@ShaneCCC I enabled the dev_dbg() messages using the following commands:
echo 'file channel.c +p' > /sys/kernel/debug/dynamic_debug/control
echo 'file csi4_fops.c +p' > /sys/kernel/debug/dynamic_debug/control
echo 'file csi2_fops.c +p' > /sys/kernel/debug/dynamic_debug/control
Here is the new trace information.
# tracer: nop
# entries-in-buffer/entries-written: 621/621 #P:2
# _-----=> irqs-off
# / _----=> need-resched
# | / _---=> hardirq/softirq
# || / _--=> preempt-depth
# ||| / delay
# TASK-PID CPU# |||| TIMESTAMP FUNCTION
kworker/0:4-2079 [000] .... 61.183242: rtos_queue_peek_from_isr_failed: tstamp:2277719167 queue:0x0bcbcf78
kworker/0:4-2079 [000] .... 61.351213: rtos_queue_peek_from_isr_failed: tstamp:2282719168 queue:0x0bcbcf78
kworker/0:4-2079 [000] .... 61.519234: rtos_queue_peek_from_isr_failed: tstamp:2287719167 queue:0x0bcbcf78
kworker/0:4-2079 [000] .... 61.687224: rtos_queue_peek_from_isr_failed: tstamp:2292719164 queue:0x0bcbcf78
kworker/0:4-2079 [000] .... 61.855251: rtos_queue_peek_from_isr_failed: tstamp:2297719169 queue:0x0bcbcf78
kworker/0:4-2079 [000] .... 62.023219: rtos_queue_peek_from_isr_failed: tstamp:2302719163 queue:0x0bcbcf78
kworker/0:4-2079 [000] .... 62.135247: rtos_queue_peek_from_isr_failed: tstamp:2307719166 queue:0x0bcbcf78
kworker/0:4-2079 [000] .... 62.303225: rtos_queue_peek_from_isr_failed: tstamp:2312719166 queue:0x0bcbcf78
kworker/0:4-2079 [000] .... 62.471235: rtos_queue_peek_from_isr_failed: tstamp:2317719166 queue:0x0bcbcf78
kworker/0:4-2079 [000] .... 62.639252: rtos_queue_peek_from_isr_failed: tstamp:2322719166 queue:0x0bcbcf78
kworker/0:4-2079 [000] .... 62.807300: rtos_queue_peek_from_isr_failed: tstamp:2327719163 queue:0x0bcbcf78
kworker/0:4-2079 [000] .... 62.975233: rtos_queue_peek_from_isr_failed: tstamp:2332719166 queue:0x0bcbcf78
kworker/0:4-2079 [000] .... 63.143220: rtos_queue_peek_from_isr_failed: tstamp:2337719166 queue:0x0bcbcf78
kworker/0:4-2079 [000] .... 63.255216: rtos_queue_peek_from_isr_failed: tstamp:2342719164 queue:0x0bcbcf78
kworker/0:4-2079 [000] .... 63.423252: rtos_queue_peek_from_isr_failed: tstamp:2347719167 queue:0x0bcbcf78
kworker/0:4-2079 [000] .... 63.591225: rtos_queue_peek_from_isr_failed: tstamp:2352719167 queue:0x0bcbcf78
kworker/0:4-2079 [000] .... 63.759224: rtos_queue_peek_from_isr_failed: tstamp:2357719166 queue:0x0bcbcf78
kworker/0:4-2079 [000] .... 63.927245: rtos_queue_peek_from_isr_failed: tstamp:2362719166 queue:0x0bcbcf78
kworker/0:4-2079 [000] .... 64.095259: rtos_queue_peek_from_isr_failed: tstamp:2367719163 queue:0x0bcbcf78
kworker/0:4-2079 [000] .... 64.263230: rtos_queue_peek_from_isr_failed: tstamp:2372719163 queue:0x0bcbcf78
kworker/0:4-2079 [000] .... 64.375242: rtos_queue_peek_from_isr_failed: tstamp:2377719169 queue:0x0bcbcf78
kworker/0:4-2079 [000] .... 64.543222: rtos_queue_peek_from_isr_failed: tstamp:2382719168 queue:0x0bcbcf78
kworker/0:4-2079 [000] .... 64.711234: rtos_queue_peek_from_isr_failed: tstamp:2387719167 queue:0x0bcbcf78
kworker/0:4-2079 [000] .... 64.879234: rtos_queue_peek_from_isr_failed: tstamp:2392719163 queue:0x0bcbcf78
kworker/0:4-2079 [000] .... 65.047234: rtos_queue_peek_from_isr_failed: tstamp:2397719169 queue:0x0bcbcf78
kworker/0:4-2079 [000] .... 65.219227: rtos_queue_peek_from_isr_failed: tstamp:2402719165 queue:0x0bcbcf78
kworker/0:4-2079 [000] .... 65.387262: rtos_queue_peek_from_isr_failed: tstamp:2407719163 queue:0x0bcbcf78
kworker/0:4-2079 [000] .... 65.499233: rtos_queue_peek_from_isr_failed: tstamp:2412719168 queue:0x0bcbcf78
kworker/0:4-2079 [000] .... 65.667243: rtos_queue_peek_from_isr_failed: tstamp:2417719171 queue:0x0bcbcf78
kworker/0:4-2079 [000] .... 65.835264: rtos_queue_peek_from_isr_failed: tstamp:2422719168 queue:0x0bcbcf78
kworker/0:4-2079 [000] .... 66.003230: rtos_queue_peek_from_isr_failed: tstamp:2427719167 queue:0x0bcbcf78
kworker/0:4-2079 [000] .... 66.171228: rtos_queue_peek_from_isr_failed: tstamp:2432719168 queue:0x0bcbcf78
kworker/0:4-2079 [000] .... 66.339221: rtos_queue_peek_from_isr_failed: tstamp:2437719168 queue:0x0bcbcf78
kworker/0:4-2079 [000] .... 66.395254: rtos_queue_peek_from_isr_failed: tstamp:2440488267 queue:0x0bcbcf78
gst-plugin-scan-6821 [000] .... 79.146174: tegra_channel_open: vi-output, imx274 30-001a
gst-plugin-scan-6821 [001] .... 79.147665: tegra_channel_set_power: imx274 30-001a : 0x1
gst-plugin-scan-6821 [001] .... 79.147680: camera_common_s_power: status : 0x1
gst-plugin-scan-6821 [001] .... 79.158725: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x1
gst-plugin-scan-6821 [001] .... 79.158731: csi_s_power: enable : 0x1
gst-plugin-scan-6821 [001] .... 79.160926: tegra_channel_close: vi-output, imx274 30-001a
gst-plugin-scan-6821 [001] .... 79.160933: tegra_channel_set_power: imx274 30-001a : 0x0
gst-plugin-scan-6821 [001] .... 79.160943: camera_common_s_power: status : 0x0
gst-plugin-scan-6821 [001] .... 79.161172: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x0
gst-plugin-scan-6821 [001] .... 79.161176: csi_s_power: enable : 0x0
gst-plugin-scan-6821 [001] .... 79.162228: tegra_channel_open: vi-output, imx274 31-001a
gst-plugin-scan-6821 [001] .... 79.162235: tegra_channel_set_power: imx274 31-001a : 0x1
gst-plugin-scan-6821 [001] .... 79.162246: camera_common_s_power: status : 0x1
gst-plugin-scan-6821 [001] .... 79.172682: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x1
gst-plugin-scan-6821 [001] .... 79.172685: csi_s_power: enable : 0x1
gst-plugin-scan-6821 [001] .... 79.172984: tegra_channel_close: vi-output, imx274 31-001a
gst-plugin-scan-6821 [001] .... 79.172989: tegra_channel_set_power: imx274 31-001a : 0x0
gst-plugin-scan-6821 [001] .... 79.172997: camera_common_s_power: status : 0x0
gst-plugin-scan-6821 [001] .... 79.173173: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x0
gst-plugin-scan-6821 [001] .... 79.173175: csi_s_power: enable : 0x0
gst-plugin-scan-6821 [001] .... 79.174186: tegra_channel_open: vi-output, imx274 32-001a
gst-plugin-scan-6821 [001] .... 79.174191: tegra_channel_set_power: imx274 32-001a : 0x1
gst-plugin-scan-6821 [001] .... 79.174199: camera_common_s_power: status : 0x1
gst-plugin-scan-6821 [001] .... 79.184656: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
gst-plugin-scan-6821 [001] .... 79.184659: csi_s_power: enable : 0x1
gst-plugin-scan-6821 [001] .... 79.184724: tegra_channel_close: vi-output, imx274 32-001a
gst-plugin-scan-6821 [001] .... 79.184727: tegra_channel_set_power: imx274 32-001a : 0x0
gst-plugin-scan-6821 [001] .... 79.184734: camera_common_s_power: status : 0x0
gst-plugin-scan-6821 [001] .... 79.184933: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
gst-plugin-scan-6821 [001] .... 79.184936: csi_s_power: enable : 0x0
kworker/0:2-1615 [000] .... 79.499227: rtos_queue_peek_from_isr_failed: tstamp:2850064538 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 79.499234: rtcpu_start: tstamp:2850066138
kworker/0:2-1615 [000] .... 79.499236: rtos_queue_send_from_isr_failed: tstamp:2850076051 queue:0x0bcb41f8
kworker/0:2-1615 [000] .... 79.499237: rtos_queue_send_from_isr_failed: tstamp:2850076200 queue:0x0bcb8a60
kworker/0:2-1615 [000] .... 79.499238: rtos_queue_send_from_isr_failed: tstamp:2850076349 queue:0x0bcba5e0
kworker/0:2-1615 [000] .... 79.499239: rtos_queue_send_from_isr_failed: tstamp:2850076496 queue:0x0bcbb3a0
kworker/0:2-1615 [000] .... 79.499240: rtos_queue_send_from_isr_failed: tstamp:2850076642 queue:0x0bcbc160
kworker/0:2-1615 [000] .... 79.499241: rtcpu_string: tstamp:2850077096 id:0x04010000 str:"Configuring ISP GoS.
kworker/0:2-1615 [000] .... 79.499268: rtcpu_string: tstamp:2850077276 id:0x04010000 str:" VM GOS[#0] addr=0xc2100000
kworker/0:2-1615 [000] .... 79.499284: rtcpu_string: tstamp:2850077534 id:0x04010000 str:" VM GOS[#1] addr=0xc2101000
kworker/0:2-1615 [000] .... 79.499296: rtcpu_string: tstamp:2850077805 id:0x04010000 str:" VM GOS[#2] addr=0xc2102000
kworker/0:2-1615 [000] .... 79.499306: rtcpu_string: tstamp:2850078041 id:0x04010000 str:" VM GOS[#3] addr=0xc2103000
kworker/0:2-1615 [000] .... 79.499317: rtcpu_string: tstamp:2850078277 id:0x04010000 str:" VM GOS[#4] addr=0xc2104000
kworker/0:2-1615 [000] .... 79.499327: rtcpu_string: tstamp:2850078559 id:0x04010000 str:" VM GOS[#5] addr=0xc2105000
kworker/0:2-1615 [000] .... 79.499338: rtcpu_string: tstamp:2850091546 id:0x04010000 str:"WARNING: t194/isp5.c:901 [config_channel] ""
kworker/0:2-1615 [000] .... 79.499339: rtcpu_string: tstamp:2850091925 id:0x04010000 str:"All error notifications not enabled: correctable"
kworker/0:2-1615 [000] .... 79.499340: rtcpu_string: tstamp:2850092043 id:0x04010000 str:"=0x00 uncorrectable=0x00"
kworker/0:2-1615 [000] .... 79.499341: rtcpu_string: tstamp:2850092236 id:0x04010000 str:""
kworker/0:2-1615 [000] .... 79.667220: rtos_queue_peek_from_isr_failed: tstamp:2855064889 queue:0x0bcbcf78
nvargus-daemon-6830 [001] .... 79.807039: tegra_channel_open: vi-output, imx274 30-001a
nvargus-daemon-6830 [001] .... 79.807052: tegra_channel_set_power: imx274 30-001a : 0x1
nvargus-daemon-6830 [001] .... 79.807065: camera_common_s_power: status : 0x1
nvargus-daemon-6830 [001] .... 79.817798: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x1
nvargus-daemon-6830 [001] .... 79.817802: csi_s_power: enable : 0x1
nvargus-daemon-6830 [001] .... 79.817946: tegra_channel_close: vi-output, imx274 30-001a
nvargus-daemon-6830 [001] .... 79.817950: tegra_channel_set_power: imx274 30-001a : 0x0
nvargus-daemon-6830 [001] .... 79.817958: camera_common_s_power: status : 0x0
nvargus-daemon-6830 [001] .... 79.818123: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x0
nvargus-daemon-6830 [001] .... 79.818126: csi_s_power: enable : 0x0
nvargus-daemon-6830 [001] .... 79.819345: tegra_channel_open: vi-output, imx274 31-001a
nvargus-daemon-6830 [001] .... 79.819353: tegra_channel_set_power: imx274 31-001a : 0x1
nvargus-daemon-6830 [001] .... 79.819363: camera_common_s_power: status : 0x1
nvargus-daemon-6830 [000] .... 79.830548: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x1
nvargus-daemon-6830 [000] .... 79.830551: csi_s_power: enable : 0x1
nvargus-daemon-6830 [000] .... 79.830643: tegra_channel_close: vi-output, imx274 31-001a
nvargus-daemon-6830 [000] .... 79.830646: tegra_channel_set_power: imx274 31-001a : 0x0
nvargus-daemon-6830 [000] .... 79.830652: camera_common_s_power: status : 0x0
nvargus-daemon-6830 [000] .... 79.830811: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x0
nvargus-daemon-6830 [000] .... 79.830813: csi_s_power: enable : 0x0
nvargus-daemon-6830 [000] .... 79.831818: tegra_channel_open: vi-output, imx274 32-001a
nvargus-daemon-6830 [000] .... 79.831824: tegra_channel_set_power: imx274 32-001a : 0x1
nvargus-daemon-6830 [000] .... 79.831831: camera_common_s_power: status : 0x1
kworker/0:2-1615 [000] .... 79.835255: rtos_queue_peek_from_isr_failed: tstamp:2860064889 queue:0x0bcbcf78
nvargus-daemon-6830 [000] .... 79.842221: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
nvargus-daemon-6830 [000] .... 79.842224: csi_s_power: enable : 0x1
nvargus-daemon-6830 [000] .... 79.842326: tegra_channel_close: vi-output, imx274 32-001a
nvargus-daemon-6830 [000] .... 79.842330: tegra_channel_set_power: imx274 32-001a : 0x0
nvargus-daemon-6830 [000] .... 79.842337: camera_common_s_power: status : 0x0
nvargus-daemon-6830 [000] .... 79.842499: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
nvargus-daemon-6830 [000] .... 79.842501: csi_s_power: enable : 0x0
nvargus-daemon-6830 [000] .... 79.846831: tegra_channel_open: vi-output, imx274 30-001a
nvargus-daemon-6830 [000] .... 79.846839: tegra_channel_set_power: imx274 30-001a : 0x1
nvargus-daemon-6830 [000] .... 79.846848: camera_common_s_power: status : 0x1
nvargus-daemon-6830 [000] .... 79.858066: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x1
nvargus-daemon-6830 [000] .... 79.858070: csi_s_power: enable : 0x1
nvargus-daemon-6830 [000] .... 79.858285: tegra_channel_close: vi-output, imx274 30-001a
nvargus-daemon-6830 [000] .... 79.858289: tegra_channel_set_power: imx274 30-001a : 0x0
nvargus-daemon-6830 [000] .... 79.858297: camera_common_s_power: status : 0x0
nvargus-daemon-6830 [000] .... 79.858471: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x0
nvargus-daemon-6830 [000] .... 79.858473: csi_s_power: enable : 0x0
nvargus-daemon-6830 [000] .... 79.859573: tegra_channel_open: vi-output, imx274 31-001a
nvargus-daemon-6830 [000] .... 79.859579: tegra_channel_set_power: imx274 31-001a : 0x1
nvargus-daemon-6830 [000] .... 79.859588: camera_common_s_power: status : 0x1
nvargus-daemon-6830 [000] .... 79.870032: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x1
nvargus-daemon-6830 [000] .... 79.870035: csi_s_power: enable : 0x1
nvargus-daemon-6830 [000] .... 79.870205: tegra_channel_close: vi-output, imx274 31-001a
nvargus-daemon-6830 [000] .... 79.870209: tegra_channel_set_power: imx274 31-001a : 0x0
nvargus-daemon-6830 [000] .... 79.870218: camera_common_s_power: status : 0x0
nvargus-daemon-6830 [000] .... 79.870373: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x0
nvargus-daemon-6830 [000] .... 79.870375: csi_s_power: enable : 0x0
nvargus-daemon-6830 [000] .... 79.871361: tegra_channel_open: vi-output, imx274 32-001a
nvargus-daemon-6830 [000] .... 79.871367: tegra_channel_set_power: imx274 32-001a : 0x1
nvargus-daemon-6830 [000] .... 79.871377: camera_common_s_power: status : 0x1
nvargus-daemon-6830 [000] .... 79.881782: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
nvargus-daemon-6830 [000] .... 79.881786: csi_s_power: enable : 0x1
nvargus-daemon-6830 [000] .... 79.881940: tegra_channel_close: vi-output, imx274 32-001a
nvargus-daemon-6830 [000] .... 79.881943: tegra_channel_set_power: imx274 32-001a : 0x0
nvargus-daemon-6830 [000] .... 79.881953: camera_common_s_power: status : 0x0
nvargus-daemon-6830 [000] .... 79.882131: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
nvargus-daemon-6830 [000] .... 79.882133: csi_s_power: enable : 0x0
nvargus-daemon-6830 [000] .... 79.896223: tegra_channel_open: vi-output, imx274 32-001a
nvargus-daemon-6830 [000] .... 79.896234: tegra_channel_set_power: imx274 32-001a : 0x1
nvargus-daemon-6830 [000] .... 79.896250: camera_common_s_power: status : 0x1
nvargus-daemon-6830 [000] .... 79.906685: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
nvargus-daemon-6830 [000] .... 79.906689: csi_s_power: enable : 0x1
nvargus-daemon-6830 [000] .... 79.906722: tegra_channel_close: vi-output, imx274 32-001a
nvargus-daemon-6830 [000] .... 79.906726: tegra_channel_set_power: imx274 32-001a : 0x0
nvargus-daemon-6830 [000] .... 79.906737: camera_common_s_power: status : 0x0
nvargus-daemon-6830 [000] .... 79.906924: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
nvargus-daemon-6830 [000] .... 79.906927: csi_s_power: enable : 0x0
nvargus-daemon-6830 [000] .... 79.908045: tegra_channel_open: vi-output, imx274 31-001a
nvargus-daemon-6830 [000] .... 79.908052: tegra_channel_set_power: imx274 31-001a : 0x1
nvargus-daemon-6830 [000] .... 79.908064: camera_common_s_power: status : 0x1
nvargus-daemon-6830 [000] .... 79.918523: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x1
nvargus-daemon-6830 [000] .... 79.918526: csi_s_power: enable : 0x1
nvargus-daemon-6830 [000] .... 79.918554: tegra_channel_close: vi-output, imx274 31-001a
nvargus-daemon-6830 [000] .... 79.918558: tegra_channel_set_power: imx274 31-001a : 0x0
nvargus-daemon-6830 [000] .... 79.918567: camera_common_s_power: status : 0x0
nvargus-daemon-6830 [000] .... 79.918766: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x0
nvargus-daemon-6830 [000] .... 79.918768: csi_s_power: enable : 0x0
nvargus-daemon-6830 [000] .... 79.919818: tegra_channel_open: vi-output, imx274 30-001a
nvargus-daemon-6830 [000] .... 79.919824: tegra_channel_set_power: imx274 30-001a : 0x1
nvargus-daemon-6830 [000] .... 79.919835: camera_common_s_power: status : 0x1
nvargus-daemon-6830 [000] .... 79.930251: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x1
nvargus-daemon-6830 [000] .... 79.930254: csi_s_power: enable : 0x1
nvargus-daemon-6830 [000] .... 79.930278: tegra_channel_close: vi-output, imx274 30-001a
nvargus-daemon-6830 [000] .... 79.930281: tegra_channel_set_power: imx274 30-001a : 0x0
nvargus-daemon-6830 [000] .... 79.930314: camera_common_s_power: status : 0x0
nvargus-daemon-6830 [000] .... 79.930483: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x0
nvargus-daemon-6830 [000] .... 79.930486: csi_s_power: enable : 0x0
nvargus-daemon-6830 [000] .... 79.931465: tegra_channel_open: vi-output, imx274 30-001a
nvargus-daemon-6830 [000] .... 79.931471: tegra_channel_set_power: imx274 30-001a : 0x1
nvargus-daemon-6830 [000] .... 79.931480: camera_common_s_power: status : 0x1
nvargus-daemon-6830 [000] .... 79.941881: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x1
nvargus-daemon-6830 [000] .... 79.941884: csi_s_power: enable : 0x1
nvargus-daemon-6830 [000] .... 79.942021: tegra_channel_close: vi-output, imx274 30-001a
nvargus-daemon-6830 [000] .... 79.942024: tegra_channel_set_power: imx274 30-001a : 0x0
nvargus-daemon-6830 [000] .... 79.942033: camera_common_s_power: status : 0x0
nvargus-daemon-6830 [000] .... 79.942211: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x0
nvargus-daemon-6830 [000] .... 79.942213: csi_s_power: enable : 0x0
nvargus-daemon-6830 [000] .... 79.943220: tegra_channel_open: vi-output, imx274 30-001a
nvargus-daemon-6830 [000] .... 79.943225: tegra_channel_set_power: imx274 30-001a : 0x1
nvargus-daemon-6830 [000] .... 79.943234: camera_common_s_power: status : 0x1
nvargus-daemon-6830 [000] .... 79.953635: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x1
nvargus-daemon-6830 [000] .... 79.953638: csi_s_power: enable : 0x1
nvargus-daemon-6830 [000] .... 79.953797: tegra_channel_close: vi-output, imx274 30-001a
nvargus-daemon-6830 [000] .... 79.953800: tegra_channel_set_power: imx274 30-001a : 0x0
nvargus-daemon-6830 [000] .... 79.953808: camera_common_s_power: status : 0x0
nvargus-daemon-6830 [000] .... 79.953988: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x0
nvargus-daemon-6830 [000] .... 79.953990: csi_s_power: enable : 0x0
nvargus-daemon-6830 [000] .... 79.980744: tegra_channel_open: vi-output, imx274 32-001a
nvargus-daemon-6830 [000] .... 79.980757: tegra_channel_set_power: imx274 32-001a : 0x1
nvargus-daemon-6830 [000] .... 79.980773: camera_common_s_power: status : 0x1
nvargus-daemon-6830 [000] .... 79.991255: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
nvargus-daemon-6830 [000] .... 79.991260: csi_s_power: enable : 0x1
nvargus-daemon-6830 [000] .... 79.991297: tegra_channel_close: vi-output, imx274 32-001a
nvargus-daemon-6830 [000] .... 79.991302: tegra_channel_set_power: imx274 32-001a : 0x0
nvargus-daemon-6830 [000] .... 79.991312: camera_common_s_power: status : 0x0
nvargus-daemon-6830 [000] .... 79.991507: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
nvargus-daemon-6830 [000] .... 79.991510: csi_s_power: enable : 0x0
nvargus-daemon-6830 [000] .... 79.992506: tegra_channel_open: vi-output, imx274 31-001a
nvargus-daemon-6830 [000] .... 79.992512: tegra_channel_set_power: imx274 31-001a : 0x1
nvargus-daemon-6830 [000] .... 79.992529: camera_common_s_power: status : 0x1
nvargus-daemon-6830 [000] .... 80.002927: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x1
nvargus-daemon-6830 [000] .... 80.002929: csi_s_power: enable : 0x1
nvargus-daemon-6830 [000] .... 80.002978: tegra_channel_close: vi-output, imx274 31-001a
nvargus-daemon-6830 [000] .... 80.002982: tegra_channel_set_power: imx274 31-001a : 0x0
nvargus-daemon-6830 [000] .... 80.002990: camera_common_s_power: status : 0x0
kworker/0:2-1615 [000] .... 80.003238: rtos_queue_peek_from_isr_failed: tstamp:2865064883 queue:0x0bcbcf78
nvargus-daemon-6830 [000] .... 80.003272: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x0
nvargus-daemon-6830 [000] .... 80.003274: csi_s_power: enable : 0x0
nvargus-daemon-6830 [000] .... 80.004231: tegra_channel_open: vi-output, imx274 31-001a
nvargus-daemon-6830 [000] .... 80.004237: tegra_channel_set_power: imx274 31-001a : 0x1
nvargus-daemon-6830 [000] .... 80.004245: camera_common_s_power: status : 0x1
nvargus-daemon-6830 [000] .... 80.014696: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x1
nvargus-daemon-6830 [000] .... 80.014699: csi_s_power: enable : 0x1
nvargus-daemon-6830 [000] .... 80.014839: tegra_channel_close: vi-output, imx274 31-001a
nvargus-daemon-6830 [000] .... 80.014842: tegra_channel_set_power: imx274 31-001a : 0x0
nvargus-daemon-6830 [000] .... 80.014851: camera_common_s_power: status : 0x0
nvargus-daemon-6830 [000] .... 80.015016: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x0
nvargus-daemon-6830 [000] .... 80.015019: csi_s_power: enable : 0x0
nvargus-daemon-6830 [000] .... 80.016026: tegra_channel_open: vi-output, imx274 31-001a
nvargus-daemon-6830 [000] .... 80.016031: tegra_channel_set_power: imx274 31-001a : 0x1
nvargus-daemon-6830 [000] .... 80.016041: camera_common_s_power: status : 0x1
nvargus-daemon-6830 [000] .... 80.026451: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x1
nvargus-daemon-6830 [000] .... 80.026454: csi_s_power: enable : 0x1
nvargus-daemon-6830 [000] .... 80.026680: tegra_channel_close: vi-output, imx274 31-001a
nvargus-daemon-6830 [000] .... 80.026688: tegra_channel_set_power: imx274 31-001a : 0x0
nvargus-daemon-6830 [000] .... 80.026695: camera_common_s_power: status : 0x0
nvargus-daemon-6830 [000] .... 80.026857: tegra_channel_set_power: 15a00000.nvcsi--2 : 0x0
nvargus-daemon-6830 [000] .... 80.026859: csi_s_power: enable : 0x0
nvargus-daemon-6830 [001] .... 80.046081: tegra_channel_open: vi-output, imx274 32-001a
nvargus-daemon-6830 [001] .... 80.046094: tegra_channel_set_power: imx274 32-001a : 0x1
nvargus-daemon-6830 [001] .... 80.046107: camera_common_s_power: status : 0x1
nvargus-daemon-6830 [001] .... 80.056608: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
nvargus-daemon-6830 [001] .... 80.056614: csi_s_power: enable : 0x1
nvargus-daemon-6830 [001] .... 80.056650: tegra_channel_close: vi-output, imx274 32-001a
nvargus-daemon-6830 [001] .... 80.056656: tegra_channel_set_power: imx274 32-001a : 0x0
nvargus-daemon-6830 [001] .... 80.056665: camera_common_s_power: status : 0x0
nvargus-daemon-6830 [001] .... 80.056865: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
nvargus-daemon-6830 [001] .... 80.056867: csi_s_power: enable : 0x0
nvargus-daemon-6830 [001] .... 80.057903: tegra_channel_open: vi-output, imx274 32-001a
nvargus-daemon-6830 [001] .... 80.057909: tegra_channel_set_power: imx274 32-001a : 0x1
nvargus-daemon-6830 [001] .... 80.057916: camera_common_s_power: status : 0x1
nvargus-daemon-6830 [001] .... 80.068366: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
nvargus-daemon-6830 [001] .... 80.068369: csi_s_power: enable : 0x1
nvargus-daemon-6830 [001] .... 80.068538: tegra_channel_close: vi-output, imx274 32-001a
nvargus-daemon-6830 [001] .... 80.068542: tegra_channel_set_power: imx274 32-001a : 0x0
nvargus-daemon-6830 [001] .... 80.068549: camera_common_s_power: status : 0x0
nvargus-daemon-6830 [001] .... 80.068729: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
nvargus-daemon-6830 [001] .... 80.068731: csi_s_power: enable : 0x0
nvargus-daemon-6830 [001] .... 80.069803: tegra_channel_open: vi-output, imx274 32-001a
nvargus-daemon-6830 [001] .... 80.069808: tegra_channel_set_power: imx274 32-001a : 0x1
nvargus-daemon-6830 [001] .... 80.069817: camera_common_s_power: status : 0x1
nvargus-daemon-6830 [001] .... 80.080262: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x1
nvargus-daemon-6830 [001] .... 80.080265: csi_s_power: enable : 0x1
nvargus-daemon-6830 [001] .... 80.080465: tegra_channel_close: vi-output, imx274 32-001a
nvargus-daemon-6830 [001] .... 80.080468: tegra_channel_set_power: imx274 32-001a : 0x0
nvargus-daemon-6830 [001] .... 80.080475: camera_common_s_power: status : 0x0
nvargus-daemon-6830 [001] .... 80.080671: tegra_channel_set_power: 15a00000.nvcsi--1 : 0x0
nvargus-daemon-6830 [001] .... 80.080673: csi_s_power: enable : 0x0
kworker/0:2-1615 [000] .... 80.115274: rtos_queue_send_from_isr_failed: tstamp:2869200443 queue:0x0bcb41f8
kworker/0:2-1615 [000] .... 80.115279: rtos_queue_send_from_isr_failed: tstamp:2869200597 queue:0x0bcb8a60
kworker/0:2-1615 [000] .... 80.115281: rtos_queue_send_from_isr_failed: tstamp:2869200750 queue:0x0bcba5e0
kworker/0:2-1615 [000] .... 80.115281: rtos_queue_send_from_isr_failed: tstamp:2869200898 queue:0x0bcbb3a0
kworker/0:2-1615 [000] .... 80.115282: rtos_queue_send_from_isr_failed: tstamp:2869201043 queue:0x0bcbc160
kworker/0:2-1615 [000] .... 80.115284: rtcpu_string: tstamp:2869201480 id:0x04010000 str:"Configuring VI GoS.
kworker/0:2-1615 [000] .... 80.115319: rtcpu_string: tstamp:2869201657 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
kworker/0:2-1615 [000] .... 80.115331: rtcpu_string: tstamp:2869201909 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
kworker/0:2-1615 [000] .... 80.115344: rtcpu_string: tstamp:2869202175 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
kworker/0:2-1615 [000] .... 80.115355: rtcpu_string: tstamp:2869202407 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
kworker/0:2-1615 [000] .... 80.115365: rtcpu_string: tstamp:2869202641 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
kworker/0:2-1615 [000] .... 80.115375: rtcpu_string: tstamp:2869202874 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
kworker/0:2-1615 [000] .... 80.115387: rtcpu_string: tstamp:2869211646 id:0x04010000 str:"vi5_hwinit: firmware CL2018101701 protocol versi"
kworker/0:2-1615 [000] .... 80.115388: rtcpu_string: tstamp:2869211767 id:0x04010000 str:"on 2.2
kworker/0:2-1615 [000] .... 80.115400: rtos_queue_send_from_isr_failed: tstamp:2869222789 queue:0x0bcb41f8
kworker/0:2-1615 [000] .... 80.115402: rtos_queue_send_from_isr_failed: tstamp:2869222961 queue:0x0bcb8a60
kworker/0:2-1615 [000] .... 80.115403: rtos_queue_send_from_isr_failed: tstamp:2869223117 queue:0x0bcba5e0
kworker/0:2-1615 [000] .... 80.115403: rtos_queue_send_from_isr_failed: tstamp:2869223263 queue:0x0bcbb3a0
kworker/0:2-1615 [000] .... 80.115404: rtos_queue_send_from_isr_failed: tstamp:2869223407 queue:0x0bcbc160
kworker/0:2-1615 [000] .... 80.115408: rtcpu_nvcsi_intr: tstamp:2869225802 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000089
kworker/0:2-1615 [000] .... 80.115409: rtcpu_nvcsi_intr: tstamp:2869225802 class:GLOBAL type:PHY_INTR0 phy:0 cil:1 st:0 vc:0 status:0x00000088
kworker/0:2-1615 [000] .... 80.175222: rtos_queue_peek_from_isr_failed: tstamp:2870064887 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 80.343228: rtos_queue_peek_from_isr_failed: tstamp:2875064888 queue:0x0bcbcf78
CaptureSchedule-6848 [001] .... 80.404742: tegra_channel_open: vi-output, imx274 30-001a
CaptureSchedule-6848 [001] .... 80.404756: tegra_channel_set_power: imx274 30-001a : 0x1
CaptureSchedule-6848 [001] .... 80.404771: camera_common_s_power: status : 0x1
CaptureSchedule-6848 [001] .... 80.415532: tegra_channel_set_power: 15a00000.nvcsi--3 : 0x1
CaptureSchedule-6848 [001] .... 80.415539: csi_s_power: enable : 0x1
CaptureSchedule-6848 [001] .... 80.437928: tegra_channel_set_stream: enable : 0x1
CaptureSchedule-6848 [001] .... 80.441073: tegra_channel_set_stream: 15a00000.nvcsi--3 : 0x1
CaptureSchedule-6848 [001] .... 80.441078: csi_s_stream: enable : 0x1
CaptureSchedule-6848 [001] .... 80.441080: tegra_channel_set_stream: imx274 30-001a : 0x1
kworker/0:2-1615 [000] .... 80.455217: rtos_queue_send_from_isr_failed: tstamp:2878556367 queue:0x0bcb41f8
kworker/0:2-1615 [000] .... 80.455221: rtos_queue_send_from_isr_failed: tstamp:2878556518 queue:0x0bcb8a60
kworker/0:2-1615 [000] .... 80.455222: rtos_queue_send_from_isr_failed: tstamp:2878556668 queue:0x0bcba5e0
kworker/0:2-1615 [000] .... 80.455223: rtos_queue_send_from_isr_failed: tstamp:2878556816 queue:0x0bcbb3a0
kworker/0:2-1615 [000] .... 80.455224: rtos_queue_send_from_isr_failed: tstamp:2878556961 queue:0x0bcbc160
kworker/0:2-1615 [000] .... 80.455224: rtos_queue_send_from_isr_failed: tstamp:2878557166 queue:0x0bcb4190
kworker/0:2-1615 [000] .... 80.455225: rtos_queue_send_from_isr_failed: tstamp:2878557304 queue:0x0bcb41f8
kworker/0:2-1615 [000] .... 80.455226: rtos_queue_send_from_isr_failed: tstamp:2878557441 queue:0x0bcb89f8
kworker/0:2-1615 [000] .... 80.455227: rtos_queue_send_from_isr_failed: tstamp:2878557576 queue:0x0bcb8a60
kworker/0:2-1615 [000] .... 80.455228: rtos_queue_send_from_isr_failed: tstamp:2878557715 queue:0x0bcba578
kworker/0:2-1615 [000] .... 80.455229: rtos_queue_send_from_isr_failed: tstamp:2878557848 queue:0x0bcba5e0
kworker/0:2-1615 [000] .... 80.455229: rtos_queue_send_from_isr_failed: tstamp:2878557984 queue:0x0bcbb338
kworker/0:2-1615 [000] .... 80.455230: rtos_queue_send_from_isr_failed: tstamp:2878558118 queue:0x0bcbb3a0
kworker/0:2-1615 [000] .... 80.455231: rtos_queue_send_from_isr_failed: tstamp:2878558253 queue:0x0bcbc0f8
kworker/0:2-1615 [000] .... 80.455232: rtos_queue_send_from_isr_failed: tstamp:2878558386 queue:0x0bcbc160
kworker/0:2-1615 [000] .... 80.455233: rtos_queue_send_from_isr_failed: tstamp:2878583944 queue:0x0bcb41f8
kworker/0:2-1615 [000] .... 80.455234: rtos_queue_send_from_isr_failed: tstamp:2878584094 queue:0x0bcb8a60
kworker/0:2-1615 [000] .... 80.455235: rtos_queue_send_from_isr_failed: tstamp:2878584246 queue:0x0bcba5e0
kworker/0:2-1615 [000] .... 80.455235: rtos_queue_send_from_isr_failed: tstamp:2878584393 queue:0x0bcbb3a0
kworker/0:2-1615 [000] .... 80.455236: rtos_queue_send_from_isr_failed: tstamp:2878584539 queue:0x0bcbc160
kworker/0:2-1615 [000] .... 80.455237: rtos_queue_send_from_isr_failed: tstamp:2878588534 queue:0x0bcb41f8
kworker/0:2-1615 [000] .... 80.455238: rtos_queue_send_from_isr_failed: tstamp:2878588681 queue:0x0bcb8a60
kworker/0:2-1615 [000] .... 80.455239: rtos_queue_send_from_isr_failed: tstamp:2878588834 queue:0x0bcba5e0
kworker/0:2-1615 [000] .... 80.455240: rtos_queue_send_from_isr_failed: tstamp:2878588980 queue:0x0bcbb3a0
kworker/0:2-1615 [000] .... 80.455241: rtos_queue_send_from_isr_failed: tstamp:2878589125 queue:0x0bcbc160
kworker/0:2-1615 [000] .... 80.455241: rtos_queue_send_from_isr_failed: tstamp:2879227204 queue:0x0bcb41f8
kworker/0:2-1615 [000] .... 80.455242: rtos_queue_send_from_isr_failed: tstamp:2879227354 queue:0x0bcb8a60
kworker/0:2-1615 [000] .... 80.455243: rtos_queue_send_from_isr_failed: tstamp:2879227503 queue:0x0bcba5e0
kworker/0:2-1615 [000] .... 80.455244: rtos_queue_send_from_isr_failed: tstamp:2879227651 queue:0x0bcbb3a0
kworker/0:2-1615 [000] .... 80.455245: rtos_queue_send_from_isr_failed: tstamp:2879227796 queue:0x0bcbc160
kworker/0:2-1615 [000] .... 80.455247: rtcpu_string: tstamp:2879228223 id:0x04010000 str:"Configuring VI GoS.
kworker/0:2-1615 [000] .... 80.455273: rtcpu_string: tstamp:2879228401 id:0x04010000 str:"VM GOS[#0] addr=0xc2100000
kworker/0:2-1615 [000] .... 80.455302: rtcpu_string: tstamp:2879228657 id:0x04010000 str:"VM GOS[#1] addr=0xc2101000
kworker/0:2-1615 [000] .... 80.455334: rtcpu_string: tstamp:2879228924 id:0x04010000 str:"VM GOS[#2] addr=0xc2102000
kworker/0:2-1615 [000] .... 80.455346: rtcpu_string: tstamp:2879229159 id:0x04010000 str:"VM GOS[#3] addr=0xc2103000
kworker/0:2-1615 [000] .... 80.455361: rtcpu_string: tstamp:2879229390 id:0x04010000 str:"VM GOS[#4] addr=0xc2104000
kworker/0:2-1615 [000] .... 80.455370: rtcpu_string: tstamp:2879229622 id:0x04010000 str:"VM GOS[#5] addr=0xc2105000
kworker/0:2-1615 [000] .... 80.455379: rtos_queue_send_from_isr_failed: tstamp:2879233456 queue:0x0bcb41f8
kworker/0:2-1615 [000] .... 80.455380: rtos_queue_send_from_isr_failed: tstamp:2879233608 queue:0x0bcb8a60
kworker/0:2-1615 [000] .... 80.455381: rtos_queue_send_from_isr_failed: tstamp:2879233765 queue:0x0bcba5e0
kworker/0:2-1615 [000] .... 80.455382: rtos_queue_send_from_isr_failed: tstamp:2879233910 queue:0x0bcbb3a0
kworker/0:2-1615 [000] .... 80.455383: rtos_queue_send_from_isr_failed: tstamp:2879234055 queue:0x0bcbc160
kworker/0:2-1615 [000] .... 80.455384: rtos_queue_send_from_isr_failed: tstamp:2879239333 queue:0x0bcb41f8
kworker/0:2-1615 [000] .... 80.455385: rtos_queue_send_from_isr_failed: tstamp:2879239478 queue:0x0bcb8a60
kworker/0:2-1615 [000] .... 80.455386: rtos_queue_send_from_isr_failed: tstamp:2879239627 queue:0x0bcba5e0
kworker/0:2-1615 [000] .... 80.455386: rtos_queue_send_from_isr_failed: tstamp:2879239774 queue:0x0bcbb3a0
kworker/0:2-1615 [000] .... 80.455387: rtos_queue_send_from_isr_failed: tstamp:2879239919 queue:0x0bcbc160
kworker/0:2-1615 [000] .... 80.455389: rtos_queue_peek_from_isr_failed: tstamp:2880064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 80.571264: rtos_queue_send_from_isr_failed: tstamp:2883168460 queue:0x0bcb41f8
kworker/0:2-1615 [000] .... 80.571270: rtos_queue_send_from_isr_failed: tstamp:2883168609 queue:0x0bcb8a60
kworker/0:2-1615 [000] .... 80.571271: rtos_queue_send_from_isr_failed: tstamp:2883168761 queue:0x0bcba5e0
kworker/0:2-1615 [000] .... 80.571272: rtos_queue_send_from_isr_failed: tstamp:2883168906 queue:0x0bcbb3a0
kworker/0:2-1615 [000] .... 80.571273: rtos_queue_send_from_isr_failed: tstamp:2883169050 queue:0x0bcbc160
kworker/0:2-1615 [000] .... 80.571275: rtcpu_string: tstamp:2883169889 id:0x04010000 str:"VI GOS[#0] set to VM GOS[4] base 0xc2104000
kworker/0:2-1615 [000] .... 80.571324: rtcpu_vinotify_event: tstamp:2883205650 tag:RESERVED_18 channel:0x0b frame:0 vi_tstamp:2067195264 data:0x10000000
kworker/0:2-1615 [000] .... 80.571325: rtcpu_vinotify_event: tstamp:2883205796 tag:RESERVED_18 channel:0x0b frame:0 vi_tstamp:2067224608 data:0x31000001
kworker/0:2-1615 [000] .... 80.571326: rtcpu_vinotify_event: tstamp:2883205959 tag:RESERVED_19 channel:0x0b frame:0 vi_tstamp:2067233440 data:0x07020001
kworker/0:2-1615 [000] .... 80.571328: rtcpu_nvcsi_intr: tstamp:2883648316 class:GLOBAL type:PHY_INTR0 phy:0 cil:0 st:0 vc:0 status:0x00000110
kworker/0:2-1615 [000] .... 80.627250: rtos_queue_send_from_isr_failed: tstamp:2883940165 queue:0x0bcb41f8
kworker/0:2-1615 [000] .... 80.627255: rtos_queue_send_from_isr_failed: tstamp:2883940317 queue:0x0bcb8a60
kworker/0:2-1615 [000] .... 80.627257: rtos_queue_send_from_isr_failed: tstamp:2883940470 queue:0x0bcba5e0
kworker/0:2-1615 [000] .... 80.627258: rtos_queue_send_from_isr_failed: tstamp:2883940617 queue:0x0bcbb3a0
kworker/0:2-1615 [000] .... 80.627259: rtos_queue_send_from_isr_failed: tstamp:2883940763 queue:0x0bcbc160
kworker/0:2-1615 [000] .... 80.627260: rtos_queue_send_from_isr_failed: tstamp:2884029040 queue:0x0bcb41f8
kworker/0:2-1615 [000] .... 80.627261: rtos_queue_send_from_isr_failed: tstamp:2884029189 queue:0x0bcb8a60
kworker/0:2-1615 [000] .... 80.627262: rtos_queue_send_from_isr_failed: tstamp:2884029339 queue:0x0bcba5e0
kworker/0:2-1615 [000] .... 80.627290: rtos_queue_send_from_isr_failed: tstamp:2884029487 queue:0x0bcbb3a0
kworker/0:2-1615 [000] .... 80.627292: rtos_queue_send_from_isr_failed: tstamp:2884029632 queue:0x0bcbc160
kworker/0:2-1615 [000] .... 80.627294: rtcpu_vinotify_event: tstamp:2884290934 tag:RESERVED_18 channel:0x0b frame:0 vi_tstamp:2091879136 data:0x10000000
kworker/0:2-1615 [000] .... 80.627296: rtcpu_vinotify_event: tstamp:2884291100 tag:RESERVED_18 channel:0x0b frame:0 vi_tstamp:2091908800 data:0x31000002
kworker/0:2-1615 [000] .... 80.627298: rtos_queue_peek_from_isr_failed: tstamp:2885064889 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 80.795228: rtos_queue_peek_from_isr_failed: tstamp:2890064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 80.963281: rtos_queue_peek_from_isr_failed: tstamp:2895064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 81.131214: rtos_queue_peek_from_isr_failed: tstamp:2900064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 81.299226: rtos_queue_peek_from_isr_failed: tstamp:2905064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 81.411232: rtos_queue_peek_from_isr_failed: tstamp:2910064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 81.579224: rtos_queue_peek_from_isr_failed: tstamp:2915064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 81.747220: rtos_queue_peek_from_isr_failed: tstamp:2920064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 81.915236: rtos_queue_peek_from_isr_failed: tstamp:2925064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 82.083332: rtos_queue_peek_from_isr_failed: tstamp:2930064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 82.251228: rtos_queue_peek_from_isr_failed: tstamp:2935064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 82.419274: rtos_queue_peek_from_isr_failed: tstamp:2940064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 82.531221: rtos_queue_peek_from_isr_failed: tstamp:2945064881 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 82.699258: rtos_queue_peek_from_isr_failed: tstamp:2950064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 82.867232: rtos_queue_peek_from_isr_failed: tstamp:2955064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 83.035214: rtos_queue_peek_from_isr_failed: tstamp:2960064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 83.203221: rtos_queue_peek_from_isr_failed: tstamp:2965064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 83.371232: rtos_queue_peek_from_isr_failed: tstamp:2970064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 83.539259: rtos_queue_peek_from_isr_failed: tstamp:2975064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 83.651239: rtos_queue_send_from_isr_failed: tstamp:2978609962 queue:0x0bcb41f8
kworker/0:2-1615 [000] .... 83.651244: rtos_queue_send_from_isr_failed: tstamp:2978610115 queue:0x0bcb8a60
kworker/0:2-1615 [000] .... 83.651245: rtos_queue_send_from_isr_failed: tstamp:2978610268 queue:0x0bcba5e0
kworker/0:2-1615 [000] .... 83.651246: rtos_queue_send_from_isr_failed: tstamp:2978610414 queue:0x0bcbb3a0
kworker/0:2-1615 [000] .... 83.651247: rtos_queue_send_from_isr_failed: tstamp:2978610561 queue:0x0bcbc160
kworker/0:2-1615 [000] .... 83.651248: rtos_queue_send_from_isr_failed: tstamp:2978629964 queue:0x0bcb41f8
kworker/0:2-1615 [000] .... 83.651275: rtos_queue_send_from_isr_failed: tstamp:2978630112 queue:0x0bcb8a60
kworker/0:2-1615 [000] .... 83.651276: rtos_queue_send_from_isr_failed: tstamp:2978630261 queue:0x0bcba5e0
kworker/0:2-1615 [000] .... 83.651277: rtos_queue_send_from_isr_failed: tstamp:2978630409 queue:0x0bcbb3a0
kworker/0:2-1615 [000] .... 83.651278: rtos_queue_send_from_isr_failed: tstamp:2978630558 queue:0x0bcbc160
kworker/0:2-1615 [000] .... 83.651280: rtos_queue_peek_from_isr_failed: tstamp:2980064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 83.819230: rtos_queue_peek_from_isr_failed: tstamp:2985064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 83.987255: rtos_queue_peek_from_isr_failed: tstamp:2990064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 84.155249: rtos_queue_peek_from_isr_failed: tstamp:2995064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 84.323254: rtos_queue_peek_from_isr_failed: tstamp:3000064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 84.491228: rtos_queue_peek_from_isr_failed: tstamp:3005064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 84.659224: rtos_queue_peek_from_isr_failed: tstamp:3010064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 84.771225: rtos_queue_peek_from_isr_failed: tstamp:3015064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 84.939231: rtos_queue_peek_from_isr_failed: tstamp:3020064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 85.107250: rtos_queue_peek_from_isr_failed: tstamp:3025064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 85.275228: rtos_queue_peek_from_isr_failed: tstamp:3030064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 85.443235: rtos_queue_peek_from_isr_failed: tstamp:3035064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 85.611226: rtos_queue_peek_from_isr_failed: tstamp:3040064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 85.779248: rtos_queue_peek_from_isr_failed: tstamp:3045064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 85.891259: rtos_queue_peek_from_isr_failed: tstamp:3050064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 86.059246: rtos_queue_peek_from_isr_failed: tstamp:3055064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 86.227227: rtos_queue_peek_from_isr_failed: tstamp:3060064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 86.395230: rtos_queue_peek_from_isr_failed: tstamp:3065064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 86.563258: rtos_queue_peek_from_isr_failed: tstamp:3070064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 86.731235: rtos_queue_peek_from_isr_failed: tstamp:3075064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 86.899245: rtos_queue_peek_from_isr_failed: tstamp:3080064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 87.011227: rtos_queue_peek_from_isr_failed: tstamp:3085064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 87.179243: rtos_queue_peek_from_isr_failed: tstamp:3090064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 87.347248: rtos_queue_peek_from_isr_failed: tstamp:3095064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 87.515253: rtos_queue_peek_from_isr_failed: tstamp:3100064888 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 87.683227: rtos_queue_peek_from_isr_failed: tstamp:3105064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 87.851222: rtos_queue_peek_from_isr_failed: tstamp:3110064889 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 88.019223: rtos_queue_peek_from_isr_failed: tstamp:3115064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 88.131220: rtos_queue_peek_from_isr_failed: tstamp:3120064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 88.299225: rtos_queue_peek_from_isr_failed: tstamp:3125064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 88.467229: rtos_queue_peek_from_isr_failed: tstamp:3130064880 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 88.635225: rtos_queue_peek_from_isr_failed: tstamp:3135064887 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 88.803240: rtos_queue_peek_from_isr_failed: tstamp:3140064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 88.971263: rtos_queue_peek_from_isr_failed: tstamp:3145064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 89.139234: rtos_queue_peek_from_isr_failed: tstamp:3150064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 89.251232: rtos_queue_peek_from_isr_failed: tstamp:3155064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 89.419231: rtos_queue_peek_from_isr_failed: tstamp:3160064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 89.587265: rtos_queue_peek_from_isr_failed: tstamp:3165064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 89.755245: rtos_queue_peek_from_isr_failed: tstamp:3170064887 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 89.923227: rtos_queue_peek_from_isr_failed: tstamp:3175064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 90.091216: rtos_queue_peek_from_isr_failed: tstamp:3180064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 90.259244: rtos_queue_peek_from_isr_failed: tstamp:3185064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 90.371224: rtos_queue_peek_from_isr_failed: tstamp:3190064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 90.539257: rtos_queue_peek_from_isr_failed: tstamp:3195064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 90.707229: rtos_queue_peek_from_isr_failed: tstamp:3200064879 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 90.875254: rtos_queue_peek_from_isr_failed: tstamp:3205064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 91.043200: rtos_queue_peek_from_isr_failed: tstamp:3210064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 91.211224: rtos_queue_peek_from_isr_failed: tstamp:3215064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 91.379220: rtos_queue_peek_from_isr_failed: tstamp:3220064888 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 91.491256: rtos_queue_peek_from_isr_failed: tstamp:3225064883 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 91.659224: rtos_queue_peek_from_isr_failed: tstamp:3230064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 91.827222: rtos_queue_peek_from_isr_failed: tstamp:3235064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 91.995222: rtos_queue_peek_from_isr_failed: tstamp:3240064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 92.163221: rtos_queue_peek_from_isr_failed: tstamp:3245064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 92.331249: rtos_queue_peek_from_isr_failed: tstamp:3250064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 92.499228: rtos_queue_peek_from_isr_failed: tstamp:3255064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 92.611244: rtos_queue_peek_from_isr_failed: tstamp:3260064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 92.779251: rtos_queue_peek_from_isr_failed: tstamp:3265064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 92.947223: rtos_queue_peek_from_isr_failed: tstamp:3270064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 93.115209: rtos_queue_peek_from_isr_failed: tstamp:3275064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 93.283218: rtos_queue_peek_from_isr_failed: tstamp:3280064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 93.451224: rtos_queue_peek_from_isr_failed: tstamp:3285064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 93.619266: rtos_queue_peek_from_isr_failed: tstamp:3290064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 93.731233: rtos_queue_peek_from_isr_failed: tstamp:3295064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 93.899225: rtos_queue_peek_from_isr_failed: tstamp:3300064887 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 94.067255: rtos_queue_peek_from_isr_failed: tstamp:3305064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 94.235269: rtos_queue_peek_from_isr_failed: tstamp:3310064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 94.403227: rtos_queue_peek_from_isr_failed: tstamp:3315064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 94.571227: rtos_queue_peek_from_isr_failed: tstamp:3320064888 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 94.739225: rtos_queue_peek_from_isr_failed: tstamp:3325064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 94.851233: rtos_queue_peek_from_isr_failed: tstamp:3330064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 95.019230: rtos_queue_peek_from_isr_failed: tstamp:3335064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 95.187227: rtos_queue_peek_from_isr_failed: tstamp:3340064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 95.355222: rtos_queue_peek_from_isr_failed: tstamp:3345064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 95.523230: rtos_queue_peek_from_isr_failed: tstamp:3350064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 95.691246: rtos_queue_peek_from_isr_failed: tstamp:3355064887 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 95.859258: rtos_queue_peek_from_isr_failed: tstamp:3360064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 95.971219: rtos_queue_peek_from_isr_failed: tstamp:3365064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 96.139253: rtos_queue_peek_from_isr_failed: tstamp:3370064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 96.307226: rtos_queue_peek_from_isr_failed: tstamp:3375064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 96.475228: rtos_queue_peek_from_isr_failed: tstamp:3380064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 96.643252: rtos_queue_peek_from_isr_failed: tstamp:3385064880 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 96.811226: rtos_queue_peek_from_isr_failed: tstamp:3390064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 96.979213: rtos_queue_peek_from_isr_failed: tstamp:3395064897 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 97.091218: rtos_queue_peek_from_isr_failed: tstamp:3400064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 97.259213: rtos_queue_peek_from_isr_failed: tstamp:3405064887 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 97.427229: rtos_queue_peek_from_isr_failed: tstamp:3410064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 97.595248: rtos_queue_peek_from_isr_failed: tstamp:3415064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 97.763243: rtos_queue_peek_from_isr_failed: tstamp:3420064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 97.931223: rtos_queue_peek_from_isr_failed: tstamp:3425064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 98.099227: rtos_queue_peek_from_isr_failed: tstamp:3430064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 98.211223: rtos_queue_peek_from_isr_failed: tstamp:3435064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 98.379223: rtos_queue_peek_from_isr_failed: tstamp:3440064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 98.547229: rtos_queue_peek_from_isr_failed: tstamp:3445064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 98.715219: rtos_queue_peek_from_isr_failed: tstamp:3450064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 98.883248: rtos_queue_peek_from_isr_failed: tstamp:3455064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 99.051227: rtos_queue_peek_from_isr_failed: tstamp:3460064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 99.219226: rtos_queue_peek_from_isr_failed: tstamp:3465064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 99.331216: rtos_queue_peek_from_isr_failed: tstamp:3470064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 99.499247: rtos_queue_peek_from_isr_failed: tstamp:3475064888 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 99.667246: rtos_queue_peek_from_isr_failed: tstamp:3480064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 99.835242: rtos_queue_peek_from_isr_failed: tstamp:3485064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 100.003226: rtos_queue_peek_from_isr_failed: tstamp:3490064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 100.171215: rtos_queue_peek_from_isr_failed: tstamp:3495064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 100.339213: rtos_queue_peek_from_isr_failed: tstamp:3500064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 100.451218: rtos_queue_peek_from_isr_failed: tstamp:3505064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 100.619221: rtos_queue_peek_from_isr_failed: tstamp:3510064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 100.787246: rtos_queue_peek_from_isr_failed: tstamp:3515064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 100.955237: rtos_queue_peek_from_isr_failed: tstamp:3520064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 101.123222: rtos_queue_peek_from_isr_failed: tstamp:3525064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 101.291235: rtos_queue_peek_from_isr_failed: tstamp:3530064887 queue:0x0bcbcf78[ 124.240208] tegra-i2c 3190000.i2c: rx dma timeout txlen:28 rxlen:128
kworker/0:2-1615 [000] .... 101.459244: rtos_queue_peek_from_isr_failed: tstamp:3535064884 queue:0x0bcbcf78[ 124.256885] tegra-i2c 3190000.i2c: --- register dump for debugging ----
[ 124.264000] tegra-i2c 3190000.i2c: I2C_CNFG - 0x22c00
[ 124.269107] tegra-i2c 3190000.i2c: I2C_PACKET_TRANSFER_STATUS - 0x10001
kworker/0:2-1615 [000] .... 101.571218: rtos_queue_peek_from_isr_failed: tstamp:3540064884 queue:0x0bcbcf78[ 124.277509] tegra-i2c 3190000.i2c: I2C_FIFO_CONTROL - 0x0
kworker/0:2-1615 [000] .... 101.739219: rtos_queue_peek_from_isr_failed: tstamp:3545064884 queue:0x0bcbcf78[ 124.292129] tegra-i2c 3190000.i2c: I2C_FIFO_STATUS - 0x800080
kworker/0:2-1615 [000] .... 101.907222: rtos_queue_peek_from_isr_failed: tstamp:3550064884 queue:0x0bcbcf78[ 124.308134] tegra-i2c 3190000.i2c: I2C_MST_FIFO_CONTROL - 0x70
kworker/0:2-1615 [000] .... 102.075223: rtos_queue_peek_from_isr_failed: tstamp:3555064884 queue:0x0bcbcf78[ 124.324307] tegra-i2c 3190000.i2c: I2C_MST_FIFO_STATUS - 0x7c0000
[ 124.340856] tegra-i2c 3190000.i2c: I2C_MST_PACKET_TRANSFER_CNT - 0x0
kworker/0:2-1615 [000] .... 102.243213: rtos_queue_peek_from_isr_failed: tstamp:3560064884 queue:0x0bcbcf78[ 124.347595] tegra-i2c 3190000.i2c: I2C_INT_MASK - 0x6c
[ 124.362415] tegra-i2c 3190000.i2c: I2C_INT_STATUS - 0x2
kworker/0:2-1615 [000] .... 102.411227: rtos_queue_peek_from_isr_fai[ 124.368690] tegra-i2c 3190000.i2c: i2c transfer timed out addr: 0x50
led: tstamp:3565064884 queue:0x0bcbcf78[ 124.381841] tegradc 15200000.nvdisplay: hdmi: edid read failed
kworker/0:2-1615 [000] .... 102.579233: rtos_queue_peek_from_isr_failed: tstamp:3570064880 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 102.691255: rtos_queue_peek_from_isr_failed: tstamp:3575064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 102.859245: rtos_queue_peek_from_isr_failed: tstamp:3580064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 103.027243: rtos_queue_peek_from_isr_failed: tstamp:3585064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 103.195218: rtos_queue_peek_from_isr_failed: tstamp:3590064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 103.363214: rtos_queue_peek_from_isr_failed: tstamp:3595064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 103.531259: rtos_queue_peek_from_isr_failed: tstamp:3600064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 103.699230: rtos_queue_peek_from_isr_failed: tstamp:3605064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 103.811220: rtos_queue_peek_from_isr_failed: tstamp:3610064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 103.979224: rtos_queue_peek_from_isr_failed: tstamp:3615064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 104.147223: rtos_queue_peek_from_isr_failed: tstamp:3620064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 104.315244: rtos_queue_peek_from_isr_failed: tstamp:3625064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 104.483217: rtos_queue_peek_from_isr_failed: tstamp:3630064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 104.651222: rtos_queue_peek_from_isr_failed: tstamp:3635064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 104.819223: rtos_queue_peek_from_isr_failed: tstamp:3640064880 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 104.931222: rtos_queue_peek_from_isr_failed: tstamp:3645064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 105.099216: rtos_queue_peek_from_isr_failed: tstamp:3650064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 105.267214: rtos_queue_peek_from_isr_failed: tstamp:3655064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 105.435261: rtos_queue_peek_from_isr_failed: tstamp:3660064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 105.603223: rtos_queue_peek_from_isr_failed: tstamp:3665064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 105.771215: rtos_queue_peek_from_isr_failed: tstamp:3670064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 105.939218: rtos_queue_peek_from_isr_failed: tstamp:3675064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 106.051225: rtos_queue_peek_from_isr_failed: tstamp:3680064889 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 106.219219: rtos_queue_peek_from_isr_failed: tstamp:3685064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 106.387226: rtos_queue_peek_from_isr_failed: tstamp:3690064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 106.555225: rtos_queue_peek_from_isr_failed: tstamp:3695064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 106.723243: rtos_queue_peek_from_isr_failed: tstamp:3700064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 106.891251: rtos_queue_peek_from_isr_failed: tstamp:3705064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 107.059222: rtos_queue_peek_from_isr_failed: tstamp:3710064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 107.171224: rtos_queue_peek_from_isr_failed: tstamp:3715064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 107.339217: rtos_queue_peek_from_isr_failed: tstamp:3720064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 107.507256: rtos_queue_peek_from_isr_failed: tstamp:3725064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 107.675216: rtos_queue_peek_from_isr_failed: tstamp:3730064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 107.843214: rtos_queue_peek_from_isr_failed: tstamp:3735064887 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 108.011230: rtos_queue_peek_from_isr_failed: tstamp:3740064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 108.179217: rtos_queue_peek_from_isr_failed: tstamp:3745064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 108.291210: rtos_queue_peek_from_isr_failed: tstamp:3750064889 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 108.459223: rtos_queue_peek_from_isr_failed: tstamp:3755064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 108.627220: rtos_queue_peek_from_isr_failed: tstamp:3760064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 108.795222: rtos_queue_peek_from_isr_failed: tstamp:3765064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 108.963220: rtos_queue_peek_from_isr_failed: tstamp:3770064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 109.131216: rtos_queue_peek_from_isr_failed: tstamp:3775064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 109.299219: rtos_queue_peek_from_isr_failed: tstamp:3780064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 109.411226: rtos_queue_peek_from_isr_failed: tstamp:3785064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 109.579259: rtos_queue_peek_from_isr_failed: tstamp:3790064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 109.747248: rtos_queue_peek_from_isr_failed: tstamp:3795064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 109.915249: rtos_queue_peek_from_isr_failed: tstamp:3800064887 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 110.083250: rtos_queue_peek_from_isr_failed: tstamp:3805064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 110.251214: rtos_queue_peek_from_isr_failed: tstamp:3810064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 110.419218: rtos_queue_peek_from_isr_failed: tstamp:3815064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 110.531225: rtos_queue_peek_from_isr_failed: tstamp:3820064887 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 110.699212: rtos_queue_peek_from_isr_failed: tstamp:3825064881 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 110.867217: rtos_queue_peek_from_isr_failed: tstamp:3830064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 111.035220: rtos_queue_peek_from_isr_failed: tstamp:3835064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 111.203250: rtos_queue_peek_from_isr_failed: tstamp:3840064887 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 111.371221: rtos_queue_peek_from_isr_failed: tstamp:3845064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 111.539336: rtos_queue_peek_from_isr_failed: tstamp:3850064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 111.651327: rtos_queue_peek_from_isr_failed: tstamp:3855064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 111.819216: rtos_queue_peek_from_isr_failed: tstamp:3860064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 111.987239: rtos_queue_peek_from_isr_failed: tstamp:3865064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 112.155231: rtos_queue_peek_from_isr_failed: tstamp:3870064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 112.323237: rtos_queue_peek_from_isr_failed: tstamp:3875064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 112.491238: rtos_queue_peek_from_isr_failed: tstamp:3880064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 112.659234: rtos_queue_peek_from_isr_failed: tstamp:3885064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 112.771268: rtos_queue_peek_from_isr_failed: tstamp:3890064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 112.939234: rtos_queue_peek_from_isr_failed: tstamp:3895064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 113.107229: rtos_queue_peek_from_isr_failed: tstamp:3900064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 113.275245: rtos_queue_peek_from_isr_failed: tstamp:3905064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 113.443241: rtos_queue_peek_from_isr_failed: tstamp:3910064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 113.611237: rtos_queue_peek_from_isr_failed: tstamp:3915064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 113.779240: rtos_queue_peek_from_isr_failed: tstamp:3920064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 113.891234: rtos_queue_peek_from_isr_failed: tstamp:3925064883 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 114.059219: rtos_queue_peek_from_isr_failed: tstamp:3930064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 114.227210: rtos_queue_peek_from_isr_failed: tstamp:3935064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 114.395285: rtos_queue_peek_from_isr_failed: tstamp:3940064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 114.563277: rtos_queue_peek_from_isr_failed: tstamp:3945064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 114.731205: rtos_queue_peek_from_isr_failed: tstamp:3950064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 114.899268: rtos_queue_peek_from_isr_failed: tstamp:3955064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 115.011247: rtos_queue_peek_from_isr_failed: tstamp:3960064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 115.179231: rtos_queue_peek_from_isr_failed: tstamp:3965064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 115.347235: rtos_queue_peek_from_isr_failed: tstamp:3970064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 115.515235: rtos_queue_peek_from_isr_failed: tstamp:3975064887 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 115.683220: rtos_queue_peek_from_isr_failed: tstamp:3980064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 115.851214: rtos_queue_peek_from_isr_failed: tstamp:3985064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 116.019212: rtos_queue_peek_from_isr_failed: tstamp:3990064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 116.131208: rtos_queue_peek_from_isr_failed: tstamp:3995064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 116.299206: rtos_queue_peek_from_isr_failed: tstamp:4000064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 116.467207: rtos_queue_peek_from_isr_failed: tstamp:4005064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 116.635214: rtos_queue_peek_from_isr_failed: tstamp:4010064880 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 116.803208: rtos_queue_peek_from_isr_failed: tstamp:4015064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 116.971214: rtos_queue_peek_from_isr_failed: tstamp:4020064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 117.139215: rtos_queue_peek_from_isr_failed: tstamp:4025064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 117.251218: rtos_queue_peek_from_isr_failed: tstamp:4030064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 117.419213: rtos_queue_peek_from_isr_failed: tstamp:4035064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 117.587211: rtos_queue_peek_from_isr_failed: tstamp:4040064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 117.755214: rtos_queue_peek_from_isr_failed: tstamp:4045064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 117.923245: rtos_queue_peek_from_isr_failed: tstamp:4050064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 118.091210: rtos_queue_peek_from_isr_failed: tstamp:4055064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 118.259217: rtos_queue_peek_from_isr_failed: tstamp:4060064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 118.371208: rtos_queue_peek_from_isr_failed: tstamp:4065064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 118.539237: rtos_queue_peek_from_isr_failed: tstamp:4070064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 118.707206: rtos_queue_peek_from_isr_failed: tstamp:4075064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 118.875206: rtos_queue_peek_from_isr_failed: tstamp:4080064881 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 119.043221: rtos_queue_peek_from_isr_failed: tstamp:4085064884 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 119.211205: rtos_queue_peek_from_isr_failed: tstamp:4090064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 119.379204: rtos_queue_peek_from_isr_failed: tstamp:4095064885 queue:0x0bcbcf78
kworker/0:2-1615 [000] .... 119.491207: rtos_queue_peek_from_isr_failed: tstamp:4100064884 queue:0x0bcbcf78
Here is the media command result:
root@srnav-desktop:/home/srnav# sudo media-ctl -p -d /dev/media0
Media controller API version 0.1.0
Media device information
driver tegra194-vi5
model NVIDIA Tegra Video Input Device
serial
bus info
hw revision 0x3
driver version 0.0.0
Device topology
- entity 1: imx274 30-001a (1 pad, 1 link)
type V4L2 subdev subtype Sensor flags 0
device node name /dev/v4l-subdev0
pad0: Source
[fmt:SRGGB10_1X10/1920x1080 field:none colorspace:srgb]
-> "15a00000.nvcsi--3":0 [ENABLED]
- entity 3: 15a00000.nvcsi--3 (2 pads, 2 links)
type V4L2 subdev subtype Unknown flags 0
device node name /dev/v4l-subdev1
pad0: Sink
<- "imx274 30-001a":0 [ENABLED]
pad1: Source
-> "vi-output, imx274 30-001a":0 [ENABLED]
- entity 6: vi-output, imx274 30-001a (1 pad, 1 link)
type Node subtype V4L flags 0
device node name /dev/video0
pad0: Sink
<- "15a00000.nvcsi--3":1 [ENABLED]
- entity 18: imx274 31-001a (1 pad, 1 link)
device node name /dev/v4l-subdev2
pad0: Source
[fmt:SRGGB10_1X10/3840x2160 field:none colorspace:srgb]
-> "15a00000.nvcsi--2":0 [ENABLED]
- entity 20: 15a00000.nvcsi--2 (2 pads, 2 links)
device node name /dev/v4l-subdev3
pad0: Sink
<- "imx274 31-001a":0 [ENABLED]
pad1: Source
-> "vi-output, imx274 31-001a":0 [ENABLED]
- entity 23: vi-output, imx274 31-001a (1 pad, 1 link)
device node name /dev/video1
pad0: Sink
<- "15a00000.nvcsi--2":1 [ENABLED]
- entity 35: imx274 32-001a (1 pad, 1 link)
device node name /dev/v4l-subdev4
pad0: Source
-> "15a00000.nvcsi--1":0 [ENABLED]
- entity 37: 15a00000.nvcsi--1 (2 pads, 2 links)
device node name /dev/v4l-subdev5
pad0: Sink
<- "imx274 32-001a":0 [ENABLED]
pad1: Source
-> "vi-output, imx274 32-001a":0 [ENABLED]
- entity 40: vi-output, imx274 32-001a (1 pad, 1 link)
device node name /dev/video2
pad0: Sink
<- "15a00000.nvcsi--1":1 [ENABLED]
Where exactly should the dev_dbg messages be printing out? I checked dmesg, my serial screen and trace and I don’t see any of the dbg messages there.
