Hi, when I hit the launch button nothing happens .
Welcome to the forum @vidyaravichander
Could you please send your latest Launcher log? It should be located inside C:\Users\<UserName>\.nvidia-omniverse\logs\launcher.log
launcher.log (522.6 KB)
I have uploaded the above mentioned file
@vidyaravichander i am just another OV user, is it possible for you to check whether there are log files in the following directory:
%userprofile%\.nvidia-omniverse\logs\Kit\Audio2Face\2023.2
if you do, mind uploading the latest log file from there as well?
sure @Simplychenable . I am a new user here …
kit_20231213_173713.log (690.5 KB)
kit_20231213_175106.log (690.9 KB)
kit_20231213_175701.log (690.8 KB)
kit_20231214_041655.log (659.7 KB)
kit_20231214_041659.log (693.2 KB)
thanks for uploading them!
looks like you are using Tesla T4, so i think that may be the attributing factor; another aspect i’d defer to @Ehsan.HM is the OS you are running (Windows Server 2022 Datacenter). generally speaking, OV supports only RTX cards but there are a few exceptions based on what i’ve heard with particular setup. here’s a thread getting into a few of those details when it comes to A2F specifically:
so, i am sure Ehsan can help confirm whether Tesla T4 is applicable for you at some point.
fyi, here is the technical requirement for A2F, feel free to take a look:
the mods/devs would be better suited to check those out for you. so hang tight!
@vidyaravichander Are you using this in a cloud windows machine?
