IPL both switches show as master
FF-Core-A [FF-Core-1-Rack1: master] (config) # sh mlag-vip
MLAG-VIP:
MLAG group name: FF-Core-1-Rack1
MLAG VIP address: 10.255.12.2/23
Active nodes: 1
Hostname VIP-State IP Address
FF-Core-A master 10.255.12.21
Admin status: Enabled
Operational status: Up
Reload-delay: 30 sec
Keepalive-interval: 1 sec
Upgrade-timeout: 60 min
System-mac: 02:00:00:00:00:01
MLAG Ports Configuration Summary:
Configured: 1
Disabled: 0
Enabled: 1
MLAG Ports Status Summary:
Inactive: 0
Active-partial: 0
Active-full: 1
MLAG IPLs Summary:
ID Group Vlan Operational Local Peer Up Time Toggle Counter
Port-Channel Interface State IP address IP address
1 Po4094 4000 Up 1.1.1.0 1.1.1.1 0 days, 00:15:24 3
MLAG Members Summary:
System-id State Hostname
90:0A:84:52:8E:C8 Up
90:0A:84:6D:21:08 Up -
I can ping the IPl address of the remote and the reciprocal.
mlag-vip FF-Core-1-Rack1 ip 10.255.12.2 /23 force
no mlag shutdown
mlag system-mac 02:00:00:00:00:01
interface port-channel 4094 ipl 1
interface vlan 4000 ipl 1 peer-address 1.1.1.1
AND
no mlag shutdown
interface vlan 4000 ipl 1 peer-address 1.1.1.0
FF-Core-A [FF-Core-1-Rack1: master] (config) # sh interfaces port-channel 4094
Po4094:
Admin state : Enabled
Operational state : Up
Description : N/A
Mac address : N/A
MTU : 9216 bytes (Maximum packet size 9238 bytes)
lacp-individual mode: Disabled
Flow-control : receive off send off
Actual speed : 2 X 100G
Width reduction mode: Not supported
Switchport mode : trunk
MAC learning mode : Enabled
Forwarding mode : inherited cut-through
Telemetry sampling: Disabled TCs: N/A
Check the system clock also.
this should be part of a support case as extensive debug is needed.
can you open such case?
https://enterprise-support.nvidia.com/s/create-case
Thanks. I factory reset and tried another run at it and it failed again even the the port-channel, L3 etc is all reporting properly and peer addressing is pingable.
I have a support case open and will be looking at this Monday. Even the logs are showing the IPL transitioning properly from what I can tell.
What is the case number?
I have it with HPE Storage Networking.
