Thanks @WayneWWW .
I am able to get the 3rd DP display working. I have done the changes as you mentioned.
But now this dp display is acting as primary display.
If i dont connect this dp display and other 2 dp displays connected i am not seeing the bootup logs. Also if i try to stream camera without this dp display am not getting the output on the other screens.
For reference i have attached my changes, dp3.txt (9.9 KB)
Do you have dmesg to share when the error happens?
