Asus PG32UQX monitor - GSync Issues under Linux (with workaround)
Most of the time, under Linux the Asus PG32UQX monitor isn’t detected as GSync capable. This is most likely a driver bug.
Fortunately, there is a work around:
  1. Open nvidia-settings
  2. Go to “X Server Display Configuration”.
  3. Click on the “Advanced” button.
  4. Check “Allow G-SYNC on monitor not validated as G-SYNC Compatible”
  5. Click on apply.
I don’t think there’s a way to apply this setting via the CLI, but I’d be happy to be wrong about that. :)
Hopefully that helps someone… Hopefully this gets fixed soon.
