Hello
I am using an auvidea j140 board with TX2, I installed JetPack 4.6 which was provided by the board manufacturer.
I added my imx290 sensor driver, the sensor initializes without problems, but when I try to get an image I only get the trace “rtos_queue_peek_from_isr_failed”
I checked the physical connections as well as the signal from the sensor, everything is ok.
The sensor is connected to the CSI-CD connector (J14).
The sensor is fine, I have successfully used the sensor driver and sensor on a JetPack 4.2 with a development board.
Trace:
kworker/5:1-724 [005] .... 424.758352: rtos_queue_peek_from_isr_failed: tstamp:13529293209 queue:0x0b4b4940 kworker/5:1-724 [005] .... 424.926332: rtos_queue_peek_from_isr_failed: tstamp:13534293215 queue:0x0b4b4940 kworker/5:1-724 [005] .... 425.094344: rtos_queue_peek_from_isr_failed: tstamp:13539293221 queue:0x0b4b4940…
kworker/5:1-724 [005] … 429.574319: rtos_queue_peek_from_isr_failed: tstamp:13679293415 queue:0x0b4b4940
kworker/5:1-724 [005] … 429.686326: rtos_queue_peek_from_isr_failed: tstamp:13684293422 queue:0x0b4b4940
kworker/5:1-724 [005] … 429.854327: rtos_queue_peek_from_isr_failed: tstamp:13689293424 queue:0x0b4b4940
kworker/5:1-724 [005] … 429.910294: rtos_queue_peek_from_isr_failed: tstamp:13691049789 queue:0x0b4b4940
gst-plugin-scan-8927 [004] … 500.605750: tegra_channel_open: vi-output, imx290 2-001a
gst-plugin-scan-8927 [004] … 500.607012: tegra_channel_set_power: imx290 2-001a : 0x1
gst-plugin-scan-8927 [004] … 500.607020: camera_common_s_power: status : 0x1
gst-plugin-scan-8927 [004] … 500.630552: tegra_channel_set_power: 150c0000.nvcsi–1 : 0x1
gst-plugin-scan-8927 [004] … 500.630561: csi_s_power: enable : 0x1
gst-plugin-scan-8927 [004] … 500.632536: tegra_channel_close: vi-output, imx290 2-001a
gst-plugin-scan-8927 [004] … 500.632540: tegra_channel_set_power: imx290 2-001a : 0x0
gst-plugin-scan-8927 [004] … 500.632547: camera_common_s_power: status : 0x0
gst-plugin-scan-8927 [004] … 500.632702: tegra_channel_set_power: 150c0000.nvcsi–1 : 0x0
gst-plugin-scan-8927 [004] … 500.632703: csi_s_power: enable : 0x0
nvargus-daemon-8944 [004] … 501.016651: tegra_channel_open: vi-output, imx290 2-001a
nvargus-daemon-8944 [004] … 501.016662: tegra_channel_set_power: imx290 2-001a : 0x1
nvargus-daemon-8944 [004] … 501.016669: camera_common_s_power: status : 0x1
nvargus-daemon-8944 [004] … 501.040251: tegra_channel_set_power: 150c0000.nvcsi–1 : 0x1
nvargus-daemon-8944 [004] … 501.040257: csi_s_power: enable : 0x1
nvargus-daemon-8944 [004] … 501.040451: tegra_channel_close: vi-output, imx290 2-001a
nvargus-daemon-8944 [004] … 501.040457: tegra_channel_set_power: imx290 2-001a : 0x0
nvargus-daemon-8944 [004] … 501.040467: camera_common_s_power: status : 0x0
nvargus-daemon-8944 [003] … 501.040661: tegra_channel_set_power: 150c0000.nvcsi–1 : 0x0
nvargus-daemon-8944 [003] … 501.040664: csi_s_power: enable : 0x0
nvargus-daemon-8944 [003] … 501.044933: tegra_channel_open: vi-output, imx290 2-001a
nvargus-daemon-8944 [003] … 501.044944: tegra_channel_set_power: imx290 2-001a : 0x1
nvargus-daemon-8944 [003] … 501.044950: camera_common_s_power: status : 0x1
nvargus-daemon-8944 [003] … 501.068542: tegra_channel_set_power: 150c0000.nvcsi–1 : 0x1
nvargus-daemon-8944 [003] … 501.068547: csi_s_power: enable : 0x1
nvargus-daemon-8944 [003] … 501.068695: tegra_channel_close: vi-output, imx290 2-001a
nvargus-daemon-8944 [003] … 501.068699: tegra_channel_set_power: imx290 2-001a : 0x0
nvargus-daemon-8944 [003] … 501.068709: camera_common_s_power: status : 0x0
nvargus-daemon-8944 [003] … 501.068903: tegra_channel_set_power: 150c0000.nvcsi–1 : 0x0
nvargus-daemon-8944 [003] … 501.068905: csi_s_power: enable : 0x0
nvargus-daemon-8944 [003] … 501.091191: tegra_channel_open: vi-output, imx290 2-001a
nvargus-daemon-8944 [003] … 501.091206: tegra_channel_set_power: imx290 2-001a : 0x1
nvargus-daemon-8944 [003] … 501.091218: camera_common_s_power: status : 0x1
nvargus-daemon-8944 [003] … 501.115484: tegra_channel_set_power: 150c0000.nvcsi–1 : 0x1
nvargus-daemon-8944 [003] … 501.115493: csi_s_power: enable : 0x1
nvargus-daemon-8944 [003] … 501.115601: tegra_channel_close: vi-output, imx290 2-001a
nvargus-daemon-8944 [003] … 501.115610: tegra_channel_set_power: imx290 2-001a : 0x0
nvargus-daemon-8944 [003] … 501.115625: camera_common_s_power: status : 0x0
nvargus-daemon-8944 [003] … 501.115975: tegra_channel_set_power: 150c0000.nvcsi–1 : 0x0
nvargus-daemon-8944 [003] … 501.115978: csi_s_power: enable : 0x0
nvargus-daemon-8944 [003] … 501.116338: tegra_channel_open: vi-output, imx290 2-001a
nvargus-daemon-8944 [003] … 501.116351: tegra_channel_set_power: imx290 2-001a : 0x1
nvargus-daemon-8944 [003] … 501.116364: camera_common_s_power: status : 0x1
nvargus-daemon-8944 [003] … 501.140058: tegra_channel_set_power: 150c0000.nvcsi–1 : 0x1
nvargus-daemon-8944 [003] … 501.140065: csi_s_power: enable : 0x1
nvargus-daemon-8944 [003] … 501.140577: tegra_channel_close: vi-output, imx290 2-001a
nvargus-daemon-8944 [003] … 501.140590: tegra_channel_set_power: imx290 2-001a : 0x0
nvargus-daemon-8944 [003] … 501.140610: camera_common_s_power: status : 0x0
nvargus-daemon-8944 [003] … 501.140944: tegra_channel_set_power: 150c0000.nvcsi–1 : 0x0
nvargus-daemon-8944 [003] … 501.140949: csi_s_power: enable : 0x0
nvargus-daemon-8944 [003] … 501.141381: tegra_channel_open: vi-output, imx290 2-001a
nvargus-daemon-8944 [003] … 501.141399: tegra_channel_set_power: imx290 2-001a : 0x1
nvargus-daemon-8944 [003] … 501.141416: camera_common_s_power: status : 0x1
nvargus-daemon-8944 [003] … 501.165132: tegra_channel_set_power: 150c0000.nvcsi–1 : 0x1
nvargus-daemon-8944 [003] … 501.165140: csi_s_power: enable : 0x1
nvargus-daemon-8944 [003] … 501.165426: tegra_channel_close: vi-output, imx290 2-001a
nvargus-daemon-8944 [003] … 501.165437: tegra_channel_set_power: imx290 2-001a : 0x0
nvargus-daemon-8944 [003] … 501.165451: camera_common_s_power: status : 0x0
nvargus-daemon-8944 [003] … 501.165736: tegra_channel_set_power: 150c0000.nvcsi–1 : 0x0
nvargus-daemon-8944 [003] … 501.165741: csi_s_power: enable : 0x0
kworker/5:1-724 [005] … 501.266229: rtos_queue_peek_from_isr_failed: tstamp:15920764520 queue:0x0b4b4940
kworker/5:1-724 [005] … 501.266233: rtcpu_start: tstamp:15920765973
kworker/5:1-724 [005] … 501.266235: rtos_queue_send_from_isr_failed: tstamp:15920774557 queue:0x0b4a7698
kworker/5:1-724 [005] … 501.266235: rtos_queue_send_from_isr_failed: tstamp:15920774665 queue:0x0b4ab1a8
kworker/5:1-724 [005] … 501.266236: rtos_queue_send_from_isr_failed: tstamp:15920774773 queue:0x0b4acdd8
kworker/5:1-724 [005] … 501.266237: rtos_queue_send_from_isr_failed: tstamp:15920774879 queue:0x0b4ae958
kworker/5:1-724 [005] … 501.266237: rtos_queue_send_from_isr_failed: tstamp:15920774984 queue:0x0b4af718
kworker/5:1-724 [005] … 501.266238: rtos_queue_send_from_isr_failed: tstamp:15920775089 queue:0x0b4b04d8
kworker/5:1-724 [005] … 501.266239: rtos_queue_send_from_isr_failed: tstamp:15920775193 queue:0x0b4b1298
kworker/5:1-724 [005] … 501.266239: rtos_queue_send_from_isr_failed: tstamp:15920775296 queue:0x0b4b2058
kworker/5:1-724 [005] … 501.266241: rtos_queue_send_failed: tstamp:15920775772 queue:0x0b4a7698
kworker/5:1-724 [005] … 501.434249: rtos_queue_peek_from_isr_failed: tstamp:15925764865 queue:0x0b4b4940
CaptureSchedule-8961 [004] … 501.443737: tegra_channel_open: vi-output, imx290 2-001a
CaptureSchedule-8961 [004] … 501.443747: tegra_channel_set_power: imx290 2-001a : 0x1
CaptureSchedule-8961 [004] … 501.443754: camera_common_s_power: status : 0x1
CaptureSchedule-8961 [004] … 501.467247: tegra_channel_set_power: 150c0000.nvcsi–1 : 0x1
CaptureSchedule-8961 [004] … 501.467251: csi_s_power: enable : 0x1
CaptureSchedule-8961 [004] … 501.470647: tegra_channel_set_stream: enable : 0x1
CaptureSchedule-8961 [004] … 501.471915: tegra_channel_set_stream: 150c0000.nvcsi–1 : 0x1
CaptureSchedule-8961 [004] … 501.471918: csi_s_stream: enable : 0x1
CaptureSchedule-8961 [004] … 501.471919: tegra_channel_set_stream: imx290 2-001a : 0x1
kworker/5:1-724 [005] … 501.490256: rtos_queue_send_from_isr_failed: tstamp:15926793660 queue:0x0b4a7698
kworker/5:1-724 [005] … 501.490259: rtos_queue_send_from_isr_failed: tstamp:15926793777 queue:0x0b4ab1a8
kworker/5:1-724 [005] … 501.490260: rtos_queue_send_from_isr_failed: tstamp:15926793883 queue:0x0b4acdd8
kworker/5:1-724 [005] … 501.490261: rtos_queue_send_from_isr_failed: tstamp:15926794001 queue:0x0b4ae958
kworker/5:1-724 [005] … 501.490261: rtos_queue_send_from_isr_failed: tstamp:15926794106 queue:0x0b4af718
kworker/5:1-724 [005] … 501.490262: rtos_queue_send_from_isr_failed: tstamp:15926794210 queue:0x0b4b04d8
kworker/5:1-724 [005] … 501.490262: rtos_queue_send_from_isr_failed: tstamp:15926794313 queue:0x0b4b1298
kworker/5:1-724 [005] … 501.490263: rtos_queue_send_from_isr_failed: tstamp:15926794417 queue:0x0b4b2058
kworker/5:1-724 [005] … 501.490264: rtos_queue_send_failed: tstamp:15926794878 queue:0x0b4a7698
kworker/5:1-724 [005] … 501.490265: rtos_queue_send_from_isr_failed: tstamp:15927634719 queue:0x0b4a7698
kworker/5:1-724 [005] … 501.490266: rtos_queue_send_from_isr_failed: tstamp:15927634826 queue:0x0b4ab1a8
kworker/5:1-724 [005] … 501.490266: rtos_queue_send_from_isr_failed: tstamp:15927634933 queue:0x0b4acdd8
kworker/5:1-724 [005] … 501.490267: rtos_queue_send_from_isr_failed: tstamp:15927635039 queue:0x0b4ae958
kworker/5:1-724 [005] … 501.490268: rtos_queue_send_from_isr_failed: tstamp:15927635144 queue:0x0b4af718
kworker/5:1-724 [005] … 501.490268: rtos_queue_send_from_isr_failed: tstamp:15927635248 queue:0x0b4b04d8
kworker/5:1-724 [005] … 501.490269: rtos_queue_send_from_isr_failed: tstamp:15927635353 queue:0x0b4b1298
kworker/5:1-724 [005] … 501.490269: rtos_queue_send_from_isr_failed: tstamp:15927635458 queue:0x0b4b2058
kworker/5:1-724 [005] … 501.490270: rtos_queue_send_failed: tstamp:15927635913 queue:0x0b4a7698
kworker/5:1-724 [005] … 501.602358: rtos_queue_peek_from_isr_failed: tstamp:15930764904 queue:0x0b4b4940
kworker/5:1-724 [005] … 501.770323: rtos_queue_peek_from_isr_failed: tstamp:15935764902 queue:0x0b4b4940
kworker/5:1-724 [005] … 501.938352: rtos_queue_peek_from_isr_failed: tstamp:15940764905 queue:0x0b4b4940
kworker/5:1-724 [005] … 502.050432: rtos_queue_peek_from_isr_failed: tstamp:15945764913 queue:0x0b4b4940
kworker/5:1-724 [005] … 502.106325: rtos_queue_send_from_isr_failed: tstamp:15946375525 queue:0x0b4a7698
kworker/5:1-724 [005] … 502.106334: rtos_queue_send_from_isr_failed: tstamp:15946375672 queue:0x0b4ab1a8
kworker/5:1-724 [005] … 502.106337: rtos_queue_send_from_isr_failed: tstamp:15946375814 queue:0x0b4acdd8
kworker/5:1-724 [005] … 502.106339: rtos_queue_send_from_isr_failed: tstamp:15946375954 queue:0x0b4ae958
kworker/5:1-724 [005] … 502.106342: rtos_queue_send_from_isr_failed: tstamp:15946376094 queue:0x0b4af718
kworker/5:1-724 [005] … 502.106344: rtos_queue_send_from_isr_failed: tstamp:15946376231 queue:0x0b4b04d8
kworker/5:1-724 [005] … 502.106347: rtos_queue_send_from_isr_failed: tstamp:15946376369 queue:0x0b4b1298
kworker/5:1-724 [005] … 502.106349: rtos_queue_send_from_isr_failed: tstamp:15946376512 queue:0x0b4b2058
kworker/5:1-724 [005] … 502.106354: rtos_queue_send_failed: tstamp:15946377983 queue:0x0b4a7698
kworker/5:1-724 [005] … 502.218331: rtos_queue_peek_from_isr_failed: tstamp:15950764921 queue:0x0b4b4940
kworker/5:1-724 [005] … 502.386308: rtos_queue_peek_from_isr_failed: tstamp:15955764934 queue:0x0b4b4940
dtsi:
host1x {
vi@15700000 {
num-channels = <1>;
status=“okay”;
ports {
#address-cells = <1>;
#size-cells = <0>;
status=“okay”;
port@0 {
status=“okay”;
reg = <0>;
imx290_vi_in: endpoint {
status=“okay”;
port-index = <2>;
bus-width = <2>;
remote-endpoint = <&imx290_csi_out>;
};}; }; nvcsi@150c0000 { status="okay"; num-channels = <1>; #address-cells = <1>; #size-cells = <0>; channel@0 { reg = <0>; ports { status="okay"; #address-cells = <1>; #size-cells = <0>; port@0 { reg = <0>; status="okay"; imx290_csi_in: endpoint@0 { port-index = <2>; bus-width = <2>; remote-endpoint = <&imx290_out>; status="okay"; }; }; port@1 { reg = <1>; status="okay"; imx290_csi_out: endpoint@1 { remote-endpoint = <&imx290_vi_in>; status="okay"; }; }; }; }; };};
i2c@3180000 {
status=“okay”;
imx290_c@1a {
status=“okay”;
compatible = “nvidia,imx290”;
reg = <0x1a>;
devnode = “video0”;
physical_w = “5.62”;
physical_h = “3.18”;
sensor_model =“imx290”;
delayed_gain = “true”;
use_sensor_mode_id = “true”;
opt_ctrl_i2c_addr = <0x65>;
mode0 {
mclk_khz = “37125”;
num_lanes = “2”;
tegra_sinterface = “serial_c”;
phy_mode = “DPHY”;
discontinuous_clk = “yes”;
dpcm_enable = “false”;
cil_settletime = “0”;
active_w = “1920”;
active_h = “1080”;
mode_type = “bayer”;
pixel_phase = “rggb”;
csi_pixel_bit_depth = “12”;
readout_orientation = “0”;
line_length = “4400”;
inherent_gain = “1”;
mclk_multiplier = “10”;
pix_clk_hz = “89100000”;
gain_factor = “10”;
min_gain_val = “1”;
max_gain_val = “720”;
step_gain_val = “3”;
default_gain = “10”;
min_hdr_ratio = “1”;
max_hdr_ratio = “1”;
framerate_factor = “1”;
min_framerate = “30”;
max_framerate = “30”;
step_framerate = “10”;
default_framerate = “30”;
exposure_factor = “1000000”;
min_exp_time = “30”;
max_exp_time = “33700”;
step_exp_time = “1”;
default_exp_time = “15000”;
embedded_metadata_height = “1”;
ports {
#size-cells = <0>;
status=“okay”;
port@0 {
reg = <0>;
status=“okay”;
imx290_out: endpoint {
status=“okay”;
port-index = <2>;
bus-width = <2>;
remote-endpoint = <&imx290_csi_in>;
};e3326_lens_imx290@IMX290 {
status=“okay”;
min_focus_distance = “0.0”;
hyper_focal = “0.0”;
focal_length = “2.67”;
f_number = “2.0”;
aperture = “2.0”;
};tegra-camera-platform {
compatible = “nvidia, tegra-camera-platform”;
num_csi_lanes = <2>;
max_lane_speed = <1500000>;
min_bits_per_pixel = <10>;
vi_peak_byte_per_pixel = <2>;
vi_bw_margin_pct = <25>;
max_pixel_rate = <750000>;
isp_peak_byte_per_pixel = <2>;
isp_bw_margin_pct = <25>;
modules {
status=“okay”;
module0 {
badge = “e3326_top_IMX290”;
position = “top”;
orientation = “0”;
drivernode0 {
status=“okay”;
pcl_id = “v4l2_sensor”;
devname = “imx290 2-001a”;
proc-device-tree = “/proc/device-tree/i2c@3180000/imx290_c@1a”;
};drivernode1 {status=“okay”;
pcl_id = “v4l2_lens”;
proc-device-tree = “/proc/device-tree/e3326_lens_imx290@IMX290/”;
The commands I use to try to capture the image:
gst-launch-1.0 nvarguscamerasrc ! ‘video/x-raw(memory:NVMM), width=1920, height=1080, format=(string)NV12, framerate=(fraction)30/1’ ! nvoverlaysink -e
v4l2-ctl --set-fmt-video=width=1920,height=1080,pixelformat=RG12 --stream-mmap --stream-count=10 -d /dev/video0 --stream-to=video.raw
dmesg:
[ 26.986259] imx290 2-001a: imx290_power_on: power on
[ 27.034325] imx290 2-001a: imx290_set_mode: Mode properties index: 0
[ 27.807021] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 27.813546] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 28.026881] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 28.033337] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 28.246919] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 28.253377] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 28.466882] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 28.473336] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 28.687013] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 28.693484] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 28.906854] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 28.913336] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 29.126900] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 29.133368] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 29.346890] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 29.353347] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 29.566906] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 29.573360] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 29.786922] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 29.793394] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 30.006888] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 30.013381] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 30.226919] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 30.233434] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 30.446892] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 30.453348] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 30.667007] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 30.673569] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 30.886905] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 30.893417] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 31.106807] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 31.113179] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 31.326913] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 31.333360] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 31.546917] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 31.553421] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 31.766947] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 31.773458] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 31.823353] spmic-ldo0: disabling
[ 31.823664] spmic-ldo1: disabling
[ 31.823871] en-vdd-sd: disabling
[ 31.823883] vdd-usb0-5v: disabling
[ 31.823892] vdd-usb1-5v: disabling
[ 31.823904] vdd-3v3: disabling
[ 31.823913] en-vdd-vcm-2v8: disabling
[ 31.823923] vdd-sys-bl: disabling
[ 31.986927] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 31.993493] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 32.206921] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 32.213391] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 32.426902] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 32.433356] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 32.646889] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 32.653317] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 32.866916] tegra-vi4 15700000.vi: PXL_SOF syncpt timeout! err = -11
[ 32.873501] tegra-vi4 15700000.vi: tegra_channel_error_recovery: attempting to reset the capture channel
[ 32.923504] imx290 2-001a: imx290_power_off: power off
[ 78.991345] imx290 2-001a: imx290_open:
[ 78.992788] imx290 2-001a: imx290_power_on: power on
[ 79.020365] imx290 2-001a: imx290_power_off: power off
[ 79.424168] imx290 2-001a: imx290_power_on: power on
[ 79.447424] imx290 2-001a: imx290_power_off: power off
[ 79.450779] imx290 2-001a: imx290_power_on: power on
[ 79.474034] imx290 2-001a: imx290_power_off: power off
[ 79.485654] imx290 2-001a: imx290_power_on: power on
[ 79.508848] imx290 2-001a: imx290_power_off: power off
[ 79.509865] imx290 2-001a: imx290_power_on: power on
[ 79.533214] imx290 2-001a: imx290_power_off: power off
[ 79.534201] imx290 2-001a: imx290_power_on: power on
[ 79.557481] imx290 2-001a: imx290_power_off: power off
[ 79.870215] imx290 2-001a: imx290_power_on: power on
[ 79.893424] imx290 2-001a: imx290_set_frame_rate: val: 60 frame_length: 1125
[ 79.895742] imx290 2-001a: imx290_set_exposure: val: 16820, reg_shs1: 3
[ 79.897668] imx290 2-001a: imx290_set_mode: Mode properties index: 1
[ 80.252923] imx290 2-001a: imx290_set_gain: gain 0 val: 1
[ 80.253098] imx290 2-001a: imx290_set_exposure: val: 16820, reg_shs1: 3
[ 80.253520] imx290 2-001a: imx290_set_frame_rate: val: 60 frame_length: 1125
[ 80.467432] imx290 2-001a: imx290_set_gain: gain 5 val: 19
[ 80.484274] imx290 2-001a: imx290_set_gain: gain 0 val: 1
[ 80.484927] imx290 2-001a: imx290_set_gain: gain 5 val: 19
[ 81.998564] fence timeout on [ffffffc1ac670900] after 1500ms
[ 81.998571] name=[nvhost_sync:23], current value=24 waiting value=25
[ 81.998574] fence timeout on [ffffffc1ac670240] after 1500ms
[ 81.998578] name=[nvhost_sync:38], current value=0 waiting value=1
[ 81.998578] ---- mlocks ----
[ 81.998581] ---- mlocks ----
[ 81.998590] 8: locked by channel 1
[ 81.998592] 8: locked by channel 1[ 81.998607] ---- syncpts ----
[ 81.998609] ---- syncpts ----
[ 81.998619] id 5 (disp_d) min 245 max 245 refs 1 (previous client : )
[ 81.998622] id 6 (disp_e) min 1 max 1 refs 1 (previous client : )
[ 81.998625] id 7 (disp_f) min 1 max 1 refs 1 (previous client : )
[ 81.998629] id 8 (vblank1) min 4840 max -2 refs 1 (previous client : )
[ 81.998643] id 19 (gp10b_507) min 15090 max 15090 refs 1 (previous client : )
[ 81.998647] id 20 (gp10b_506) min 14 max 14 refs 1 (previous client : )
[ 81.998650] id 21 (gp10b_505) min 1268 max 1268 refs 1 (previous client : gp10b_505)
[ 81.998654] id 22 (15340000.vic_gst-launch-1.0_0) min 24 max 24 refs 1 (previous client : tegra-vi4)
[ 81.998657] id 23 (15600000.isp_nvargus-daemon_0) min 24 max 28 refs 4 (previous client : tegra-vi4)
[ 81.998660] id 24 (15600000.isp_nvargus-daemon_1) min 0 max 2 refs 4 (previous client : )
[ 81.998663] id 25 (15600000.isp_nvargus-daemon_2) min 0 max 2 refs 4 (previous client : )
[ 81.998668] id 28 (15600000.isp_nvargus-daemon_3) min 0 max 2 refs 4 (previous client : )
[ 81.998672] id 29 (15600000.isp_nvargus-daemon_4) min 15 max 26 refs 9 (previous client : )
[ 81.998675] id 30 (15600000.isp_nvargus-daemon_5) min 0 max 2 refs 4 (previous client : )
[ 81.998679] id 32 (gp10b_503) min 56 max 56 refs 1 (previous client : )
[ 81.998686] id 36 (15700000.vi_0) min 14 max 14 refs 1 (previous client : 15700000.vi_0)
[ 81.998689] id 37 (15700000.vi_0) min 1 max 2 refs 4 (previous client : 15700000.vi_0)
[ 81.998692] id 38 (15700000.vi_1) min 0 max 2 refs 4 (previous client : 15700000.vi_1)
[ 81.998696] id 39 (15700000.vi_2) min 0 max 2 refs 4 (previous client : 15700000.vi_2)
[ 81.998699] id 40 (150c0000.nvcsi_0) min 26 max 26 refs 1 (previous client : 150c0000.nvcsi_0)
[ 81.998704] id 43 (gp10b_499) min 6 max 6 refs 1 (previous client : )
[ 81.998708] id 44 (gp10b_498) min 8 max 8 refs 1 (previous client : )
[ 81.998711] id 45 (gp10b_497) min 6 max 6 refs 1 (previous client : )
[ 81.998714] id 46 (gp10b_496) min 6 max 6 refs 1 (previous client : )
[ 81.998717] id 47 (gp10b_495) min 6 max 6 refs 1 (previous client : )
[ 81.998720] id 48 (gp10b_494) min 6 max 6 refs 1 (previous client : )[ 81.999239] ---- channels ----
[ 81.999246] id 5 (disp_d) min 245 max 245 refs 1 (previous client : )
[ 81.999249] id 6 (disp_e) min 1 max 1 refs 1 (previous client : )
[ 81.999251]
channel 2 - 15820000.se[ 81.999253] id 7 (disp_f) min 1 max 1 refs 1 (previous client : )
[ 81.999253] NvHost basic channel registers:
[ 81.999256] CMDFIFO_STAT_0: 00002040
[ 81.999257] id 8 (vblank1) min 4840 max -2 refs 1 (previous client : )
[ 81.999259] CMDFIFO_RDATA_0: 02000504
[ 81.999264] CMDP_OFFSET_0: 00000000
[ 81.999267] CMDP_CLASS_0: 00000000
[ 81.999269] CHANNELSTAT_0: 00000000
[ 81.999270] id 19 (gp10b_507) min 15090 max 15090 refs 1 (previous client : )
[ 81.999271] The CDMA sync queue is empty.
[ 81.999272] id 20 (gp10b_506) min 14 max 14 refs 1 (previous client : )[ 81.999276] id 21 (gp10b_505) min 1268 max 1268 refs 1 (previous client : gp10b_505)
[ 81.999276]
channel 3 - 15830000.se[ 81.999277] NvHost basic channel registers:
[ 81.999279] id 22 (15340000.vic_gst-launch-1.0_0) min 24 max 24 refs 1 (previous client : tegra-vi4)
[ 81.999280] CMDFIFO_STAT_0: 00002040
[ 81.999282] CMDFIFO_RDATA_0: 00280000
[ 81.999283] id 23 (15600000.isp_nvargus-daemon_0) min 24 max 28 refs 4 (previous client : tegra-vi4)
[ 81.999286] id 24 (15600000.isp_nvargus-daemon_1) min 0 max 2 refs 4 (previous client : )
[ 81.999286] CMDP_OFFSET_0: 00000000
[ 81.999288] CMDP_CLASS_0: 00000000
[ 81.999289] id 25 (15600000.isp_nvargus-daemon_2) min 0 max 2 refs 4 (previous client : )
[ 81.999291] CHANNELSTAT_0: 00000000
[ 81.999292] The CDMA sync queue is empty.[ 81.999294] id 28 (15600000.isp_nvargus-daemon_3) min 0 max 2 refs 4 (previous client : )
[ 81.999297] id 29 (15600000.isp_nvargus-daemon_4) min 15 max 26 refs 9 (previous client : )
[ 81.999297]
channel 4 - 15840000.se[ 81.999298] NvHost basic channel registers:
[ 81.999300] id 30 (15600000.isp_nvargus-daemon_5) min 0 max 2 refs 4 (previous client : )
[ 81.999300] CMDFIFO_STAT_0: 00002040
[ 81.999302] CMDFIFO_RDATA_0: 00002040
[ 81.999304] id 32 (gp10b_503) min 56 max 56 refs 1 (previous client : )
[ 81.999306] CMDP_OFFSET_0: 00000000
[ 81.999308] CMDP_CLASS_0: 00000000
[ 81.999310] id 36 (15700000.vi_0) min 14 max 14 refs 1 (previous client : 15700000.vi_0)
[ 81.999311] CHANNELSTAT_0: 00000000
[ 81.999312] The CDMA sync queue is empty.[ 81.999313] id 37 (15700000.vi_0) min 1 max 2 refs 4 (previous client : 15700000.vi_0)
[ 81.999316] id 38 (15700000.vi_1) min 0 max 2 refs 4 (previous client : 15700000.vi_1)
[ 81.999316]
channel 1 - 15600000.isp[ 81.999317] NvHost basic channel registers:
[ 81.999319] id 39 (15700000.vi_2) min 0 max 2 refs 4 (previous client : 15700000.vi_2)
[ 81.999320] CMDFIFO_STAT_0: 00004000
[ 81.999322] CMDFIFO_RDATA_0: 004e0041
[ 81.999323] id 40 (150c0000.nvcsi_0) min 26 max 26 refs 1 (previous client : 150c0000.nvcsi_0)
[ 81.999326] CMDP_OFFSET_0: 00000050
[ 81.999328] id 43 (gp10b_499) min 6 max 6 refs 1 (previous client : )
[ 81.999328] CMDP_CLASS_0: 00000001
[ 81.999330] CHANNELSTAT_0: 00000000
[ 81.999331] id 44 (gp10b_498) min 8 max 8 refs 1 (previous client : )
[ 81.999334] id 45 (gp10b_497) min 6 max 6 refs 1 (previous client : )
[ 81.999335]
ffffffc1e41ef400: JOB, syncpt_id=23, syncpt_val=26, first_get=00000628, timeout=10000, num_slots=19
[ 81.999337] id 46 (gp10b_496) min 6 max 6 refs 1 (previous client : )
[ 81.999340] id 47 (gp10b_495) min 6 max 6 refs 1 (previous client : )
[ 81.999343] id 48 (gp10b_494) min 6 max 6 refs 1 (previous client : )
[ 81.999343] GATHER at ffd60000+3c20, 12 words
[ 81.999345] 20000001
[ 81.999347] 00006417
[ 81.999348] 20000001
[ 81.999350] 00006818
[ 81.999351] 20000001
[ 81.999353] 00006c19
[ 81.999354] 20000001
[ 81.999356] 00007c1c
[ 81.999357] 20000001
[ 81.999358] 0000741e
[ 81.999360] 200c0001
[ 81.999361] 00000005[ 81.999366] GATHER at ffd60000+3c50, 2 words
[ 81.999367] 20000001
[ 81.999369] 0000001d[ 81.999376]
channel 5 - 15700000.vi[ 81.999377] NvHost basic channel registers:
[ 81.999379] CMDFIFO_STAT_0: 0000001b
[ 81.999382] CMDFIFO_RDATA_0: 304e0005
[ 81.999386] CMDP_OFFSET_0: 00000050
[ 81.999388] CMDP_CLASS_0: 00000001
[ 81.999390] CHANNELSTAT_0: 00000000
[ 81.999394]
ffffffc1b03c1800: JOB, syncpt_id=39, syncpt_val=1, first_get=00000000, timeout=10000, num_slots=7
[ 81.999398] GATHER at ffd50000+0000, 6 words
[ 81.999399] 304e0005
[ 81.999401] 0000000f
[ 81.999402] 0000001d
[ 81.999404] 304e0005
[ 81.999405] 00000000
[ 81.999407] 00000026[ 81.999410] GATHER at ffd50000+0018, 29 words
[ 81.999411] 90000002
[ 81.999413] a0004008
[ 81.999415] 00013f1f
[ 81.999416] 00000b3f
[ 81.999417] 9000000c
[ 81.999419] a000400c
[ 81.999420] 00000780
[ 81.999422] 00000438
[ 81.999423] 00000001
[ 81.999425] 00000001
[ 81.999426] 00000000
[ 81.999427] 00000000
[ 81.999429] 00000000
[ 81.999430] 00000000
[ 81.999432] 00000000
[ 81.999433] 00000000
[ 81.999434] 00000780
[ 81.999436] 00000438
[ 81.999437] 90000002
[ 81.999439] a0004018
[ 81.999440] 007f0000
[ 81.999442] 00000104
[ 81.999443] 90000002
[ 81.999444] a0004021
[ 81.999446] 00000000
[ 81.999447] 00000000
[ 81.999449] 90000001
[ 81.999450] a0004045
[ 81.999451] 0003d5ea[ 81.999455] GATHER at ffd50000+008c, 26 words
[ 81.999456] 90000001
[ 81.999458] a0000401
[ 81.999459] 00000000
[ 81.999460] 90000001
[ 81.999462] a000404d
[ 81.999463] 00000001
[ 81.999464] 90000001
[ 81.999466] a0004020
[ 81.999467] 00000000
[ 81.999469] 90000003
[ 81.999470] a0004042
[ 81.999472] ffe3f000
[ 81.999473] 0000001f
[ 81.999474] 00000001
[ 81.999476] 90000001
[ 81.999477] a0004048
[ 81.999479] 00000000
[ 81.999480] 90000001
[ 81.999482] a000400a
[ 81.999483] 00000000
[ 81.999485] 90000001
[ 81.999486] a0004001
[ 81.999487] 00000001
[ 81.999489] 90000001
[ 81.999490] a0004007
[ 81.999492] 00000003[ 81.999495] GATHER at ffd50000+00f4, 2 words
[ 81.999496] 20000001
[ 81.999498] 00000025[ 81.999502]
---- host general irq ----[ 81.999505] sync_intc0mask = 0x00000001
[ 81.999507] sync_intmask = 0x50000003
[ 81.999509]
---- host syncpt irq mask ----[ 81.999510]
---- host syncpt irq status ----[ 81.999513] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 81.999516] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 81.999518] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 81.999521] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 81.999523] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 81.999525] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 81.999528] syncpt_thresh_cpu0_int_status(6) = 0x00000000
[ 81.999530] syncpt_thresh_cpu0_int_status(7) = 0x00000000
[ 81.999533] syncpt_thresh_cpu0_int_status(8) = 0x00000000
[ 81.999535] syncpt_thresh_cpu0_int_status(9) = 0x00000000
[ 81.999537] syncpt_thresh_cpu0_int_status(10) = 0x00000000
[ 81.999540] syncpt_thresh_cpu0_int_status(11) = 0x00000000
[ 81.999542] syncpt_thresh_cpu0_int_status(12) = 0x00000000
[ 81.999545] syncpt_thresh_cpu0_int_status(13) = 0x00000000
[ 81.999547] syncpt_thresh_cpu0_int_status(14) = 0x00000000
[ 81.999549] syncpt_thresh_cpu0_int_status(15) = 0x00000000
[ 81.999552] syncpt_thresh_cpu0_int_status(16) = 0x00000000
[ 81.999554] syncpt_thresh_cpu0_int_status(17) = 0x00000000[ 81.999863] ---- channels ----
[ 81.999869]
channel 2 - 15820000.se[ 81.999871] NvHost basic channel registers:
[ 81.999874] CMDFIFO_STAT_0: 00002040
[ 81.999876] CMDFIFO_RDATA_0: 02000504
[ 81.999880] CMDP_OFFSET_0: 00000000
[ 81.999882] CMDP_CLASS_0: 00000000
[ 81.999885] CHANNELSTAT_0: 00000000
[ 81.999886] The CDMA sync queue is empty.[ 81.999890]
channel 3 - 15830000.se[ 81.999891] NvHost basic channel registers:
[ 81.999894] CMDFIFO_STAT_0: 00002040
[ 81.999896] CMDFIFO_RDATA_0: 00280000
[ 81.999900] CMDP_OFFSET_0: 00000000
[ 81.999902] CMDP_CLASS_0: 00000000
[ 81.999904] CHANNELSTAT_0: 00000000
[ 81.999905] The CDMA sync queue is empty.[ 81.999909]
channel 4 - 15840000.se[ 81.999910] NvHost basic channel registers:
[ 81.999913] CMDFIFO_STAT_0: 00002040
[ 81.999915] CMDFIFO_RDATA_0: 00002040
[ 81.999918] CMDP_OFFSET_0: 00000000
[ 81.999921] CMDP_CLASS_0: 00000000
[ 81.999923] CHANNELSTAT_0: 00000000
[ 81.999924] The CDMA sync queue is empty.[ 81.999927]
channel 1 - 15600000.isp[ 81.999929] NvHost basic channel registers:
[ 81.999931] CMDFIFO_STAT_0: 00004000
[ 81.999934] CMDFIFO_RDATA_0: 004e0041
[ 81.999937] CMDP_OFFSET_0: 00000050
[ 81.999939] CMDP_CLASS_0: 00000001
[ 81.999942] CHANNELSTAT_0: 00000000
[ 81.999945]
[ 81.999948] GATHER at ffd60000+3c20, 12 words
[ 81.999949] 20000001
[ 81.999951] 00006417
[ 81.999952] 20000001
[ 81.999954] 00006818
[ 81.999956] 20000001
[ 81.999957] 00006c19
[ 81.999958] 20000001
[ 81.999960] 00007c1c
[ 81.999961] 20000001
[ 81.999963] 0000741e
[ 81.999964] 200c0001
[ 81.999965] 00000005[ 81.999969] GATHER at ffd60000+3c50, 2 words
[ 81.999970] 20000001
[ 81.999972] 0000001d[ 81.999977]
channel 5 - 15700000.vi[ 81.999978] NvHost basic channel registers:
[ 81.999981] CMDFIFO_STAT_0: 0000001b
[ 81.999983] CMDFIFO_RDATA_0: 304e0005
[ 81.999987] CMDP_OFFSET_0: 00000050
[ 81.999989] CMDP_CLASS_0: 00000001
[ 81.999991] CHANNELSTAT_0: 00000000
[ 81.999994]
[ 81.999997] GATHER at ffd50000+0000, 6 words
[ 81.999998] 304e0005
[ 82.000000] 0000000f
[ 82.000001] 0000001d
[ 82.000003] 304e0005
[ 82.000004] 00000000
[ 82.000005] 00000026[ 82.000009] GATHER at ffd50000+0018, 29 words
[ 82.000010] 90000002
[ 82.000011] a0004008
[ 82.000013] 00013f1f
[ 82.000014] 00000b3f
[ 82.000016] 9000000c
[ 82.000017] a000400c
[ 82.000018] 00000780
[ 82.000020] 00000438
[ 82.000021] 00000001
[ 82.000022] 00000001
[ 82.000024] 00000000
[ 82.000025] 00000000
[ 82.000027] 00000000
[ 82.000028] 00000000
[ 82.000029] 00000000
[ 82.000031] 00000000
[ 82.000032] 00000780
[ 82.000033] 00000438
[ 82.000035] 90000002
[ 82.000036] a0004018
[ 82.000038] 007f0000
[ 82.000039] 00000104
[ 82.000040] 90000002
[ 82.000042] a0004021
[ 82.000043] 00000000
[ 82.000044] 00000000
[ 82.000046] 90000001
[ 82.000047] a0004045
[ 82.000049] 0003d5ea[ 82.000052] GATHER at ffd50000+008c, 26 words
[ 82.000053] 90000001
[ 82.000055] a0000401
[ 82.000056] 00000000
[ 82.000057] 90000001
[ 82.000059] a000404d
[ 82.000060] 00000001
[ 82.000061] 90000001
[ 82.000063] a0004020
[ 82.000064] 00000000
[ 82.000065] 90000003
[ 82.000067] a0004042
[ 82.000068] ffe3f000
[ 82.000070] 0000001f
[ 82.000071] 00000001
[ 82.000072] 90000001
[ 82.000074] a0004048
[ 82.000075] 00000000
[ 82.000076] 90000001
[ 82.000078] a000400a
[ 82.000079] 00000000
[ 82.000080] 90000001
[ 82.000082] a0004001
[ 82.000083] 00000001
[ 82.000085] 90000001
[ 82.000086] a0004007
[ 82.000087] 00000003[ 82.000090] GATHER at ffd50000+00f4, 2 words
[ 82.000092] 20000001
[ 82.000093] 00000025[ 82.000098]
---- host general irq ----[ 82.000100] sync_intc0mask = 0x00000001
[ 82.000103] sync_intmask = 0x50000003
[ 82.000104]
---- host syncpt irq mask ----[ 82.000105]
---- host syncpt irq status ----[ 82.000108] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 82.000111] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 82.000113] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 82.000116] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 82.000118] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 82.000121] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 82.000123] syncpt_thresh_cpu0_int_status(6) = 0x00000000
[ 82.000125] syncpt_thresh_cpu0_int_status(7) = 0x00000000
[ 82.000128] syncpt_thresh_cpu0_int_status(8) = 0x00000000
[ 82.000130] syncpt_thresh_cpu0_int_status(9) = 0x00000000
[ 82.000133] syncpt_thresh_cpu0_int_status(10) = 0x00000000
[ 82.000135] syncpt_thresh_cpu0_int_status(11) = 0x00000000
[ 82.000138] syncpt_thresh_cpu0_int_status(12) = 0x00000000
[ 82.000140] syncpt_thresh_cpu0_int_status(13) = 0x00000000
[ 82.000142] syncpt_thresh_cpu0_int_status(14) = 0x00000000
[ 82.000145] syncpt_thresh_cpu0_int_status(15) = 0x00000000
[ 82.000147] syncpt_thresh_cpu0_int_status(16) = 0x00000000
[ 82.000150] syncpt_thresh_cpu0_int_status(17) = 0x00000000
[ 82.007026] fence timeout on [ffffffc1ac6706c0] after 1500ms
[ 82.007033] name=[nvhost_sync:28], current value=0 waiting value=1
[ 82.007037] ---- mlocks ----
[ 82.007048] 8: locked by channel 1[ 82.007066] ---- syncpts ----
[ 82.007077] id 5 (disp_d) min 245 max 245 refs 1 (previous client : )
[ 82.007080] id 6 (disp_e) min 1 max 1 refs 1 (previous client : )
[ 82.007084] id 7 (disp_f) min 1 max 1 refs 1 (previous client : )
[ 82.007087] id 8 (vblank1) min 4841 max -2 refs 1 (previous client : )
[ 82.007101] id 19 (gp10b_507) min 15090 max 15090 refs 1 (previous client : )
[ 82.007105] id 20 (gp10b_506) min 14 max 14 refs 1 (previous client : )
[ 82.007108] id 21 (gp10b_505) min 1268 max 1268 refs 1 (previous client : gp10b_505)
[ 82.007112] id 22 (15340000.vic_gst-launch-1.0_0) min 24 max 24 refs 1 (previous client : tegra-vi4)
[ 82.007115] id 23 (15600000.isp_nvargus-daemon_0) min 24 max 28 refs 4 (previous client : tegra-vi4)
[ 82.007118] id 24 (15600000.isp_nvargus-daemon_1) min 0 max 2 refs 4 (previous client : )
[ 82.007122] id 25 (15600000.isp_nvargus-daemon_2) min 0 max 2 refs 4 (previous client : )
[ 82.007127] id 28 (15600000.isp_nvargus-daemon_3) min 0 max 2 refs 4 (previous client : )
[ 82.007130] id 29 (15600000.isp_nvargus-daemon_4) min 15 max 26 refs 9 (previous client : )
[ 82.007133] id 30 (15600000.isp_nvargus-daemon_5) min 0 max 2 refs 4 (previous client : )
[ 82.007138] id 32 (gp10b_503) min 56 max 56 refs 1 (previous client : )
[ 82.007144] id 36 (15700000.vi_0) min 14 max 14 refs 1 (previous client : 15700000.vi_0)
[ 82.007147] id 37 (15700000.vi_0) min 1 max 2 refs 4 (previous client : 15700000.vi_0)
[ 82.007151] id 38 (15700000.vi_1) min 0 max 2 refs 4 (previous client : 15700000.vi_1)
[ 82.007154] id 39 (15700000.vi_2) min 0 max 2 refs 4 (previous client : 15700000.vi_2)
[ 82.007157] id 40 (150c0000.nvcsi_0) min 26 max 26 refs 1 (previous client : 150c0000.nvcsi_0)
[ 82.007162] id 43 (gp10b_499) min 6 max 6 refs 1 (previous client : )
[ 82.007165] id 44 (gp10b_498) min 8 max 8 refs 1 (previous client : )
[ 82.007169] id 45 (gp10b_497) min 6 max 6 refs 1 (previous client : )
[ 82.007172] id 46 (gp10b_496) min 6 max 6 refs 1 (previous client : )
[ 82.007175] id 47 (gp10b_495) min 6 max 6 refs 1 (previous client : )
[ 82.007178] id 48 (gp10b_494) min 6 max 6 refs 1 (previous client : )[ 82.007699] ---- channels ----
[ 82.007710]
channel 2 - 15820000.se[ 82.007712] NvHost basic channel registers:
[ 82.007715] CMDFIFO_STAT_0: 00002040
[ 82.007718] CMDFIFO_RDATA_0: 02000504
[ 82.007722] CMDP_OFFSET_0: 00000000
[ 82.007725] CMDP_CLASS_0: 00000000
[ 82.007727] CHANNELSTAT_0: 00000000
[ 82.007729] The CDMA sync queue is empty.[ 82.007733]
channel 3 - 15830000.se[ 82.007735] NvHost basic channel registers:
[ 82.007737] CMDFIFO_STAT_0: 00002040
[ 82.007740] CMDFIFO_RDATA_0: 00280000
[ 82.007744] CMDP_OFFSET_0: 00000000
[ 82.007746] CMDP_CLASS_0: 00000000
[ 82.007748] CHANNELSTAT_0: 00000000
[ 82.007750] The CDMA sync queue is empty.[ 82.007754]
channel 4 - 15840000.se[ 82.007755] NvHost basic channel registers:
[ 82.007758] CMDFIFO_STAT_0: 00002040
[ 82.007760] CMDFIFO_RDATA_0: 00002040
[ 82.007764] CMDP_OFFSET_0: 00000000
[ 82.007766] CMDP_CLASS_0: 00000000
[ 82.007768] CHANNELSTAT_0: 00000000
[ 82.007770] The CDMA sync queue is empty.[ 82.007773]
channel 1 - 15600000.isp[ 82.007775] NvHost basic channel registers:
[ 82.007777] CMDFIFO_STAT_0: 00004000
[ 82.007780] CMDFIFO_RDATA_0: 004e0041
[ 82.007783] CMDP_OFFSET_0: 00000050
[ 82.007785] CMDP_CLASS_0: 00000001
[ 82.007788] CHANNELSTAT_0: 00000000
[ 82.007792]
[ 82.007796] GATHER at ffd60000+3c20, 12 words
[ 82.007799] 20000001
[ 82.007800] 00006417
[ 82.007802] 20000001
[ 82.007804] 00006818
[ 82.007805] 20000001
[ 82.007806] 00006c19
[ 82.007808] 20000001
[ 82.007809] 00007c1c
[ 82.007811] 20000001
[ 82.007812] 0000741e
[ 82.007814] 200c0001
[ 82.007815] 00000005[ 82.007820] GATHER at ffd60000+3c50, 2 words
[ 82.007821] 20000001
[ 82.007823] 0000001d[ 82.007829]
channel 5 - 15700000.vi[ 82.007830] NvHost basic channel registers:
[ 82.007833] CMDFIFO_STAT_0: 0000001b
[ 82.007835] CMDFIFO_RDATA_0: 304e0005
[ 82.007839] CMDP_OFFSET_0: 00000050
[ 82.007841] CMDP_CLASS_0: 00000001
[ 82.007843] CHANNELSTAT_0: 00000000
[ 82.007847]
[ 82.007850] GATHER at ffd50000+0000, 6 words
[ 82.007851] 304e0005
[ 82.007853] 0000000f
[ 82.007854] 0000001d
[ 82.007856] 304e0005
[ 82.007857] 00000000
[ 82.007859] 00000026[ 82.007862] GATHER at ffd50000+0018, 29 words
[ 82.007864] 90000002
[ 82.007865] a0004008
[ 82.007866] 00013f1f
[ 82.007868] 00000b3f
[ 82.007869] 9000000c
[ 82.007871] a000400c
[ 82.007872] 00000780
[ 82.007874] 00000438
[ 82.007875] 00000001
[ 82.007877] 00000001
[ 82.007878] 00000000
[ 82.007879] 00000000
[ 82.007881] 00000000
[ 82.007882] 00000000
[ 82.007883] 00000000
[ 82.007885] 00000000
[ 82.007886] 00000780
[ 82.007888] 00000438
[ 82.007889] 90000002
[ 82.007891] a0004018
[ 82.007892] 007f0000
[ 82.007893] 00000104
[ 82.007895] 90000002
[ 82.007896] a0004021
[ 82.007898] 00000000
[ 82.007899] 00000000
[ 82.007901] 90000001
[ 82.007902] a0004045
[ 82.007903] 0003d5ea[ 82.007907] GATHER at ffd50000+008c, 26 words
[ 82.007908] 90000001
[ 82.007910] a0000401
[ 82.007911] 00000000
[ 82.007913] 90000001
[ 82.007914] a000404d
[ 82.007916] 00000001
[ 82.007917] 90000001
[ 82.007918] a0004020
[ 82.007920] 00000000
[ 82.007921] 90000003
[ 82.007923] a0004042
[ 82.007924] ffe3f000
[ 82.007925] 0000001f
[ 82.007927] 00000001
[ 82.007928] 90000001
[ 82.007930] a0004048
[ 82.007931] 00000000
[ 82.007932] 90000001
[ 82.007934] a000400a
[ 82.007935] 00000000
[ 82.007937] 90000001
[ 82.007938] a0004001
[ 82.007940] 00000001
[ 82.007941] 90000001
[ 82.007942] a0004007
[ 82.007944] 00000003[ 82.007947] GATHER at ffd50000+00f4, 2 words
[ 82.007948] 20000001
[ 82.007950] 00000025[ 82.007956]
---- host general irq ----[ 82.007958] sync_intc0mask = 0x00000001
[ 82.007960] sync_intmask = 0x50000003
[ 82.007962]
---- host syncpt irq mask ----[ 82.007963]
---- host syncpt irq status ----[ 82.007967] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 82.007970] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 82.007972] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 82.007975] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 82.007977] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 82.007980] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 82.007982] syncpt_thresh_cpu0_int_status(6) = 0x00000000
[ 82.007984] syncpt_thresh_cpu0_int_status(7) = 0x00000000
[ 82.007987] syncpt_thresh_cpu0_int_status(8) = 0x00000000
[ 82.007989] syncpt_thresh_cpu0_int_status(9) = 0x00000000
[ 82.007992] syncpt_thresh_cpu0_int_status(10) = 0x00000000
[ 82.007994] syncpt_thresh_cpu0_int_status(11) = 0x00000000
[ 82.007997] syncpt_thresh_cpu0_int_status(12) = 0x00000000
[ 82.007999] syncpt_thresh_cpu0_int_status(13) = 0x00000000
[ 82.008002] syncpt_thresh_cpu0_int_status(14) = 0x00000000
[ 82.008004] syncpt_thresh_cpu0_int_status(15) = 0x00000000
[ 82.008007] syncpt_thresh_cpu0_int_status(16) = 0x00000000
[ 82.008009] syncpt_thresh_cpu0_int_status(17) = 0x00000000
[ 86.606543] host1x 13e10000.host1x: CaptureSchedule: syncpoint id 29 (15600000.isp_nvargus-daemon_4) stuck waiting 18, timeout=-1
[ 86.618223] ---- syncpts ----
[ 86.618235] id 5 (disp_d) min 252 max 252 refs 1 (previous client : )
[ 86.618239] id 6 (disp_e) min 1 max 1 refs 1 (previous client : )
[ 86.618242] id 7 (disp_f) min 1 max 1 refs 1 (previous client : )
[ 86.618246] id 8 (vblank1) min 5117 max -2 refs 1 (previous client : )
[ 86.618259] id 19 (gp10b_507) min 15118 max 15118 refs 1 (previous client : )
[ 86.618262] id 20 (gp10b_506) min 14 max 14 refs 1 (previous client : )
[ 86.618266] id 21 (gp10b_505) min 1304 max 1304 refs 1 (previous client : gp10b_505)
[ 86.618269] id 22 (15340000.vic_gst-launch-1.0_0) min 24 max 24 refs 1 (previous client : tegra-vi4)
[ 86.618272] id 23 (15600000.isp_nvargus-daemon_0) min 24 max 28 refs 4 (previous client : tegra-vi4)
[ 86.618276] id 24 (15600000.isp_nvargus-daemon_1) min 0 max 2 refs 4 (previous client : )
[ 86.618279] id 25 (15600000.isp_nvargus-daemon_2) min 0 max 2 refs 4 (previous client : )
[ 86.618284] id 28 (15600000.isp_nvargus-daemon_3) min 0 max 2 refs 4 (previous client : )
[ 86.618287] id 29 (15600000.isp_nvargus-daemon_4) min 15 max 26 refs 9 (previous client : )
[ 86.618290] id 30 (15600000.isp_nvargus-daemon_5) min 0 max 2 refs 4 (previous client : )
[ 86.618295] id 32 (gp10b_503) min 56 max 56 refs 1 (previous client : )
[ 86.618301] id 36 (15700000.vi_0) min 14 max 14 refs 1 (previous client : 15700000.vi_0)
[ 86.618305] id 37 (15700000.vi_0) min 1 max 2 refs 4 (previous client : 15700000.vi_0)
[ 86.618308] id 38 (15700000.vi_1) min 0 max 2 refs 4 (previous client : 15700000.vi_1)
[ 86.618311] id 39 (15700000.vi_2) min 0 max 2 refs 4 (previous client : 15700000.vi_2)
[ 86.618315] id 40 (150c0000.nvcsi_0) min 26 max 26 refs 1 (previous client : 150c0000.nvcsi_0)
[ 86.618320] id 43 (gp10b_499) min 6 max 6 refs 1 (previous client : )
[ 86.618323] id 44 (gp10b_498) min 8 max 8 refs 1 (previous client : )
[ 86.618326] id 45 (gp10b_497) min 6 max 6 refs 1 (previous client : )
[ 86.618328] id 46 (gp10b_496) min 6 max 6 refs 1 (previous client : )
[ 86.618332] id 47 (gp10b_495) min 6 max 6 refs 1 (previous client : )
[ 86.618335] id 48 (gp10b_494) min 6 max 6 refs 1 (previous client : )[ 90.702626] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 39 (15700000.vi_2) clientid 11, HW thresh 0, done 1
[ 90.713387] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 38 (15700000.vi_1) clientid 11, HW thresh 0, done 1
[ 90.724114] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 37 (15700000.vi_0) clientid 11, HW thresh 1, done 1
[ 90.734823] ---- mlocks ----
[ 90.734843] 8: locked by channel 1[ 90.734869] ---- syncpts ----
[ 90.734889] id 5 (disp_d) min 259 max 259 refs 1 (previous client : )
[ 90.734898] id 6 (disp_e) min 1 max 1 refs 1 (previous client : )
[ 90.734907] id 7 (disp_f) min 1 max 1 refs 1 (previous client : )
[ 90.734916] id 8 (vblank1) min 5364 max -2 refs 1 (previous client : )
[ 90.734938] id 19 (gp10b_507) min 15146 max 15146 refs 1 (previous client : )
[ 90.734946] id 20 (gp10b_506) min 14 max 14 refs 1 (previous client : )
[ 90.734954] id 21 (gp10b_505) min 1338 max 1338 refs 1 (previous client : gp10b_505)
[ 90.734964] id 23 (15600000.isp_nvargus-daemon_0) min 24 max 28 refs 4 (previous client : tegra-vi4)
[ 90.734972] id 24 (15600000.isp_nvargus-daemon_1) min 0 max 2 refs 4 (previous client : )
[ 90.734980] id 25 (15600000.isp_nvargus-daemon_2) min 0 max 2 refs 4 (previous client : )
[ 90.734990] id 28 (15600000.isp_nvargus-daemon_3) min 0 max 2 refs 4 (previous client : )
[ 90.734998] id 29 (15600000.isp_nvargus-daemon_4) min 15 max 26 refs 9 (previous client : )
[ 90.735006] id 30 (15600000.isp_nvargus-daemon_5) min 0 max 2 refs 4 (previous client : )
[ 90.735016] id 32 (gp10b_503) min 56 max 56 refs 1 (previous client : )
[ 90.735027] id 36 (15700000.vi_0) min 14 max 14 refs 1 (previous client : 15700000.vi_0)
[ 90.735035] id 37 (15700000.vi_0) min 1 max 2 refs 4 (previous client : 15700000.vi_0)
[ 90.735042] id 38 (15700000.vi_1) min 0 max 2 refs 4 (previous client : 15700000.vi_1)
[ 90.735050] id 39 (15700000.vi_2) min 0 max 2 refs 4 (previous client : 15700000.vi_2)
[ 90.735058] id 40 (150c0000.nvcsi_0) min 26 max 26 refs 1 (previous client : 150c0000.nvcsi_0)
[ 90.735068] id 43 (gp10b_499) min 6 max 6 refs 1 (previous client : )
[ 90.735075] id 44 (gp10b_498) min 8 max 8 refs 1 (previous client : )
[ 90.735083] id 45 (gp10b_497) min 6 max 6 refs 1 (previous client : )
[ 90.735090] id 46 (gp10b_496) min 6 max 6 refs 1 (previous client : )
[ 90.735098] id 47 (gp10b_495) min 6 max 6 refs 1 (previous client : )
[ 90.735105] id 48 (gp10b_494) min 6 max 6 refs 1 (previous client : )[ 90.735729] ---- channels ----
[ 90.735754]
channel 2 - 15820000.se[ 90.735759] NvHost basic channel registers:
[ 90.735764] CMDFIFO_STAT_0: 00002040
[ 90.735770] CMDFIFO_RDATA_0: 02000504
[ 90.735777] CMDP_OFFSET_0: 00000000
[ 90.735782] CMDP_CLASS_0: 00000000
[ 90.735787] CHANNELSTAT_0: 00000000
[ 90.735791] The CDMA sync queue is empty.[ 90.735801]
channel 3 - 15830000.se[ 90.735804] NvHost basic channel registers:
[ 90.735809] CMDFIFO_STAT_0: 00002040
[ 90.735814] CMDFIFO_RDATA_0: 00280000
[ 90.735820] CMDP_OFFSET_0: 00000000
[ 90.735825] CMDP_CLASS_0: 00000000
[ 90.735829] CHANNELSTAT_0: 00000000
[ 90.735833] The CDMA sync queue is empty.[ 90.735842]
channel 4 - 15840000.se[ 90.735846] NvHost basic channel registers:
[ 90.735851] CMDFIFO_STAT_0: 00002040
[ 90.735855] CMDFIFO_RDATA_0: 00002040
[ 90.735862] CMDP_OFFSET_0: 00000000
[ 90.735866] CMDP_CLASS_0: 00000000
[ 90.735870] CHANNELSTAT_0: 00000000
[ 90.735874] The CDMA sync queue is empty.[ 90.735883]
channel 1 - 15600000.isp[ 90.735886] NvHost basic channel registers:
[ 90.735891] CMDFIFO_STAT_0: 00004000
[ 90.735895] CMDFIFO_RDATA_0: 004e0041
[ 90.735902] CMDP_OFFSET_0: 00000050
[ 90.735906] CMDP_CLASS_0: 00000001
[ 90.735910] CHANNELSTAT_0: 00000000
[ 90.735919]
[ 90.735929] GATHER at ffd60000+3c20, 12 words
[ 90.735933] 20000001
[ 90.735938] 00006417
[ 90.735942] 20000001
[ 90.735946] 00006818
[ 90.735949] 20000001
[ 90.735953] 00006c19
[ 90.735957] 20000001
[ 90.735960] 00007c1c
[ 90.735964] 20000001
[ 90.735967] 0000741e
[ 90.735971] 200c0001
[ 90.735974] 00000005[ 90.735984] GATHER at ffd60000+3c50, 2 words
[ 90.735988] 20000001
[ 90.735992] 0000001d[ 90.736008]
channel 5 - 15700000.vi[ 90.736011] NvHost basic channel registers:
[ 90.736016] CMDFIFO_STAT_0: 0000001b
[ 90.736020] CMDFIFO_RDATA_0: 304e0005
[ 90.736027] CMDP_OFFSET_0: 00000050
[ 90.736031] CMDP_CLASS_0: 00000001
[ 90.736035] CHANNELSTAT_0: 00000000
[ 90.736044]
[ 90.736051] GATHER at ffd50000+0000, 6 words
[ 90.736055] 304e0005
[ 90.736058] 0000000f
[ 90.736062] 0000001d
[ 90.736065] 304e0005
[ 90.736069] 00000000
[ 90.736072] 00000026[ 90.736081] GATHER at ffd50000+0018, 29 words
[ 90.736085] 90000002
[ 90.736088] a0004008
[ 90.736092] 00013f1f
[ 90.736095] 00000b3f
[ 90.736099] 9000000c
[ 90.736102] a000400c
[ 90.736106] 00000780
[ 90.736109] 00000438
[ 90.736113] 00000001
[ 90.736116] 00000001
[ 90.736120] 00000000
[ 90.736123] 00000000
[ 90.736126] 00000000
[ 90.736130] 00000000
[ 90.736133] 00000000
[ 90.736137] 00000000
[ 90.736140] 00000780
[ 90.736144] 00000438
[ 90.736147] 90000002
[ 90.736151] a0004018
[ 90.736154] 007f0000
[ 90.736158] 00000104
[ 90.736161] 90000002
[ 90.736165] a0004021
[ 90.736168] 00000000
[ 90.736172] 00000000
[ 90.736175] 90000001
[ 90.736179] a0004045
[ 90.736182] 0003d5ea[ 90.736190] GATHER at ffd50000+008c, 26 words
[ 90.736194] 90000001
[ 90.736197] a0000401
[ 90.736201] 00000000
[ 90.736204] 90000001
[ 90.736208] a000404d
[ 90.736211] 00000001
[ 90.736214] 90000001
[ 90.736218] a0004020
[ 90.736221] 00000000
[ 90.736225] 90000003
[ 90.736228] a0004042
[ 90.736232] ffe3f000
[ 90.736235] 0000001f
[ 90.736239] 00000001
[ 90.736242] 90000001
[ 90.736246] a0004048
[ 90.736249] 00000000
[ 90.736252] 90000001
[ 90.736256] a000400a
[ 90.736259] 00000000
[ 90.736263] 90000001
[ 90.736266] a0004001
[ 90.736269] 00000001
[ 90.736273] 90000001
[ 90.736276] a0004007
[ 90.736280] 00000003[ 90.736288] GATHER at ffd50000+00f4, 2 words
[ 90.736291] 20000001
[ 90.736295] 00000025[ 90.736307]
---- host general irq ----[ 90.736312] sync_intc0mask = 0x00000001
[ 90.736316] sync_intmask = 0x50000003
[ 90.736319]
---- host syncpt irq mask ----[ 90.736323]
---- host syncpt irq status ----[ 90.736330] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 90.736335] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 90.736340] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 90.736345] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 90.736349] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 90.736354] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 90.736359] syncpt_thresh_cpu0_int_status(6) = 0x00000000
[ 90.736363] syncpt_thresh_cpu0_int_status(7) = 0x00000000
[ 90.736368] syncpt_thresh_cpu0_int_status(8) = 0x00000000
[ 90.736373] syncpt_thresh_cpu0_int_status(9) = 0x00000000
[ 90.736378] syncpt_thresh_cpu0_int_status(10) = 0x00000000
[ 90.736383] syncpt_thresh_cpu0_int_status(11) = 0x00000000
[ 90.736388] syncpt_thresh_cpu0_int_status(12) = 0x00000000
[ 90.736392] syncpt_thresh_cpu0_int_status(13) = 0x00000000
[ 90.736397] syncpt_thresh_cpu0_int_status(14) = 0x00000000
[ 90.736402] syncpt_thresh_cpu0_int_status(15) = 0x00000000
[ 90.736407] syncpt_thresh_cpu0_int_status(16) = 0x00000000
[ 90.736412] syncpt_thresh_cpu0_int_status(17) = 0x00000000
[ 90.736482] tegra-vi4 15700000.vi: SYNCPT_ID 39
[ 90.736489] tegra-vi4 15700000.vi: SYNCPT_VAL 1
[ 90.736494] tegra-vi4 15700000.vi: FIRST_GET 0x0
[ 90.736500] tegra-vi4 15700000.vi: TIMEOUT 10000
[ 90.736505] tegra-vi4 15700000.vi: NUM_SLOTS 7
[ 90.736510] tegra-vi4 15700000.vi: NUM_HANDLES 2
[ 90.736643] tegra-vi4 15700000.vi: SYNCPT_ID 39
[ 90.736652] tegra-vi4 15700000.vi: SYNCPT_VAL 2
[ 90.736659] tegra-vi4 15700000.vi: FIRST_GET 0x38
[ 90.736665] tegra-vi4 15700000.vi: TIMEOUT 10000
[ 90.736674] tegra-vi4 15700000.vi: NUM_SLOTS 7
[ 90.736680] tegra-vi4 15700000.vi: NUM_HANDLES 2
[ 90.736797] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 23 (15600000.isp_nvargus-daemon_0) clientid 3, HW thresh 24, done 26
[ 90.748902] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 24 (15600000.isp_nvargus-daemon_1) clientid 3, HW thresh 0, done 1
[ 90.760814] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 25 (15600000.isp_nvargus-daemon_2) clientid 3, HW thresh 0, done 1
[ 90.772747] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 28 (15600000.isp_nvargus-daemon_3) clientid 3, HW thresh 0, done 1
[ 90.784685] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 30 (15600000.isp_nvargus-daemon_5) clientid 3, HW thresh 0, done 1
[ 90.796642] host1x 13e10000.host1x: cdma_handle_timeout: timeout: 29 (15600000.isp_nvargus-daemon_4) clientid 3, HW thresh 15, done 15
[ 90.808771] ---- mlocks ----
[ 90.808785] 8: locked by channel 1[ 90.808812] ---- syncpts ----
[ 90.808827] id 5 (disp_d) min 259 max 259 refs 1 (previous client : )
[ 90.808832] id 6 (disp_e) min 1 max 1 refs 1 (previous client : )
[ 90.808840] id 7 (disp_f) min 1 max 1 refs 1 (previous client : )
[ 90.808847] id 8 (vblank1) min 5369 max -2 refs 1 (previous client : )
[ 90.808863] id 19 (gp10b_507) min 15146 max 15146 refs 1 (previous client : )
[ 90.808866] id 20 (gp10b_506) min 14 max 14 refs 1 (previous client : )
[ 90.808871] id 21 (gp10b_505) min 1338 max 1338 refs 1 (previous client : gp10b_505)
[ 90.808876] id 23 (15600000.isp_nvargus-daemon_0) min 24 max 28 refs 4 (previous client : tegra-vi4)
[ 90.808879] id 24 (15600000.isp_nvargus-daemon_1) min 0 max 2 refs 4 (previous client : )
[ 90.808883] id 25 (15600000.isp_nvargus-daemon_2) min 0 max 2 refs 4 (previous client : )
[ 90.808889] id 28 (15600000.isp_nvargus-daemon_3) min 0 max 2 refs 4 (previous client : )
[ 90.808892] id 29 (15600000.isp_nvargus-daemon_4) min 15 max 26 refs 9 (previous client : )
[ 90.808896] id 30 (15600000.isp_nvargus-daemon_5) min 0 max 2 refs 4 (previous client : )
[ 90.808901] id 32 (gp10b_503) min 56 max 56 refs 1 (previous client : )
[ 90.808909] id 36 (15700000.vi_0) min 14 max 14 refs 1 (previous client : 15700000.vi_0)
[ 90.808913] id 37 (15700000.vi_0) min 2 max 2 refs 1 (previous client : 15700000.vi_0)
[ 90.808917] id 38 (15700000.vi_1) min 2 max 2 refs 1 (previous client : 15700000.vi_1)
[ 90.808921] id 39 (15700000.vi_2) min 2 max 2 refs 1 (previous client : 15700000.vi_2)
[ 90.808926] id 40 (150c0000.nvcsi_0) min 26 max 26 refs 1 (previous client : 150c0000.nvcsi_0)
[ 90.808932] id 43 (gp10b_499) min 6 max 6 refs 1 (previous client : )
[ 90.808935] id 44 (gp10b_498) min 8 max 8 refs 1 (previous client : )
[ 90.808938] id 45 (gp10b_497) min 6 max 6 refs 1 (previous client : )
[ 90.808941] id 46 (gp10b_496) min 6 max 6 refs 1 (previous client : )
[ 90.808945] id 47 (gp10b_495) min 6 max 6 refs 1 (previous client : )
[ 90.808949] id 48 (gp10b_494) min 6 max 6 refs 1 (previous client : )[ 90.809494] ---- channels ----
[ 90.809507]
channel 2 - 15820000.se[ 90.809509] NvHost basic channel registers:
[ 90.809512] CMDFIFO_STAT_0: 00002040
[ 90.809515] CMDFIFO_RDATA_0: 02000504
[ 90.809519] CMDP_OFFSET_0: 00000000
[ 90.809521] CMDP_CLASS_0: 00000000
[ 90.809524] CHANNELSTAT_0: 00000000
[ 90.809526] The CDMA sync queue is empty.[ 90.809530]
channel 3 - 15830000.se[ 90.809531] NvHost basic channel registers:
[ 90.809534] CMDFIFO_STAT_0: 00002040
[ 90.809537] CMDFIFO_RDATA_0: 00280000
[ 90.809540] CMDP_OFFSET_0: 00000000
[ 90.809543] CMDP_CLASS_0: 00000000
[ 90.809545] CHANNELSTAT_0: 00000000
[ 90.809547] The CDMA sync queue is empty.[ 90.809551]
channel 4 - 15840000.se[ 90.809553] NvHost basic channel registers:
[ 90.809555] CMDFIFO_STAT_0: 00002040
[ 90.809558] CMDFIFO_RDATA_0: 00002040
[ 90.809562] CMDP_OFFSET_0: 00000000
[ 90.809564] CMDP_CLASS_0: 00000000
[ 90.809567] CHANNELSTAT_0: 00000000
[ 90.809569] The CDMA sync queue is empty.[ 90.809573]
channel 1 - 15600000.isp[ 90.809574] NvHost basic channel registers:
[ 90.809577] CMDFIFO_STAT_0: 00004000
[ 90.809579] CMDFIFO_RDATA_0: 004e0041
[ 90.809583] CMDP_OFFSET_0: 00000050
[ 90.809585] CMDP_CLASS_0: 00000001
[ 90.809588] CHANNELSTAT_0: 00000000
[ 90.809592]
[ 90.809596] GATHER at ffd60000+3c20, 12 words
[ 90.809598] 20000001
[ 90.809600] 00006417
[ 90.809602] 20000001
[ 90.809604] 00006818
[ 90.809605] 20000001
[ 90.809607] 00006c19
[ 90.809609] 20000001
[ 90.809610] 00007c1c
[ 90.809612] 20000001
[ 90.809613] 0000741e
[ 90.809615] 200c0001
[ 90.809617] 00000005[ 90.809621] GATHER at ffd60000+3c50, 2 words
[ 90.809622] 20000001
[ 90.809624] 0000001d[ 90.809631]
---- host general irq ----[ 90.809633] sync_intc0mask = 0x00000001
[ 90.809636] sync_intmask = 0x50000003
[ 90.809637]
---- host syncpt irq mask ----[ 90.809639]
---- host syncpt irq status ----[ 90.809642] syncpt_thresh_cpu0_int_status(0) = 0x00000000
[ 90.809645] syncpt_thresh_cpu0_int_status(1) = 0x00000000
[ 90.809647] syncpt_thresh_cpu0_int_status(2) = 0x00000000
[ 90.809650] syncpt_thresh_cpu0_int_status(3) = 0x00000000
[ 90.809652] syncpt_thresh_cpu0_int_status(4) = 0x00000000
[ 90.809655] syncpt_thresh_cpu0_int_status(5) = 0x00000000
[ 90.809657] syncpt_thresh_cpu0_int_status(6) = 0x00000000
[ 90.809660] syncpt_thresh_cpu0_int_status(7) = 0x00000000
[ 90.809662] syncpt_thresh_cpu0_int_status(8) = 0x00000000
[ 90.809665] syncpt_thresh_cpu0_int_status(9) = 0x00000000
[ 90.809668] syncpt_thresh_cpu0_int_status(10) = 0x00000000
[ 90.809670] syncpt_thresh_cpu0_int_status(11) = 0x00000000
[ 90.809673] syncpt_thresh_cpu0_int_status(12) = 0x00000000
[ 90.809675] syncpt_thresh_cpu0_int_status(13) = 0x00000000
[ 90.809678] syncpt_thresh_cpu0_int_status(14) = 0x00000000
[ 90.809680] syncpt_thresh_cpu0_int_status(15) = 0x00000000
[ 90.809683] syncpt_thresh_cpu0_int_status(16) = 0x00000000
[ 90.809686] syncpt_thresh_cpu0_int_status(17) = 0x00000000
[ 90.830092] isp 15600000.isp: SYNCPT_ID 23
[ 90.830095] isp 15600000.isp: SYNCPT_VAL 26
[ 90.830098] isp 15600000.isp: FIRST_GET 0x628
[ 90.830100] isp 15600000.isp: TIMEOUT 10000
[ 90.830102] isp 15600000.isp: NUM_SLOTS 19
[ 90.830104] isp 15600000.isp: NUM_HANDLES 1
[ 90.830255] isp 15600000.isp: SYNCPT_ID 29
[ 90.830257] isp 15600000.isp: SYNCPT_VAL 17
[ 90.830259] isp 15600000.isp: FIRST_GET 0x6c0
[ 90.830261] isp 15600000.isp: TIMEOUT 10000
[ 90.830263] isp 15600000.isp: NUM_SLOTS 12
[ 90.830265] isp 15600000.isp: NUM_HANDLES 1
[ 90.830303] isp 15600000.isp: SYNCPT_ID 29
[ 90.830305] isp 15600000.isp: SYNCPT_VAL 19
[ 90.830307] isp 15600000.isp: FIRST_GET 0x720
[ 90.830309] isp 15600000.isp: TIMEOUT 10000
[ 90.830311] isp 15600000.isp: NUM_SLOTS 9
[ 90.830313] isp 15600000.isp: NUM_HANDLES 1
[ 90.830353] isp 15600000.isp: SYNCPT_ID 29
[ 90.830355] isp 15600000.isp: SYNCPT_VAL 21
[ 90.830357] isp 15600000.isp: FIRST_GET 0x768
[ 90.830359] isp 15600000.isp: TIMEOUT 10000
[ 90.830361] isp 15600000.isp: NUM_SLOTS 9
[ 90.830364] isp 15600000.isp: NUM_HANDLES 1
[ 90.830368] isp 15600000.isp: SYNCPT_ID 29
[ 90.830401] isp 15600000.isp: SYNCPT_VAL 23
[ 90.830403] isp 15600000.isp: FIRST_GET 0x7b0
[ 90.830405] isp 15600000.isp: TIMEOUT 10000
[ 90.830407] isp 15600000.isp: NUM_SLOTS 9
[ 90.830409] isp 15600000.isp: NUM_HANDLES 5
[ 90.830444] isp 15600000.isp: SYNCPT_ID 23
[ 90.830446] isp 15600000.isp: SYNCPT_VAL 28
[ 90.830448] isp 15600000.isp: FIRST_GET 0x7f8
[ 90.830449] isp 15600000.isp: TIMEOUT 10000
[ 90.830451] isp 15600000.isp: NUM_SLOTS 19
[ 90.830453] isp 15600000.isp: NUM_HANDLES 1
[ 90.830602] isp 15600000.isp: SYNCPT_ID 29
[ 90.830604] isp 15600000.isp: SYNCPT_VAL 26
[ 90.830606] isp 15600000.isp: FIRST_GET 0x890
[ 90.830608] isp 15600000.isp: TIMEOUT 10000
[ 90.830610] isp 15600000.isp: NUM_SLOTS 12
[ 90.830612] isp 15600000.isp: NUM_HANDLES 1
Can someone tell me where I went wrong?
Thank you.
