Omniverse on AWS environment
Hi, we want to confirm whether we can use Omniverse on AWS environment or no.
My understanding is that Nucleus and Cache sever may work on AWS environment
even if AWS instance does not have RTX.
But applications regarding RTX Renderer ( Omniverse View, Create ) may not work
if AWS instance which does not have Ampere base RTX.
Currently it looks EC2 P4d of AWS uses NVIDIA A100 and A100 is Ampere architecture.
In this case, can we use omniverse application ( View, Create ) on this instance?
Masahiro Suzuoki
Hello @nirsatia1890! Thanks for reaching out. I have forwarded this to our development team.
I have used this AWS instance type for Create.
Thank you for the answer!
I could create Omniverse environment by using the same AWS instance.
Hello @WendyGram and @mirice ,
I have tried to do the same but for some reason I cannot see Create and View as a downloadable option in Omniverse Exchange tab. Any idea what could be the reason.
I used a g4dn.2xlarge system (which uses Tesla T4 GPUs) with 320gb of ebs storage in AWS and my driver version is: 537.7
@siddharth.singi those apps have been rebranded (in name only). Create is now Composer; and View as Presenter. you will need a RTX card to use OV last i checked.
