We have three SN2100 switches all running Onyx 3.10.4404. All are able to pick up NTP from the mgmt0 VRF interface using ntpdate, so we know there is connectivity to a server…
ar-sn2100-03 [standalone: master] (config) # ntpdate time.google.com
4 Mar 15:33:06 ntpdate[3098184]: adjust time server 216.239.35.12 offset 0.000134 sec
But we cant seem to see the switch query the NTP server on its own. And we always see “Clock is unsynchronized”. For example…
ar-sn2100-03 [standalone: master] (config) # show ntp
NTP is administratively : enabled
VRF name : default
NTP Authentication administratively: disabled
NTP server role : enabled
Clock is unsynchronized.
Active servers and peers:
2001:4860:4806:4:::
Configured as : time.google.com
Conf Type : serv
Status : pending
Stratum : 16
Offset(msec) : 0.000
Ref clock : .INIT.
Poll Interval (sec): 128
Last Response (sec): N/A
Auth state : none
Feels like I’m missing something basic - would appreciate a pointer to my cockpit error without too much shaming.
Please configure a source IP for NTP on vrf default, then see if it can be synced automatically.
If no, please try NTP syncing with some other public or your private NTP servers better as the close ones (with Stratum in low values). Also please try this with the source IP set.
The command ‘ntpdate’ is ‘a one -time operation and does not cause the clock to be kept in sync’ from Onyx user manual.
Hi @derxu . I’m not exactly sure how to do that. Let me explain what we are trying to do, maybe there is a better way. We have a set of sn2100/2700 switches for our 100G infrastructure. All the management interfaces on are on a class-c control plane LAN with gateway access to the internet. When the switches are power-cycled, they lose their clock. We would like to at least get them close with a configuration that uses NTP to get approximate time. That the one-time ‘ntpdate’ works, suggests that there may be a solution. Can you explain to me exactly how to configure a source IP for NTP on vrf default? It was not clear to me from the docs.
I did create a loopback0 interface and gave it a legit unused address on the control plane, but then nothing worked, not even ‘ntpdate’…
ar-sn2100-02 [standalone: master] (config) # show ntp vrf all source-interface
VRF name: default
Source IP for ntp client:
Configured: loopback0
Current : loopback0
IPv4-addr : 10.0.209.42
IPv6-addr : none
ar-sn2100-02 [standalone: master] (config) # ntpdate ntp-b.nist.gov
% 7 Mar 15:32:46 ntpdate[412659]: no server suitable for synchronization found
If it is is needed, we can place a hardware NTP server on the class-c control plane LAN to which all the management ports connect. That’s not ideal, but we can do that.
Also, we do have multiple PTP grandmasters connected to several switches (for other purposes besides this). These are connected directly to data plane switch ports of the switch. We could enable the NTP server(s) in any of the PTP grandmasters to allows the switch NTP client to try to get NTP time from some port other than the management port(s). Feels like this gymnastic exercise should not be needed, just saying that it is there too.
Obviously this isn’t my day job - so appreciate the kind feedback. Guessing that this dance would be about the same if we were running Cumulus instead of Onyx?
Please run these commands first to check the present switch configuration,
show vrf – which vrfs are ready out there
show interface mgmt0 - this displays on which vrf mgmt0 is located on
Once located the mgmt 0 interface, then config the IP add used to communicate to the NTP server.
ntp vrf source-interface
Then save the config by
write memory
show ntp – validation
All the above commands can be executed in config mode.
BTW, Onyx has been announced with extended Tech support till 2025 on releases for bug fix and security patches. No more new features will be developed.
Please have this in mind and prepare for transition to cumulus linux.
After write memory and some other fooling around, still no luck…
VRF name : default
NTP server role : disabled
132.163.96.5:
Configured as : ntp-b.nist.gov
Conf Type : serv
Status : pending
Stratum : 16
Ref clock : .INIT.
Poll Interval (sec): 1024
Auth state : none
2001:4860:4806:4:::
Conf Type : serv
Status : pending
Stratum : 16
Ref clock : .INIT.
Auth state : none
So not sure where Im going wrong. Also, ever since I created the loopback0 VRF, this switch doesn’t even allow ntpdate…
% 7 Mar 16:58:36 ntpdate[418156]: no server suitable for synchronization found
Here are some sections from “show configuration” in case these is a clue to what I am doing wrong…
## L3 configuration
ip routing vrf default
interface loopback 0
interface loopback 0 ip address 10.0.209.42/32 primary
interface loopback 0 ip address 10.0.209.183/32
ntp vrf default source-interface loopback0
## Other IP configuration
hostname ar-sn2100-02
ip route vrf default 0.0.0.0/0 10.0.209.1
## Other IPv6 configuration
no ipv6 enable
## Network management configuration
# web proxy auth basic password ********
no ntp server 132.163.96.5 disable
ntp server 132.163.96.5 keyID 0
no ntp server 132.163.96.5 trusted-enable
ntp server 132.163.96.5 version 4
no ntp server ntp-b.nist.gov disable
ntp server ntp-b.nist.gov keyID 0
no ntp server ntp-b.nist.gov trusted-enable
ntp server ntp-b.nist.gov version 4
no ntp server time.google.com disable
ntp server time.google.com keyID 0
no ntp server time.google.com trusted-enable
ntp server time.google.com version 3
ntp server-role disable
ntp vrf default enable
telnet-server enable
terminal sysrq enable
no web auto-logout
web http enable
no web https ssl secure-cookie enable
web vrf default enable
## IPv4 packet filtering configuration
no ip filter chain forward rule all
no ip filter chain input rule all
no ip filter chain logging rule all
no ip filter chain output rule all
no ip filter enable
When you config the Lo0 as the source interface, can the lo0 interface IP ping to the NTP server?
If you do want to use a separate vrf, mgmt can be defined as the name. And interface mgmt0 or lo0 needs to be placed into the vrf with the route reachable from the interface to the NTP server.
Currently, only one ‘default’ vrf is there. To make it simple, you can leave the Lo0 with vrf default but needs to make sure lo0 IP is able to ping to the NTP server whichever it is, such as 8.8.8.8 or 8.8.4.4.
Hi @derxu If you have the time, I would be happy to jump on a screenshare call with you. I’m free this afternoon except for 2PM-330PM ET. If you can, shoot me you email address privately and I’ll send you an invite at the day/time of your preference. Shep
Thanks derxu. I’ve created a case 00674360 in the Enterprise Support Portal referencing this forum thread. You’ve been super-helpful, thanks. I’ll update this thread when we understated why this works:
ar-sn2100-03 [standalone: master] (config) # ping google.com
PING google.com (142.251.40.142) 56(84) bytes of data.
64 bytes from lga25s80-in-f14.1e100.net (142.251.40.142): icmp_seq=1 ttl=56 time=27.9 ms
64 bytes from lga25s80-in-f14.1e100.net (142.251.40.142): icmp_seq=2 ttl=56 time=24.2 ms
^C
--- google.com ping statistics ---
2 packets transmitted, 2 received, 0% packet loss, time 1002ms
rtt min/avg/max/mdev = 24.197/26.056/27.916/1.866 ms
