Audio 2 face Rest API '/A2F/Player/GetInstances' dosen't work
I am trying to incorporate NVIDIA REST API. For testing I hit /A2F/Player/GetInstances end point in my Linux machine. Below is response:-
  "status": "OK",
  "result": {
    "regular": [],
    "streaming": [
      "/World/audio2face/PlayerStreaming"
  "message": "Suceeded to retrieve Player instances"
I have tried this api in three different beta versions : 2023.2.0, 2023.1.0 and 2022.2.0.
None them return regular player.
When I hit following API /A2F/Player/SetRootPath with
“a2f_player”: “World/audio2face/Player”,
“dir_path”: “path/to/my/audio/files”
It gave following error:
“status”: “ERROR”,
“result”: null,
“message”: “<class ‘ValueError’>: World/audio2face/Player - Regular player not found”
Not sure what is wrong, I restart application multiple times , no luck here.
I am starting application via ./audio2face_headless.sh
Did you open a stage with a regular player? Is it possible that you only have a streaming player in your currently opened stage?
Yes It is possible it might just have streaming player but how to fix it, there is no detail document about it. I just launched using ./audio2face_headless.sh script.
Opening ./audio2face_headless.sh only opens the app. It might come with a default streaming player.
If you need a regular player, you will need to open a usd file that already has a regular player.
You can use Audio2Face UI and create a file that has a regular player. Then open that file using Audio2Face_headless
Yes, that was the error, I was loading usd file with streaming player, now when I load usd player with regular player it works very well. Thank you.
