As our design ,we need connect the GPS’s synchronization signal PPS,PPS is a TTL signal,1hz ,so which GPIO can use?If have some suggestion?
hello lishuiwang1007,
please refer to similar discussion threads for the steps, Topic 124003, and Topic 125189.
thanks
Related topics
| What GPIO to use for 1PPS signal from GPS receiver with AGXI | 1 | 1081 | March 7, 2022 | |
| How to use gpio pps as input signal for agx orin/jp5.1.1 | 5 | 473 | December 2, 2024 | |
| Jetson Xavier hardware pps_out | 17 | 6386 | June 24, 2020 | |
| how to setup NTPD with GPIO PPS | 2 | 894 | November 7, 2019 | |
| Enable PSS on Jetson-GPIO Pin Header | 24 | 4671 | November 15, 2023 | |
| Enabling PPS on Xavier AGX | 30 | 7231 | April 7, 2021 | |
| Enable PPS on Jetson AGX Xavier | 5 | 2244 | December 11, 2020 | |
| Getting an 8microsecond GPS PPS event to trigger on GPIO | 1 | 1337 | May 2, 2022 | |
| Connecting GPS with PPS to Xavier | 16 | 5406 | May 6, 2019 | |
| How to reuse gpio388 as a pps input in TX2? | 14 | 1681 | January 14, 2021 |
