I recieve this error in LazyGraph Error: Assertion raised in compute - Instance of type AudioPlayerInstance does not exist: /World/audio2face/Player
Welcome to the forums @sjafari
Could you please send your latest Audio2Face log file? It should be located inside C:\Users\<USERNAME>\.nvidia-omniverse\logs\Kit\Audio2Face
on Windows and ~/.nvidia-omniverse/logs/Kit/Audio2Face
on Linux?
kit_20240214_114654.log (116.8 KB)
@sjafari i am just a fellow OV user, so take my input as a grain of salt. but based on the log provided, it seems like there are some issues when connecting to nucleus, which is a bit odd since i am not sure how it relates, if at all, to the error message you posted initially. did you already set up a nucleus service and/or nucleus server? and are all the services shown as running in the OV system monitor (http://localhost:3080/)?
thanks for your reply, yes I have already set uo a local nucleus server and all the services are shown as running in the system monitor. I have not yet resolved the issue though.
Have you recently updated Audio2Face app? If yes, I suggest uninstalling everything and installing them again.
Have you edited any of the config files? If yes, does it work with the default settings right after a clean install?
Thanks alot, the audio player appeared after uninstallng and installing again. the face movements look so strange though. I am going to redo some steps in setting up the .usd file and see how it goes.
