Attempting to perform BLAS operation using StreamExecutor without BLAS support
I am currently getting familiar with Jetson Orin 64 GB devkit. With installed jetpack 6.0 I have pulled nvcr.io/nvidia/tensorflow 23.06-tf2-py3 image and ran it with command:
docker run --rm --runtime=nvidia --gpus all --ipc=host --ulimit memlock=-1 --ulimit stack=67108864 -it -v ~/tensorflow_tests:/mnt/tensorflow_tests nvcr.io/nvidia/tensorflow:23.06-tf2-py3
Output is like this:
== TensorFlow ==
NVIDIA Release 23.06-tf2 (build 61512348)
TensorFlow Version 2.12.0
Container image Copyright (c) 2023, NVIDIA CORPORATION & AFFILIATES. All rights reserved.
Copyright 2017-2023 The TensorFlow Authors.  All rights reserved.
Various files include modifications (c) NVIDIA CORPORATION & AFFILIATES.  All rights reserved.
This container image and its contents are governed by the NVIDIA Deep Learning Container License.
By pulling and using the container, you accept the terms and conditions of this license:
https://developer.nvidia.com/ngc/nvidia-deep-learning-container-license
Failed to detect NVIDIA driver version.
Now I am creating script for simple nn training test:
import tensorflow as tf
from tensorflow.keras.models import Sequential
from tensorflow.keras.layers import Dense, Flatten
from tensorflow.keras.datasets import mnist
# Configure TensorFlow to use GPU memory growth
gpus = tf.config.experimental.list_physical_devices('GPU')
if gpus:
    try:
        for gpu in gpus:
            tf.config.experimental.set_memory_growth(gpu, True)
    except RuntimeError as e:
        print(e)
# Load and preprocess the MNIST dataset
(x_train, y_train), (x_test, y_test) = mnist.load_data()
x_train, x_test = x_train / 255.0, x_test / 255.0
# Define a simple neural network model
model = Sequential([
    Flatten(input_shape=(28, 28)),
    Dense(128, activation='relu'),
    Dense(10, activation='softmax')
# Compile the model
model.compile(optimizer='adam',
              loss='sparse_categorical_crossentropy',
              metrics=['accuracy'])
# Train the model
model.fit(x_train, y_train, epochs=5, batch_size=32, validation_data=(x_test, y_test))
# Evaluate the model
test_loss, test_acc = model.evaluate(x_test, y_test, verbose=2)
print(f'\nTest accuracy: {test_acc}')
And this is the error I get:
/usr/local/lib/python3.10/dist-packages/tensorflow_io/python/ops/__init__.py:98: UserWarning: unable to load libtensorflow_io_plugins.so: unable to open file: libtensorflow_io_plugins.so, from paths: ['/usr/local/lib/python3.10/dist-packages/tensorflow_io/python/ops/libtensorflow_io_plugins.so']
caused by: ["[Errno 2] The file to load file system plugin from does not exist.: '/usr/local/lib/python3.10/dist-packages/tensorflow_io/python/ops/libtensorflow_io_plugins.so'"]
  warnings.warn(f"unable to load libtensorflow_io_plugins.so: {e}")
/usr/local/lib/python3.10/dist-packages/tensorflow_io/python/ops/__init__.py:104: UserWarning: file system plugins are not loaded: unable to open file: libtensorflow_io.so, from paths: ['/usr/local/lib/python3.10/dist-packages/tensorflow_io/python/ops/libtensorflow_io.so']
caused by: ['/usr/local/lib/python3.10/dist-packages/tensorflow_io/python/ops/libtensorflow_io.so: cannot open shared object file: No such file or directory']
  warnings.warn(f"file system plugins are not loaded: {e}")
Downloading data from https://storage.googleapis.com/tensorflow/tf-keras-datasets/mnist.npz
11490434/11490434 [==============================] - 1s 0us/step
Epoch 1/5
2024-07-18 14:55:39.418536: E tensorflow/compiler/xla/stream_executor/cuda/cuda_blas.cc:232] failed to create cublas handle: the resource allocation failed
2024-07-18 14:55:39.418667: E tensorflow/compiler/xla/stream_executor/cuda/cuda_blas.cc:235] Failure to initialize cublas may be due to OOM (cublas needs some free memory when you initialize it, and your deep-learning framework may have preallocated more than its fair share), or may be because this binary was not built with support for the GPU in your machine.
2024-07-18 14:55:39.418745: W tensorflow/core/framework/op_kernel.cc:1830] OP_REQUIRES failed at matmul_op_impl.h:621 : INTERNAL: Attempting to perform BLAS operation using StreamExecutor without BLAS support
  File "/mnt/tensorflow_tests/tf_test.py", line 32, in <module>
  File "/usr/local/lib/python3.10/dist-packages/keras/utils/traceback_utils.py", line 70, in error_handler
    raise e.with_traceback(filtered_tb) from None
  File "/usr/local/lib/python3.10/dist-packages/tensorflow/python/eager/execute.py", line 52, in quick_execute
    tensors = pywrap_tfe.TFE_Py_Execute(ctx._handle, device_name, op_name,
tensorflow.python.framework.errors_impl.InternalError: Graph execution error:
Detected at node 'sequential/dense/MatMul' defined at (most recent call last):
    File "/usr/local/lib/python3.10/dist-packages/keras/utils/traceback_utils.py", line 65, in error_handler
      return fn(*args, **kwargs)
    File "/usr/local/lib/python3.10/dist-packages/keras/engine/training.py", line 1685, in fit
      tmp_logs = self.train_function(iterator)
    File "/usr/local/lib/python3.10/dist-packages/keras/engine/training.py", line 1284, in train_function
      return step_function(self, iterator)
    File "/usr/local/lib/python3.10/dist-packages/keras/engine/training.py", line 1268, in step_function
      outputs = model.distribute_strategy.run(run_step, args=(data,))
    File "/usr/local/lib/python3.10/dist-packages/keras/engine/training.py", line 1249, in run_step
      outputs = model.train_step(data)
    File "/usr/local/lib/python3.10/dist-packages/keras/engine/training.py", line 1050, in train_step
      y_pred = self(x, training=True)
    File "/usr/local/lib/python3.10/dist-packages/keras/engine/training.py", line 558, in __call__
      return super().__call__(*args, **kwargs)
    File "/usr/local/lib/python3.10/dist-packages/keras/engine/base_layer.py", line 1145, in __call__
      outputs = call_fn(inputs, *args, **kwargs)
    File "/usr/local/lib/python3.10/dist-packages/keras/utils/traceback_utils.py", line 96, in error_handler
    File "/usr/local/lib/python3.10/dist-packages/keras/engine/sequential.py", line 412, in call
      return super().call(inputs, training=training, mask=mask)
    File "/usr/local/lib/python3.10/dist-packages/keras/engine/functional.py", line 512, in call
      return self._run_internal_graph(inputs, training=training, mask=mask)
    File "/usr/local/lib/python3.10/dist-packages/keras/engine/functional.py", line 669, in _run_internal_graph
      outputs = node.layer(*args, **kwargs)
    File "/usr/local/lib/python3.10/dist-packages/keras/layers/core/dense.py", line 241, in call
      outputs = tf.matmul(a=inputs, b=self.kernel)
Node: 'sequential/dense/MatMul'
         [[{{node sequential/dense/MatMul}}]] [Op:__inference_train_function_717]
nvcc --version:
Copyright (c) 2005-2023 NVIDIA Corporation
Built on Tue_Aug_15_22:08:11_PDT_2023
Cuda compilation tools, release 12.2, V12.2.140
Build cuda_12.2.r12.2/compiler.33191640_0
nvidia-smi:
Thu Jul 18 17:00:59 2024
| NVIDIA-SMI 540.3.0                Driver Version: N/A          CUDA Version: 12.2     |
| GPU  Name                 Persistence-M | Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp   Perf          Pwr:Usage/Cap |         Memory-Usage | GPU-Util  Compute M. |
|                                         |                      |               MIG M. |
|   0  Orin (nvgpu)                  N/A  | N/A              N/A |                  N/A |
| N/A   N/A  N/A               N/A /  N/A | Not Supported        |     N/A          N/A |
|                                         |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                            GPU Memory |
|        ID   ID                                                             Usage      |
|  No running processes found                                                           |
Orin is an iGPU system so could you give iGPU container a try?
Ex. nvcr.io/nvidia/tensorflow:24.06-tf2-py3-igpu
Thank you, this was the solution.
