As per the documentation an AWS S3 bucket is required to use/setup the CARLA with Nvidia Omniverse APIs. Is it possible to setup without AWS S3 Bucket (any possibility with local setup)? Also how to connect with Nvidia to get the user arn added?
Thanks for the question. Can you start by linking me directly to the tutorial or resource you are following?
Hi Richard, Thank you for your response. These instructions are present in the ngc collection named “NVIDIA Enhancing CARLA with NVIDIA Omniverse“ (early access).
I am sorry, but I am not sure if you can download the files locally. It may be required for the setup. What you could do is follow the instructions, for AWS and then once you have everything loaded and installed and working, just clone it locally to your machine.
If you are accessing this, you are probably an Enterprise user. I would recommend reaching out to your Enterprise Rep.
