Good Morning
I configured two 1410 switch with MLAG using the doc
Mellanox Interconnect Community. I read that all VLANs are open on this port. There is no need to configure that, as once an interface is mapped as IPL all the VLANs are open on this port.
in my config for PO1 (IPL) are used port 1/49 and 1/50
sw-amb-40G-u39 [amb-vip: master] # show mlag
Admin status: Enabled
Operational status: Up
MLAG IPLs Summary:
ID Group Vlan Operational Local Peer Up Time Toggle Counter
Port-Channel Interface State IP address IP address
1 Po1 4001 Up 11.0.0.39 11.0.0.40 0 days, 12:08:19 3
If I run command show vlan I don’t see any VLAN on ports that belongs to PO1 ???. It is normal ???
sw-amb-40G-u39 [amb-vip: master] # show vlan
VLAN Name Ports
1 default Eth1/3, Eth1/4, Eth1/5, Eth1/6, Eth1/9,
Eth1/10, Eth1/11, Eth1/12, Eth1/14, Eth1/15,
Eth1/16, Eth1/17, Eth1/18, Eth1/21, Eth1/22,
Eth1/23, Eth1/24, Eth1/25, Eth1/26, Eth1/28,
Eth1/29, Eth1/30, Eth1/32, Eth1/33, Eth1/34,
Eth1/35, Eth1/36, Eth1/40, Eth1/41, Eth1/42,
Eth1/46, Eth1/47, Eth1/48, Eth1/51, Eth1/52,
Eth1/53, Eth1/54, Eth1/55, Eth1/56, Eth1/57,
Eth1/58, Eth1/59, Eth1/60, Mpo900
102 Mpo531, Mpo900
125 Mpo100, Mpo101, Mpo102, Mpo103, Mpo104,
Mpo900
540 Mpo303, Mpo304, Mpo531, Mpo800, Mpo900
4001
II see that PO1 in in trunk mode
sw-amb-40G-u39 [amb-vip: master] # show interfaces port-channel 1
Po1:
Admin state : Enabled
Operational state : Up
Switchport mode : trunk
it is normal that the ports that belongs to PO1 re in access mode ??
w-amb-40G-u39 [amb-vip: master] # show interfaces ethernet 1/49
Eth1/49:
Last change in operational status : 12:11:46 ago (3 oper change)
Boot delay time : 0 sec
Description : mlag-ipl
Mac address : 7c:fe:90:fa:3f:73
MTU : 9216 bytes (Maximum packet size 9238 bytes)
Fec : auto
Flow-control : receive off send off
Actual speed : 40 Gbps
Auto-negotiation : Enabled
Width reduction mode : Unknown
Switchport mode : access
MAC learning mode : Enabled
sw-amb-40G-u39 [amb-vip: master] # show interfaces ethernet 1/50
Eth1/50:
Last change in operational status : 12:13:04 ago (3 oper change)
Mac address : 7c:fe:90:fa:3f:53
Fec : auto
Thanks in advance
