there is no IPL configured. For more information please see the following link for configuring mlag on Mellanox switches:
https://community.mellanox.com/s/article/how-to-configure-mlag-on-mellanox-switches
Just for reference please find the below link on configuring the different port types (access/hybrid/trunk) and add vlans to those ports:
https://community.mellanox.com/s/article/howto-configure-switch-port-types-with-mlnx-os
Thanks,
Kevin
