I think I have the same issue as SN2100 NTP Debugging
Basically I can run the ntpdate command all day long from any switch (4x MSN2100’s). All reach the 3 possible “servers” and set the date.
Add the NTP Servers in and still all we get is “Clock is unsynchronized” and the red boxes saying the NTP servers are not running. This seems wacked. Does anyone have the secret decoder ring to resolve this?
The FW’s do not log NTP traffic so I can’t rely on their logs for disproving any sort of “attempts” but is it because ntpdate really only applies if the switch is acting “as a server” and it’s used to true it up, or, should this just work? Onyx 3.10.2202
thanks
Hi David,
This issue appears to require some triage steps that are too involved to address over the support forums. Please open a support case on this so we can assist you in the most efficient and effective way possible.
Thank you!
