Best way to connect 3 different displays to Jetson AGX Xavier
Hi there,
I am planning to use Jetson AGX Xavier and have to use 3 different display (finally, it will be connected to HD-SDI for a long distance transport). Questions!
  1. Is it possible to configure 3 different monitor? Theoretically possible but not quite sure if there’s any hurdle.
  2. If yes, what is the best configuration as the output? Using 2 DP and 1 HDMI? Or, Use 1 HDMI and 2x MIPI DSI2?
  3. What is the most stableJetpack version and SOM module? Any good carrier board found?
Any comments are welcome!
By default we support 1 DP + 1 HDMI on Xavier series. Would suggest use this setup. 3 displays are not validated.
Xavier series use Jetpack 5 and the latest version is Jetpack 5.1.5 r35.6.2:
Jetson Linux | NVIDIA Developer
Thanks a million.
I need 3 display.
Any suggestion by anybody?
