Running without nvidia driver (just nouveau) - no visible artifacts.
Lowering the resolution to 1920x1080 - no artifacts (at least there are no vertical lines but some slight pixel inconsistency instead, sort of ‘X’ grid).
Switching to HDMI connection - no visible artifacts.
Using DP-to-HDMI cable - no visible artifacts.
Finally I installed Windows10 with 441.08/441.41 driver and used the same DisplayPort connection - no visible artifacts in QHD.
Additional information:
I tried to play with xrandr setting custom resolution of 2560x1440_59Hz, and this seem to affect lines visibility somehow, but not completely eliminated them.
Those lines may appear in different places, i.e. on different dark backgrounds. I can spot them in one part of the Telegram UI, turn the monitor off and on, and then they appear in other places of the UI.
First I ran AIDA64 GPU test - it completed successfully.
In order to stress test the GPU I ran Furmark with different presets couple of times.
Result: no visible artifacts (Windows + 441.41 + DisplayPort + QHD resolution), stable run, no overheating.
Can you please suggest trying anything else?
Could this be a Linux driver bug?
I thought about returning this card to store’s service center for extended diagnostics, but I think they will simply plug the GPU into Windows PC and find no problems with it.
I’ve been having the same problem since I switched from HDMI-to-DVI to DisplayPort. The problem happened on my GTX 1060 and still happens on my new RTX 2080.
Also noticed that on a screenshot, viewed from another device, the artifacts don’t show.
I would guess it’s either something in the driver when displaying over displayport, or the cable itself. I don’t have another cable to test though.
Hi. I know i might be a little late, but even if you don’t see this it may help others like me. I am aware you can install NVIBRANT on Linux to force disable dithering on Wayland systems with the following command ATTRIBUTE=dithering uvx nvibrant. I havent tested if it fixes mine yet but I would give it a go. PS ill reply to this later if it does indeed work.
Edit: THIS HAS SOLVED THE ISSUE ON WAYLAND
However if you installed nvibrant thought the rpm package you should run the command without the uvx line. Also this needs to be ran each time on startup so make sure to make it into a script and add it to startup options
