Can you tell me when the release is expected?
https://docs.nvidia.com/jetson/l4t-multimedia/group__LibargusAPI.html
- Auto-focus. (Planned to be added in a later release.)
How can I make an auto focus camera at the current point in time?
Thank you.
Current release won’t support it. You can try the manual control the focus by IOCTL to focuser kernel driver.
Cameras such as
As you said, is it true if you manually set the focus control using IOCTL?
Thank you.
This case is YUV sensor without Jetson ISP. They focus alg could be integrate with the external ISP.
