Audio2face Not Launching
I downloaded the most recent version of audio2face (2022.1.1)on a pc with the most recent version of windows10 and it will not launch.
Ryzen 7 3700x
RTX 2080 Super
16GB Ram
Hi there, can you please share your log file?
launcher.log (36.1 KB)
omni.processlifetime.log (8.5 KB)
We need the Audio2Face log files which can be found here: C:\Users\<USERNAME>\.nvidia-omniverse\logs\Kit\Audio2Face
There is no “kit” in the logs file under .nvidia-omniverse only launcher.log and omni.processlifetime.log
Im not finding it
must be frustrating… maybe you can share a print screen of that folder:
Re-install maybe helps?
I hope Nvidia people have time to help you out…
I shared your logs with the team. Hoping to get an answer soon. In the meantime, could you please try removing everything and installing the latest ones?
okay did a fresh install on both omniverse and audio2face, everything is exactly the same.
Thanks for trying again @Leftyshifter
Just to make sure we’re on the same page, did you install Audio2Face 2022.2.0?
yeah it definitely is
Sorry you’re experiencing this issue. We have logged a bug ticket and our team is working on this.
@Leftyshifter Could you please tell us your graphic’s driver version?
531.18
Can you try installing 527.37 to see if it works?
no change
Thanks for testing. I’ll add this info to the ticket OM-84665
When launching the first time, the screen gets stuck for a long time (around 5 min) then it starts to catch and its building the TensorRT Engine once for the Emotionen, then the Auto-Emotion, which also takes couple of minutes. After that it worked for me at least
