I am using a HDMI-to-VGA adapter to connect nano and a VGA monitor. It worked several days ago. But now I get no display.
Below is the result of dmesg.
Anyone can help me?
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.9.140-tegra (buildbrain@mobile-u64-3531) (gcc version 7.3.1 20180425 [linaro-7.3-2018.05 revision d29120a424ecfbc167ef90065c0eeb7f91977701] (Linaro GCC 7.3-2018.05) ) #1 SMP PREEMPT Wed Mar 13 00:32:22 PDT 2019
[ 0.000000] Boot CPU: AArch64 Processor [411fd071]
[ 0.000000] OF: fdt:memory scan node memory@80000000, reg size 48,
[ 0.000000] OF: fdt: - 80000000 , 7ee00000
[ 0.000000] OF: fdt: - 100000000 , 7f200000
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb0_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: fdt:Reserved memory: failed to reserve memory for node ‘fb1_carveout’: base 0x0000000000000000, size 0 MiB
[ 0.000000] OF: reserved mem: initialized node vpr-carveout, compatible id nvidia,vpr-carveout
[ 0.000000] OF: reserved mem: initialized node iram-carveout, compatible id nvidia,iram-carveout
[ 0.000000] OF: reserved mem: initialized node ramoops_carveout, compatible id nvidia,ramoops
[ 0.000000] cma: Reserved 64 MiB at 0x00000000fac00000
[ 0.000000] On node 0 totalpages: 1039872
[ 0.000000] DMA zone: 8192 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 519168 pages, LIFO batch:31
[ 0.000000] Normal zone: 8136 pages used for memmap
[ 0.000000] Normal zone: 520704 pages, LIFO batch:31
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.1
[ 0.000000] percpu: Embedded 23 pages/cpu @ffffffc0fefd2000 s53400 r8192 d32616 u94208
[ 0.000000] pcpu-alloc: s53400 r8192 d32616 u94208 alloc=23*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] CPU features: enabling workaround for ARM erratum 832075
[ 0.000000] Speculative Store Bypass Disable mitigation not required
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 1023544
[ 0.000000] Kernel command line: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,0 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 rootfstype=ext4 root=/dev/mmcblk0p1 rw rootwait
[ 0.000000] log_buf_len individual max cpu contribution: 32768 bytes
[ 0.000000] log_buf_len total cpu_extra contributions: 98304 bytes
[ 0.000000] log_buf_len min size: 32768 bytes
[ 0.000000] log_buf_len: 131072 bytes
[ 0.000000] early log buf free: 29492(90%)
[ 0.000000] PID hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.000000] Dentry cache hash table entries: 524288 (order: 10, 4194304 bytes)
[ 0.000000] Inode-cache hash table entries: 262144 (order: 9, 2097152 bytes)
[ 0.000000] Memory: 3576064K/4159488K available (15166K kernel code, 2914K rwdata, 6616K rodata, 8512K init, 605K bss, 108288K reserved, 475136K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] modules : 0xffffff8000000000 - 0xffffff8008000000 ( 128 MB)
[ 0.000000] vmalloc : 0xffffff8008000000 - 0xffffffbebfff0000 ( 250 GB)
[ 0.000000] .text : 0xffffff8008080000 - 0xffffff8008f50000 ( 15168 KB)
[ 0.000000] .rodata : 0xffffff8008f50000 - 0xffffff80095d0000 ( 6656 KB)
[ 0.000000] .init : 0xffffff80095d0000 - 0xffffff8009e20000 ( 8512 KB)
[ 0.000000] .data : 0xffffff8009e20000 - 0xffffff800a0f8808 ( 2915 KB)
[ 0.000000] .bss : 0xffffff800a0f8808 - 0xffffff800a18fe3c ( 606 KB)
[ 0.000000] fixed : 0xffffffbefe7fd000 - 0xffffffbefec00000 ( 4108 KB)
[ 0.000000] PCI I/O : 0xffffffbefee00000 - 0xffffffbeffe00000 ( 16 MB)
[ 0.000000] vmemmap : 0xffffffbf00000000 - 0xffffffc000000000 ( 4 GB maximum)
[ 0.000000] 0xffffffbf00000000 - 0xffffffbf03fc8000 ( 63 MB actual)
[ 0.000000] memory : 0xffffffc000000000 - 0xffffffc0ff200000 ( 4082 MB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 64.
[ 0.000000] RCU restricting CPUs from NR_CPUS=64 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=64, nr_cpu_ids=4
[ 0.000000] NR_IRQS:64 nr_irqs:64 0
[ 0.000000] /interrupt-controller@60004000: 192 interrupts forwarded to /interrupt-controller
[ 0.000000] t210 clock and reset probe
[ 0.000000] tegra-pmc: get_secure_pmc_setting: done secure_pmc=1
[ 0.000000] clk_cbus_recalc_rate: no gbus parent
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000006] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.001479] Console: colour dummy device 80x25
[ 0.002330] console [tty0] enabled
[ 0.002356] kmemleak: Kernel memory leak detector disabled
[ 0.002383] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=76800)
[ 0.002410] pid_max: default: 32768 minimum: 301
[ 0.002874] Security Framework initialized
[ 0.003106] Mount-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.003126] Mountpoint-cache hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.004332] ftrace: allocating 46802 entries in 183 pages
[ 0.174233] sched-energy: CPU device node has no sched-energy-costs
[ 0.174265] ASID allocator initialised with 65536 entries
[ 0.211329] tegra-id: chipid=22117.
[ 0.211367] tegra-id: opt_subrevision=0.
[ 0.211397] Tegra Speedo/IDDQ fuse revision 4
[ 0.211413] Tegra: CPU Speedo ID 9, SoC Speedo ID 0, GPU Speedo ID 2
[ 0.211429] Tegra: CPU Process ID 0, SoC Process ID 1, GPU Process ID 0
[ 0.211445] Tegra: CPU Speedo Value 2081, SoC Speedo Value 1982, GPU Speedo Value 2095
[ 0.211466] Tegra: CPU IDDQ Value 2356, SoC IDDQ Value 2736, GPU IDDQ Value 3510
[ 0.211501] Tegra Revision: A02 SKU: 0x8f CPU Process: 0 SoC Process: 1
[ 0.211527] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02.dts
[ 0.211561] DTB Build time: Mar 15 2019 09:52:07
[ 0.261051] CPU1: Booted secondary processor [411fd071]
[ 0.292952] CPU2: Booted secondary processor [411fd071]
[ 0.324949] CPU3: Booted secondary processor [411fd071]
[ 0.325036] Brought up 4 CPUs
[ 0.325099] SMP: Total of 4 processors activated.
[ 0.325116] CPU features: detected feature: 32-bit EL0 Support
[ 0.325396] CPU: All CPU(s) started at EL2
[ 0.325425] alternatives: patching kernel code
[ 0.333419] devtmpfs: initialized
[ 0.368012] Initilizing CustomIPI irq domain
[ 0.368418] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.368466] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.378959] pinctrl core: initialized pinctrl subsystem
[ 0.379596] OS set in device tree is not L4T.
[ 0.380012] regulator-dummy: no parameters
[ 0.380288] Initializing plugin-manager
[ 0.380453] Plugin module not found
[ 0.380668] node /plugin-manager/fragement@0 match with board >=3448-0000-100
[ 0.381257] node /plugin-manager/fragment@1 match with board >=3448-0000-101
[ 0.382004] node /plugin-manager/fragment@5 match with board 3449-0000-200
[ 0.385164] NET: Registered protocol family 16
[ 0.388634] pstore: using zlib compression
[ 0.389294] console [pstore-1] enabled
[ 0.389311] pstore: Registered ramoops as persistent store backend
[ 0.389331] ramoops: attached 0x200000@0xb0000000, ecc: 0/0
[ 0.405068] cpuidle: using governor menu
[ 0.408931] tegra_smmu 70019000.iommu: Loaded Tegra IOMMU driver
[ 0.410420] vdso: 2 pages (1 code @ ffffff8008f57000, 1 data @ ffffff8009e24000)
[ 0.410463] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.413509] atomic_pool_init():622: DMA: preallocated 1024 KiB pool for atomic allocations
[ 0.415064] tegra_bpmp_of_clk_init: EMC proxy not found.
[ 0.416011] tegra_powergate_init: DONE
[ 0.416053] DTS File Name: /dvs/git/dirty/git-master_linux/kernel/kernel-4.9/arch/arm64/boot/dts/…/…/…/…/…/…/hardware/nvidia/platform/t210/porg/kernel-dts/tegra210-p3448-0000-p3449-0000-a02.dts
[ 0.416089] DTB Build time: Mar 15 2019 09:52:07
[ 0.417805] Tegra reboot handler registered.
[ 0.422130] iommu: Adding device tegra-carveouts to group 0
[ 0.422305] platform tegra-carveouts: domain=ffffffc0f9408318 allocates as[0]=ffffffc0f9b940a8
[ 0.422673] iommu: Adding device smmu_test to group 1
[ 0.422740] platform smmu_test: domain=ffffffc0f9408558 allocates as[0]=ffffffc0f9b94110
[ 0.423574] mc: mapped MMIO address: 0xffffff800802e000 → 0x70019000
[ 0.423648] mc: mapped MMIO address: 0xffffff8008065000 → 0x7001c000
[ 0.423720] mc: mapped MMIO address: 0xffffff8008079000 → 0x7001d000
[ 0.423742] nv-tegra-mc 70019000.mc: No mssnvlink node
[ 0.423776] mc-err: mcerr ops are set to t21x
[ 0.433486] iommu: Adding device 70090000.xusb to group 2
[ 0.433788] iommu: Adding device 70006000.serial to group 3
[ 0.433893] platform 70006000.serial: domain=ffffffc0f9484618 allocates as[0]=ffffffc0f9b94178
[ 0.434315] iommu: Adding device 70006040.serial to group 4
[ 0.434603] iommu: Adding device 70006200.serial to group 5
[ 0.434838] iommu: Adding device sound to group 6
[ 0.434899] platform sound: domain=ffffffc0f9484b58 allocates as[0]=ffffffc0f9b941e0
[ 0.435467] iommu: Adding device 7000d400.spi to group 7
[ 0.435736] iommu: Adding device 7000d600.spi to group 8
[ 0.436026] iommu: Adding device 70410000.spi to group 9
[ 0.436339] iommu: Adding device 50000000.host1x to group 10
[ 0.436626] iommu: Adding device 54080000.vi to group 11
[ 0.437064] iommu: Adding device 54600000.isp to group 12
[ 0.437347] iommu: Adding device 54680000.isp to group 13
[ 0.437674] iommu: Adding device tegradc.0 to group 14
[ 0.437746] platform tegradc.0: domain=ffffffc0f9491a98 allocates as[0]=ffffffc0f9b94248
[ 0.438281] platform tegradc.0: IOVA linear map 0x00000000d7000000(19000000)
[ 0.438608] iommu: Adding device tegradc.1 to group 15
[ 0.438671] platform tegradc.1: domain=ffffffc0f9491cd8 allocates as[0]=ffffffc0f9b942b0
[ 0.439197] platform tegradc.1: IOVA linear map 0x00000000d7000000(19000000)
[ 0.439460] iommu: Adding device 54340000.vic to group 16
[ 0.439687] iommu: Adding device 544c0000.nvenc to group 17
[ 0.439900] iommu: Adding device 54500000.tsec to group 18
[ 0.440113] iommu: Adding device 54100000.tsecb to group 19
[ 0.440327] iommu: Adding device 54480000.nvdec to group 20
[ 0.440555] iommu: Adding device 54380000.nvjpg to group 21
[ 0.441681] iommu: Adding device 546c0000.i2c to group 22
[ 0.442026] iommu: Adding device 57000000.gpu to group 23
[ 0.442093] platform 57000000.gpu: domain=ffffffc0f949dcd8 allocates as[0]=ffffffc0f9b94318
[ 0.442153] platform 57000000.gpu: domain=ffffffc0f949dcd8 allocates as[1]=ffffffc0f9b94380
[ 0.442212] platform 57000000.gpu: domain=ffffffc0f949dcd8 allocates as[2]=ffffffc0f9b943e8
[ 0.442271] platform 57000000.gpu: domain=ffffffc0f949dcd8 allocates as[3]=ffffffc0f9b94450
[ 0.443170] tegra-pmc 7000e400.pmc: i2c-thermtrip node not found, emergency thermal reset disabled.
[ 0.443212] tegra-pmc 7000e400.pmc: scratch reg offset dts data not present
[ 0.443239] tegra-pmc: ### PMC reset source: TEGRA_SOFTWARE_RESET
[ 0.443260] tegra-pmc: ### PMC reset level: TEGRA_RESET_LEVEL_WARM
[ 0.443276] tegra-pmc: ### PMC reset status reg: 0x3
[ 0.493130] padctrl padctrl.0: Pad control driver tegra-pmc-padctrl registered
[ 0.493164] tegra-pmc: Clear bootloader IO dpd settings
[ 0.493197] tegra-pmc 7000e400.pmc: IO padctrl driver initialized
[ 0.493277] tegra-pmc 7000e400.pmc: PMC: Successfully configure bootrom reset commands
[ 0.493593] iommu: Adding device 70012000.se to group 24
[ 0.494447] iommu: Adding device 7000c000.i2c to group 25
[ 0.494779] iommu: Adding device 7000c400.i2c to group 26
[ 0.495098] iommu: Adding device 7000c500.i2c to group 27
[ 0.495402] iommu: Adding device 7000c700.i2c to group 28
[ 0.495753] iommu: Adding device 7000d000.i2c to group 29
[ 0.496067] iommu: Adding device 7000d100.i2c to group 30
[ 0.496421] iommu: Adding device sdhci-tegra.0 to group 31
[ 0.496491] platform sdhci-tegra.0: domain=ffffffc0f9524e58 allocates as[0]=ffffffc0f9b944b8
[ 0.497494] iommu: Adding device 700d0000.xudc to group 32
[ 0.503079] vdd-ac-bat: 5000 mV
[ 0.503504] vdd-5v0-sys: 5000 mV
[ 0.504655] vdd-5v0-hdmi: supplied by vdd-5v0-sys
[ 0.504743] vdd-5v0-hdmi: 5000 mV
[ 0.505199] vdd-1v8: 1800 mV
[ 0.505653] vdd-fan: supplied by vdd-5v0-sys
[ 0.505707] vdd-fan: 5000 mV
[ 0.506112] vdd-usb-vbus: supplied by vdd-5v0-sys
[ 0.506186] vdd-usb-vbus: 5000 mV
[ 0.506703] vdd-usb-vbus2: 5000 mV
[ 0.538233] HugeTLB registered 2 MB page size, pre-allocated 0 pages
[ 0.540837] GPIO line 151 (camera-control-output-low) hogged as output/low
[ 0.541462] gpiochip_setup_dev: registered GPIOs 0 to 255 on device: gpiochip0 (tegra-gpio)
[ 0.549811] eventlib_kernel: keventlib is initialized, test id: 0
[ 0.550201] SCSI subsystem initialized
[ 0.550470] libata version 3.00 loaded.
[ 0.550743] usbcore: registered new interface driver usbfs
[ 0.550813] usbcore: registered new interface driver hub
[ 0.550909] usbcore: registered new device driver usb
[ 0.554992] max77620 4-003c: PMIC Version OTP:0x35 and ES:0x8
[ 0.556553] random: fast init done
[ 0.560430] vdd-core: 600 <–> 1162 mV at 1075 mV
[ 0.561595] vdd-ddr-1v1: Bringing 1125000uV into 1150000-1150000uV
[ 0.564241] vdd-ddr-1v1: 1150 mV
[ 0.568239] vdd-pre-reg-1v35: 1350 mV
[ 0.572238] vdd-1v8: 1800 mV
[ 0.572524] vdd-1v8: Failed to create debugfs directory
[ 0.576235] avdd-sys-1v2: 1200 mV
[ 0.580234] vdd-pex-1v0: 1050 mV
[ 0.581023] vddio-sdmmc-ap: 1800 <–> 3300 mV at 3300 mV
[ 0.581662] max77620-ldo3: at 3100 mV
[ 0.584242] vdd-rtc: 850 <–> 1100 mV at 1000 mV
[ 0.584918] max77620-ldo5: at 3100 mV
[ 0.585579] max77620-ldo6: at 2800 mV
[ 0.588241] avdd-1v05-pll: 1050 mV
[ 0.592235] avdd-io-hdmi-dp: 1050 mV
[ 0.593559] GPIO line 505 (spmic-default-output-high) hogged as output/high
[ 0.593848] gpiochip_setup_dev: registered GPIOs 504 to 511 on device: gpiochip1 (max77620-gpio)
[ 0.595939] max77620 4-003c: max77620 probe successful
[ 0.598156] i2c i2c-6: Unbalanced pm_runtime_enable!
[ 0.598720] media: Linux media interface: v0.10
[ 0.598781] Linux video capture interface: v2.00
[ 0.599688] pps_core: LinuxPPS API ver. 1 registered
[ 0.599710] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 0.599752] PTP clock support registered
[ 0.603119] tegra_fiq_debugger_init: found FIQ source (IRQ 98)
[ 0.609333] tegra210-emc 7001b000.external-memory-controller: validated EMC DFS table
[ 0.610206] Advanced Linux Sound Architecture Driver Initialized.
[ 0.610851] Bluetooth: Core ver 2.22
[ 0.610917] NET: Registered protocol family 31
[ 0.610934] Bluetooth: HCI device and connection manager initialized
[ 0.610960] Bluetooth: HCI socket layer initialized
[ 0.610982] Bluetooth: L2CAP socket layer initialized
[ 0.611017] Bluetooth: SCO socket layer initialized
[ 0.612721] tegra210_dvfs: no clock found for sdmmc2_ddr
[ 0.612762] tegra210_dvfs: no clock found for sdmmc4_ddr
[ 0.612824] tegra210_dvfs: no clock found for sdmmc1_ddr
[ 0.612852] tegra210_dvfs: no clock found for sdmmc3_ddr
[ 0.615503] tegra_dvfs: Unable to get vdd-cpu rail for step info, defering probe
[ 0.617011] vdd-3v3-sys: supplied by vdd-5v0-sys
[ 0.617096] vdd-3v3-sys: 3300 mV
[ 0.617370] vdd-1v8: supplied by vdd-3v3-sys
[ 0.620303] vdd-usb-vbus2: supplied by vdd-3v3-sys
[ 0.620819] vdd-3v3-sd: supplied by vdd-3v3-sys
[ 0.620866] vdd-3v3-sd: 3300 mV
[ 0.621877] avdd-io-edp-1v05: supplied by avdd-1v05-pll
[ 0.621942] avdd-io-edp-1v05: 1050 mV
[ 0.622438] vdd-usb-hub-en: supplied by vdd-1v8
[ 0.622515] vdd-usb-hub-en: 5000 mV
[ 0.623810] camchar: rtcpu character device driver loaded
[ 0.624537] extcon-gpio-states extcon:extcon@1: Cable state:1, cable id:1
[ 0.626029] clocksource: Switched to clocksource arch_sys_counter
[ 0.665569] VFS: Disk quotas dquot_6.6.0
[ 0.665730] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.666272] nvmap_heap_init: nvmap_heap_init: created heap block cache
[ 0.666714] dma_declare_coherent_resizable_cma_memory:324: resizable heap=vpr, base=0x00000000d7000000, size=0x19000000
[ 0.666766] dma-vpr: heap size is not multiple of cma_chunk_size heap_info->num_chunks (13) rem_chunk_size(0x1000000)
[ 0.666982] cma: enabled page replacement for spfn=d7000, epfn=f0000
[ 0.667010] dma_declare_coherent_resizable_cma_memory:373: resizable cma heap=vpr create successful
[ 0.667041] tegra-carveouts tegra-carveouts: assigned reserved memory node vpr-carveout
[ 0.667098] tegra-carveouts tegra-carveouts: iram :dma coherent mem declare 0x0000000040001000,258048
[ 0.667124] tegra-carveouts tegra-carveouts: assigned reserved memory node iram-carveout
[ 0.667157] nvmap: nvmap_select_cache_ops() nvmap cache ops set to set/ways
[ 0.667180] nvmap_page_pool_init: Total RAM pages: 1012800
[ 0.667198] nvmap_page_pool_init: nvmap page pool size: 126600 pages (494 MB)
[ 0.667437] nvmap_background_zero_thread: PP zeroing thread starting.
[ 0.667703] misc nvmap: created heap iram base 0x0000000040001000 size (252KiB)
[ 0.668655] misc nvmap: created heap vpr base 0x00000000d7000000 size (409600KiB)
[ 0.676853] thermal thermal_zone0: Registering thermal zone thermal_zone0 for type AO-therm
[ 0.677263] thermal thermal_zone1: Registering thermal zone thermal_zone1 for type CPU-therm
[ 0.677525] thermal thermal_zone2: Registering thermal zone thermal_zone2 for type GPU-therm
[ 0.677762] thermal thermal_zone3: Registering thermal zone thermal_zone3 for type PLL-therm
[ 0.677960] thermal thermal_zone4: Registering thermal zone thermal_zone4 for type PMIC-Die
[ 0.678278] pre_t19x_iso_plat_init(): iso emc max clk=1600000KHz
[ 0.678303] pre_t19x_iso_plat_init(): max_iso_bw=33280000KB
[ 0.678740] NET: Registered protocol family 2
[ 0.679768] TCP established hash table entries: 32768 (order: 6, 262144 bytes)
[ 0.680003] TCP bind hash table entries: 32768 (order: 7, 524288 bytes)
[ 0.680509] TCP: Hash tables configured (established 32768 bind 32768)
[ 0.680676] UDP hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.680775] UDP-Lite hash table entries: 2048 (order: 4, 65536 bytes)
[ 0.681199] NET: Registered protocol family 1
[ 0.681947] RPC: Registered named UNIX socket transport module.
[ 0.681975] RPC: Registered udp transport module.
[ 0.681991] RPC: Registered tcp transport module.
[ 0.682007] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.682093] PCI: CLS 0 bytes, default 64
[ 0.682333] Trying to unpack rootfs image as initramfs…
[ 0.691674] host1x 50000000.host1x: initialized
[ 0.693505] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[ 0.696704] audit: initializing netlink subsys (disabled)
[ 0.696821] audit: type=2000 audit(0.547:1): initialized
[ 0.697589] workingset: timestamp_bits=46 max_order=20 bucket_order=0
[ 0.707969] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.709458] ntfs: driver 2.1.32 [Flags: R/W].
[ 0.710348] 9p: Installing v9fs 9p2000 file system support
[ 0.713606] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 240)
[ 0.713773] io scheduler noop registered
[ 0.714123] io scheduler cfq registered (default)
[ 0.716782] gic 702f9000.agic: GIC IRQ controller registered
[ 0.719645] iommu: Adding device 702ef000.adsp to group 33
[ 0.726697] iommu: Adding device aconnect@702c0000:adsp_audio to group 34
[ 0.726896] tegra-aconnect aconnect@702c0000: Tegra ACONNECT bus registered
[ 0.727561] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_SKU_CALIB_0 = 0x8227411
[ 0.727595] tegra-xusb-padctl 7009f000.xusb_padctl: TEGRA_FUSE_USB_CALIB_EXT_0 = 0x4
[ 0.729226] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.0, lane = usb2-0, function = xusb
[ 0.729362] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.1, lane = usb2-1, function = xusb
[ 0.729474] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-usb2.2, lane = usb2-2, function = xusb
[ 0.729687] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.3, lane = pcie-0, function = pcie-x1
[ 0.729799] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.4, lane = pcie-1, function = pcie-x4
[ 0.729904] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.5, lane = pcie-2, function = pcie-x4
[ 0.730063] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.6, lane = pcie-3, function = pcie-x4
[ 0.730181] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.7, lane = pcie-4, function = pcie-x4
[ 0.730294] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.8, lane = pcie-5, function = xusb
[ 0.730401] tegra-xusb-padctl 7009f000.xusb_padctl: dev = phy-pcie.9, lane = pcie-6, function = xusb
[ 0.736572] tegra-pwm 7000a000.pwm: PWM clk cannot sleep in ops
[ 0.737884] tegra-dfll-pwm 70110000.pwm: DFLL pwm-rate: 12800000
[ 0.739810] tegra-pcie 1003000.pcie-controller: 4x1, 1x1 configuration
[ 0.741120] tegra-pcie 1003000.pcie-controller: PCIE: Enable power rails
[ 0.741489] tegra-pcie 1003000.pcie-controller: probing port 0, using 4 lanes
[ 0.742784] tegra_camera_platform tegra-camera-platform: tegra_camera_probe:camera_platform_driver probe
[ 0.743022] misc tegra_camera_ctrl: tegra_camera_isomgr_register isp_iso_bw=1500000, vi_iso_bw=750000, max_bw=1500000
[ 0.743268] Adding domain tsec-pd to PM domain host1x-pd
[ 0.745173] tegra-pcie 1003000.pcie-controller: probing port 1, using 1 lanes
[ 0.746087] tsec 54500000.tsec: initialized
[ 0.747746] tsec 54100000.tsecb: initialized
[ 0.748465] Adding domain nvdec-pd to PM domain host1x-pd
[ 0.751643] nvdec 54480000.nvdec: initialized
[ 0.752738] Adding domain vic03-pd to PM domain host1x-pd
[ 0.752941] Adding domain msenc-pd to PM domain host1x-pd
[ 0.753120] Adding domain nvjpg-pd to PM domain host1x-pd
[ 0.756869] falcon 54340000.vic: initialized
[ 0.758209] falcon 544c0000.nvenc: initialized
[ 0.759583] falcon 54380000.nvjpg: initialized
[ 0.764178] tegradc tegradc.0: disp0 connected to head0->/host1x/sor1
[ 0.764304] display board info: id 0x0, fab 0x0
[ 0.764379] generic_infoframe_type: 0x87
[ 0.764522] tegradc tegradc.0: DT parsed successfully
[ 0.764581] tegradc tegradc.0: Display dc.ffffff800ab40000 registered with id=0
[ 0.767781] tegradc tegradc.0: probed
[ 0.772577] tegra-apbdma 60020000.dma: Tegra20 APB DMA driver register 32 channels
[ 0.777154] tegra-adma 702e2000.adma: Tegra210 ADMA driver registered 10 channels
[ 0.778091] tegra-fuse-burn 7000f800.efuse:efuse-burn: Fuse burn driver initialized
[ 0.778486] kfuse 7000fc00.kfuse: initialized
[ 0.779914] tegra-pmc-iopower pmc-iopower: Regulator supply iopower-dbg-supply not available
[ 0.780932] tegra-pmc-iopower pmc-iopower: NO_IOPOWER setting 0x0
[ 0.782330] tegra-dfll-pwm 70110000.pwm: DFLL_PWM regulator is available now
[ 0.782386] vdd-cpu: 708 <–> 1322 mV at 708 mV
[ 0.782930] pwm-regulator pwm_regulators:pwm-regulator@0: PWM regulator registration passed
[ 0.784644] vdd-gpu: applied init 1000000uV constraint
[ 0.784677] vdd-gpu: 708 <–> 1323 mV at 997 mV
[ 0.785109] pwm-regulator pwm_regulators:pwm-regulator@1: PWM regulator registration passed
[ 0.789714] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[ 0.789908] No Device Node present for smmu client: serial8250 !!
[ 0.789939] platform serial8250: No iommus property found in DT node, got swgids from fixup(101004000)
[ 0.790087] iommu: Adding device serial8250 to group 35
[ 0.793539] console [ttyS0] disabled
[ 0.793691] 70006000.serial: ttyS0 at MMIO 0x70006000 (irq = 63, base_baud = 25500000) is a Tegra
[ 1.254467] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 1.658867] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 2.063269] tegra-pcie 1003000.pcie-controller: link 0 down, retrying
[ 2.065287] tegra-pcie 1003000.pcie-controller: link 0 down, ignoring
[ 2.065686] tegra-pcie 1003000.pcie-controller: PCI host bridge to bus 0000:00
[ 2.065695] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 2.065699] pci_bus 0000:00: root bus resource [mem 0x13000000-0x1fffffff]
[ 2.065704] pci_bus 0000:00: root bus resource [mem 0x20000000-0x3fffffff pref]
[ 2.065711] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 2.065755] pci 0000:00:02.0: [10de:0faf] type 01 class 0x060400
[ 2.065879] pci 0000:00:02.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.066165] pci 0000:00:02.0: bridge configuration invalid ([bus 00-00]), reconfiguring
[ 2.066349] pci 0000:01:00.0: [10ec:8168] type 00 class 0x020000
[ 2.066384] pci 0000:01:00.0: reg 0x10: [io 0x0000-0x00ff]
[ 2.066427] pci 0000:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 2.066456] pci 0000:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 2.066652] pci 0000:01:00.0: supports D1 D2
[ 2.066655] pci 0000:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 2.078160] pci_bus 0000:01: busn_res: [bus 01-ff] end is updated to 01
[ 2.078211] pci 0000:00:02.0: BAR 14: assigned [mem 0x13000000-0x130fffff]
[ 2.078216] pci 0000:00:02.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 2.078226] pci 0000:01:00.0: BAR 4: assigned [mem 0x13000000-0x13003fff 64bit]
[ 2.078251] pci 0000:01:00.0: BAR 2: assigned [mem 0x13004000-0x13004fff 64bit]
[ 2.078275] pci 0000:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 2.078287] pci 0000:00:02.0: PCI bridge to [bus 01]
[ 2.078293] pci 0000:00:02.0: bridge window [io 0x1000-0x1fff]
[ 2.078300] pci 0000:00:02.0: bridge window [mem 0x13000000-0x130fffff]
[ 2.079054] pcieport 0000:00:02.0: Signaling PME through PCIe PME interrupt
[ 2.079060] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[ 2.079067] pcie_pme 0000:00:02.0:pcie001: service driver pcie_pme loaded
[ 2.079193] aer 0000:00:02.0:pcie002: service driver aer loaded
[ 3.141308] console [ttyS0] enabled
[ 3.141667] Console: switching to colour frame buffer device 80x30
[ 3.143294] 70006040.serial: ttyTHS1 at MMIO 0x70006040 (irq = 64, base_baud = 0) is a TEGRA_UART
[ 3.143620] serial-tegra 70006200.serial: RX in PIO mode
[ 3.143717] 70006200.serial: ttyTHS2 at MMIO 0x70006200 (irq = 65, base_baud = 0) is a TEGRA_UART
[ 3.144713] [drm] Initialized
[ 3.166334] brd: module loaded
[ 3.181899] tegradc tegradc.0: fb registered
[ 3.182104] loop: module loaded
[ 3.182203] tegra_profiler: version: 1.132, samples/io: 46/26
[ 3.186114] tegra_profiler: auth: init
[ 3.187558] THERMAL EST: found 2 subdevs
[ 3.187565] THERMAL EST num_resources: 0
[ 3.187571] [THERMAL EST subdev 0]
[ 3.187580] [THERMAL EST subdev 1]
[ 3.188030] thermal thermal_zone5: Registering thermal zone thermal_zone5 for type thermal-fan-est
[ 3.188032] THERMAL EST: thz register success.
[ 3.188269] THERMAL EST: end of probe, return err: 0
[ 3.189440] hisi_sas: driver version v1.6
[ 3.193713] tegra-qspi 70410000.spi: Prod settings list not found
[ 3.194961] qspi_mtd spi32766.0: MX25U3235F (4096 Kbytes)
[ 3.194968] qspi_mtd spi32766.0: mtd .name = spi32766.0, .size = 0x400000 (4MiB) .erasesize = 0x00001000 (4KiB) .numeraseregions = 0
[ 3.200601] libphy: Fixed MDIO Bus: probed
[ 3.201191] tun: Universal TUN/TAP device driver, 1.6
[ 3.201193] tun: (C) 1999-2004 Max Krasnyansky maxk@qualcomm.com
[ 3.202440] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
[ 3.202444] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 3.202510] igb: Intel(R) Gigabit Ethernet Network Driver - version 5.4.0-k
[ 3.202512] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 3.202561] igbvf: Intel(R) Gigabit Virtual Function Network Driver - version 2.4.0-k
[ 3.202564] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 3.202613] Intel(R) 10GbE PCI Express Linux Network Driver - version 4.6.4
[ 3.202615] Copyright(c) 1999 - 2017 Intel Corporation.
[ 3.203540] r8168 0000:01:00.0: enabling device (0000 → 0003)
[ 3.203569] r8168 Gigabit Ethernet driver 8.045.08-NAPI loaded
[ 3.218677] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 3.218715] r8168 Copyright (C) 2017 Realtek NIC software team nicfae@realtek.com
This program comes with ABSOLUTELY NO WARRANTY; for details, please see http://www.gnu.org/licenses/.
This is free software, and you are welcome to redistribute it under certain conditions; see http://www.gnu.org/licenses/.
[ 3.219337] PPP generic driver version 2.4.2
[ 3.219541] PPP BSD Compression module registered
[ 3.219546] PPP Deflate Compression module registered
[ 3.219585] PPP MPPE Compression module registered
[ 3.219592] NET: Registered protocol family 24
[ 3.219663] usbcore: registered new interface driver r8152
[ 3.219706] usbcore: registered new interface driver asix
[ 3.219763] usbcore: registered new interface driver ax88179_178a
[ 3.219805] usbcore: registered new interface driver cdc_ether
[ 3.219845] usbcore: registered new interface driver net1080
[ 3.219892] usbcore: registered new interface driver cdc_subset
[ 3.219931] usbcore: registered new interface driver zaurus
[ 3.219986] usbcore: registered new interface driver cdc_ncm
[ 3.220162] VFIO - User Level meta-driver version: 0.3
[ 3.221432] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 3.221454] ehci-pci: EHCI PCI platform driver
[ 3.221506] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 3.221518] ohci-pci: OHCI PCI platform driver
[ 3.221563] ohci-platform: OHCI generic platform driver
[ 3.224319] tegra-xusb 70090000.xusb: USB2 port 0 has OTG_CAP
[ 3.224927] tegra-xusb-padctl 7009f000.xusb_padctl: enabled OTG on UTMI pad 0
[ 3.226120] tegra-xusb 70090000.xusb: extcon 0: ffffffc0f9422400 id
[ 3.226229] tegra-xusb 70090000.xusb: Direct firmware load for tegra21x_xusb_firmware failed with error -2
[ 3.226232] tegra-xusb 70090000.xusb: Falling back to user helper
[ 3.227536] usbcore: registered new interface driver uas
[ 3.227594] usbcore: registered new interface driver usb-storage
[ 3.227699] usbcore: registered new interface driver usbserial
[ 3.230851] tegra-xudc-new 700d0000.xudc: device count: 1
[ 3.232157] tegra-xudc-new 700d0000.xudc: USB charger detection disabled
[ 3.232169] tegra-xudc-new 700d0000.xudc: vbus state: 1
[ 3.232185] tegra-xudc-new 700d0000.xudc: device mode on: 0
[ 3.232211] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 0
[ 3.232231] tegra-xudc-new 700d0000.xudc: active: 0 => 1
[ 3.232935] mousedev: PS/2 mouse device common for all mice
[ 3.233020] usbcore: registered new interface driver xpad
[ 3.359709] max77686-rtc max77620-rtc: rtc core: registered max77620-rtc as rtc0
[ 3.362203] rtc rtc1: alarm rtc device
[ 3.362224] tegra_rtc 7000e000.rtc: rtc core: registered 7000e000.rtc as rtc1
[ 3.362252] tegra_rtc 7000e000.rtc: Tegra internal Real Time Clock
[ 3.362882] i2c /dev entries driver
[ 3.364697] imx219 6-0010: tegracam sensor driver:imx219_v2.0.6
[ 3.388020] tegra-vii2c 546c0000.i2c: no acknowledge from address 0x10
[ 3.388086] imx219 6-0010: imx219_board_setup: error during i2c read probe (-121)
[ 3.388116] imx219 6-0010: board setup failed
[ 3.388218] imx219: probe of 6-0010 failed with error -121
[ 3.389281] max77620-power max77620-power: Event recorder REG_NVERC : 0x0
[ 3.392217] tegra_soctherm 700e2000.soctherm: pllx_offset tz:0 max:14, min:2
[ 3.392224] tegra_soctherm 700e2000.soctherm: pllx_offset tz:2 max:8, min:4
[ 3.392650] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.392666] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when cpu reaches 102500 mC
[ 3.392675] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when cpu reaches 100500 mC
[ 3.392830] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.392840] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when gpu reaches 103000 mC
[ 3.392846] tegra_soctherm 700e2000.soctherm: throttrip: will throttle when gpu reaches 101000 mC
[ 3.392988] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.392998] tegra_soctherm 700e2000.soctherm: thermtrip: will shut down when pll reaches 127000 mC
[ 3.393003] tegra_soctherm 700e2000.soctherm: throttrip: pll: missing hot temperature
[ 3.393180] tegra_soctherm 700e2000.soctherm: failed to register sensor: -19
[ 3.393942] tegra_aotag tegra-aotag: Registering sensor 0
[ 3.393993] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.394054] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.394071] tegra_aotag tegra-aotag: Bound to TZ : ID 0
[ 3.394080] tegra_aotag tegra-aotag: Probe done [SUCCESS]:0
[ 3.394992] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.395011] tegra_dfll_action dfll-cdev-cap: Tegra DFLL ‘cap cooling device’ registered
[ 3.395195] tegra_aotag tegra-aotag: Invalid temp readout
[ 3.395224] tegra_dfll_action dfll-cdev-floor: Tegra DFLL ‘floor cooling device’ registered
[ 3.395673] parse_throttle_dt_data: Num cap clks = 6
[ 3.395678] parse_throttle_dt_data: clk=cclk_g type=2
[ 3.395693] parse_throttle_dt_data: clk=gpu type=4
[ 3.395718] parse_throttle_dt_data: clk=cap.throttle.c2bus type=0
[ 3.395737] parse_throttle_dt_data: clk=cap.throttle.c3bus type=0
[ 3.395758] parse_throttle_dt_data: clk=cap.throttle.sclk type=0
[ 3.395761] parse_throttle_dt_data: clk=emc type=3
[ 3.396203] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.396297] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 3.396435] tegra_throttle_probe: probe successful. #cdevs=4
[ 3.397199] FAN dev name: pwm-fan
[ 3.397251] FAN:gpio request success.
[ 3.397325] pwm_fan_driver pwm-fan: cap state:7, cap pwm:255
[ 3.397636] pwm_fan_driver pwm-fan: got pwm for fan. polarity is normal
[ 3.397826] pwm_fan_driver pwm-fan: fan tach request irq success
[ 3.397836] pwm_fan_driver pwm-fan: tach period: 1000
[ 3.397917] pwm_fan_driver pwm-fan: index 0: pwm=0, rpm=0, rru=40, rrd=40, state:2
[ 3.397921] pwm_fan_driver pwm-fan: index 1: pwm=80, rpm=1000, rru=2, rrd=2, state:2
[ 3.397925] pwm_fan_driver pwm-fan: index 2: pwm=120, rpm=2000, rru=1, rrd=1, state:2
[ 3.397929] pwm_fan_driver pwm-fan: index 3: pwm=160, rpm=3000, rru=1, rrd=1, state:2
[ 3.397932] pwm_fan_driver pwm-fan: index 4: pwm=255, rpm=4000, rru=1, rrd=1, state:3
[ 3.397936] pwm_fan_driver pwm-fan: index 5: pwm=255, rpm=5000, rru=1, rrd=1, state:3
[ 3.397939] pwm_fan_driver pwm-fan: index 6: pwm=255, rpm=6000, rru=1, rrd=1, state:3
[ 3.397942] pwm_fan_driver pwm-fan: index 7: pwm=255, rpm=7000, rru=1, rrd=1, state:4
[ 3.397946] pwm_fan_driver pwm-fan: index 8: pwm=255, rpm=10000, rru=1, rrd=1, state:4
[ 3.397949] pwm_fan_driver pwm-fan: index 9: pwm=255, rpm=11000, rru=1, rrd=1, state:4
[ 3.398678] tegra-wdt 60005100.watchdog: Tegra WDT enabled on probe. Timeout = 120 seconds.
[ 3.399023] tegra-wdt 60005100.watchdog: initialized (timeout = 120 sec, nowayout = 1)
[ 3.399944] device-mapper: uevent: version 1.0.3
[ 3.400412] device-mapper: ioctl: 4.35.0-ioctl (2016-06-23) initialised: dm-devel@redhat.com
[ 3.405676] tegra210-cpufreq cpufreq: probe()…completed
[ 3.406419] sdhci: Secure Digital Host Controller Interface driver
[ 3.406420] sdhci: Copyright(c) Pierre Ossman
[ 3.406421] sdhci-pltfm: SDHCI platform and OF driver helper
[ 3.406908] sdhci-tegra sdhci-tegra.0: Got CD GPIO
[ 3.407272] sdhci-tegra sdhci-tegra.0: Client registration for eMC Successful
[ 3.407394] sdhci-tegra sdhci-tegra.0: wakeup init done, cdirq 300
[ 3.410768] tegra-se 70012000.se: tegra_se_probe: complete
[ 3.411292] hidraw: raw HID events driver (C) Jiri Kosina
[ 3.412567] usbcore: registered new interface driver usbhid
[ 3.412569] usbhid: USB HID core driver
[ 3.414720] tegra21x_actmon 6000c800.actmon: in actmon_register()…
[ 3.414892] tegra21x_actmon 6000c800.actmon: initialization Completed for the device mc_all
[ 3.416625] nvpmodel: initialized successfully
[ 3.417737] usbcore: registered new interface driver snd-usb-audio
[ 3.417804] No Device Node present for smmu client: snd-soc-dummy !!
[ 3.417809] platform snd-soc-dummy: No iommus property found in DT node, got swgids from fixup(101004000)
[ 3.417826] iommu: Adding device snd-soc-dummy to group 36
[ 3.426230] input: tegra-hda HDMI/DP,pcm=3 as /devices/70030000.hda/sound/card0/input0
[ 3.447257] OPE platform probe
[ 3.447339] OPE platform probe successful
[ 3.447719] OPE platform probe
[ 3.447800] OPE platform probe successful
[ 3.454213] mmc0: SDHCI controller on sdhci-tegra.0 [sdhci-tegra.0] using ADMA 64-bit with 64 bit addr
[ 3.473409] tegra-asoc: sound: ADMAIF1 <-> ADMAIF1 mapping ok
[ 3.473537] tegra-asoc: sound: ADMAIF2 <-> ADMAIF2 mapping ok
[ 3.473663] tegra-asoc: sound: ADMAIF3 <-> ADMAIF3 mapping ok
[ 3.473790] tegra-asoc: sound: ADMAIF4 <-> ADMAIF4 mapping ok
[ 3.473911] tegra-asoc: sound: ADMAIF5 <-> ADMAIF5 mapping ok
[ 3.474055] tegra-asoc: sound: ADMAIF6 <-> ADMAIF6 mapping ok
[ 3.474182] tegra-asoc: sound: ADMAIF7 <-> ADMAIF7 mapping ok
[ 3.474303] tegra-asoc: sound: ADMAIF8 <-> ADMAIF8 mapping ok
[ 3.474426] tegra-asoc: sound: ADMAIF9 <-> ADMAIF9 mapping ok
[ 3.474547] tegra-asoc: sound: ADMAIF10 <-> ADMAIF10 mapping ok
[ 3.487168] u32 classifier
[ 3.487170] Actions configured
[ 3.487238] Initializing XFRM netlink socket
[ 3.487972] NET: Registered protocol family 10
[ 3.488719] NET: Registered protocol family 17
[ 3.488728] NET: Registered protocol family 15
[ 3.488803] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 3.488847] Bluetooth: RFCOMM socket layer initialized
[ 3.488855] Bluetooth: RFCOMM ver 1.11
[ 3.488859] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 3.488863] Bluetooth: HIDP socket layer initialized
[ 3.488880] 9pnet: Installing 9P2000 support
[ 3.488916] Key type dns_resolver registered
[ 3.493114] Registered cp15_barrier emulation handler
[ 3.493123] Registered setend emulation handler
[ 3.494252] registered taskstats version 1
[ 3.494844] Adding domain ve2-pd to PM domain host1x-pd
[ 3.495087] Adding domain ve-pd to PM domain host1x-pd
[ 3.800905] mmc0: hw tuning done …
[ 3.800938] mmc0: new ultra high speed SDR50 SDHC card at address b368
[ 3.801285] mmcblk0: mmc0:b368 CBADS 30.0 GiB
[ 3.805951] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12
[ 4.306681] tegradc tegradc.1: disp1 connected to head1->/host1x/sor
[ 4.313082] tegradc tegradc.1: No lt-data, using default setting
[ 4.319100] tegradc tegradc.1: No hpd-gpio in DT
[ 4.323736] tegradc tegradc.1: DT parsed successfully
[ 4.328805] tegradc tegradc.1: Display dc.ffffff800f4c0000 registered with id=1
[ 4.336813] tegradc tegradc.1: dpd enable lookup fail:-19
[ 4.847837] Host read timeout at address 545c00c4
[ 4.848469] tegradc tegradc.1: probed
[ 4.862846] tegradc tegradc.1: fb registered
[ 4.870246] hpd: state 7 (Takeover from bootloader), hpd 0, pending_hpd_evt 1
[ 4.877401] hpd: switching from state 7 (Takeover from bootloader) to state 0 (Reset)
[ 4.885232] hpd: state 0 (Reset), hpd 0, pending_hpd_evt 0
[ 4.890722] tegradc tegradc.1: blank - powerdown
[ 4.891309] isp 54600000.isp: initialized
[ 4.892230] isp 54680000.isp: initialized
[ 4.903408] extcon-disp-state extcon:disp-state: cable 44 state 0 already set.
[ 4.903866] clk_cbus_recalc_rate: no gbus parent
[ 4.903870] clk_cbus_round_rate: no gbus parent
[ 4.903871] clk_cbus_round_rate: no gbus parent
[ 4.903878] clk_cbus_recalc_rate: no gbus parent
[ 4.903975] clk_cbus_recalc_rate: no gbus parent
[ 4.903978] clk_cbus_round_rate: no gbus parent
[ 4.903979] clk_cbus_round_rate: no gbus parent
[ 4.903982] clk_cbus_recalc_rate: no gbus parent
[ 4.903995] tegra_dvfs: GPU-cap: registered
[ 4.904056] tegra dvfs: vdd-cpu: nominal 1168mV, offset 708000uV, step 19200uV, scaling enabled
[ 4.904057] tegra dvfs: vdd-core: nominal 1075mV, offset 600000uV, step 12500uV, scaling enabled
[ 4.904059] tegra dvfs: vdd-gpu: nominal 1048mV, offset 708000uV, step 10000uV, scaling enabled
[ 4.960377] tegra_dvfs: vdd-gpu-vts: registered
[ 4.982236] Extcon DP: HPD disabled
[ 4.985727] hpd: hpd_switch 0
[ 4.988705] hpd: switching from state 0 (Reset) to state 1 (Check Plug)
[ 4.988765] tegra_core_action core_dvfs_cdev_floor: Tegra CORE DVFS ‘floor cooling device’ registered
[ 4.989385] tegra_core_action core_dvfs_cdev_cap: Tegra CORE DVFS ‘cap cooling device’ registered
[ 4.989927] input: gpio-keys as /devices/gpio-keys/input/input1
[ 5.019346] hpd: state 1 (Check Plug), hpd 0, pending_hpd_evt 0
[ 5.025266] hpd: switching from state 1 (Check Plug) to state 3 (Disabled)
[ 5.034906] tegra_rtc 7000e000.rtc: setting system clock to 2019-05-28 10:16:20 UTC (1559038580)
[ 5.044877] vi 54080000.vi: vi_probe: ++
[ 5.052845] vi 54080000.vi: initialized
[ 5.058997] vi 54080000.vi: subdev nvcsi–1 bound
[ 5.063927] mmcblk mmc0:b368: Card claimed for testing.
[ 5.070345] Disable partitions left on by BL
[ 5.074663] disb
[ 5.076721] bwmgr: missing cdev-type property
[ 5.081175] tegra_soctherm 700e2000.soctherm: soctherm: trip temperature -2147483647 forced to -127000
[ 5.090486] DRAM derating cdev registered.
[ 5.095594] vdd-1v8: disabling
[ 5.098658] vdd-fan: disabling
[ 5.101706] vdd-usb-vbus: disabling
[ 5.105196] vdd-usb-vbus2: disabling
[ 5.108781] avdd-io-edp-1v05: disabling
[ 5.112618] vdd-usb-hub-en: disabling
[ 5.116523] ALSA device list:
[ 5.119499] #0: tegra-hda at 0x70038000 irq 83
[ 5.124120] #1: tegra-snd-t210ref-mobile-rt565x
[ 5.183716] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null)
[ 5.191832] VFS: Mounted root (ext4 filesystem) on device 179:1.
[ 5.202672] devtmpfs: mounted
[ 5.208701] Freeing unused kernel memory: 8512K
[ 5.573386] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 5.589770] cgroup: cgroup2: unknown option “nsdelegate”
[ 5.611827] systemd[1]: systemd 237 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 5.633975] systemd[1]: Detected architecture arm64.
[ 5.664652] systemd[1]: Set hostname to .
[ 5.767073] systemd[1]: File /lib/systemd/system/systemd-journald.service:36 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 5.784285] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 5.930928] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.937596] systemd[1]: Reached target Swap.
[ 5.942445] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.950975] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 5.960497] random: systemd: uninitialized urandom read (16 bytes read)
[ 5.968828] systemd[1]: Created slice User and Session Slice.
[ 5.975577] systemd[1]: Created slice System Slice.
[ 5.980792] systemd[1]: Listening on Journal Socket (/dev/log).
[ 6.108949] EXT4-fs (mmcblk0p1): re-mounted. Opts: (null)
[ 6.233939] systemd-journald[1936]: Received request to flush runtime journal from PID 1
[ 6.276959] nvgpu: 57000000.gpu gm20b_init_clk_setup_sw:1268 [INFO] GPCPLL initial settings: NA mode, M=1, N=34, P=3 (id = 1)
[ 7.378101] random: crng init done
[ 7.381509] random: 7 urandom warning(s) missed due to ratelimiting
[ 7.404884] tegra-xusb 70090000.xusb: cannot find firmware…retry after 1 second
[ 7.517749] using random self ethernet address
[ 7.524311] using random host ethernet address
[ 7.723682] nvs_dsm nvs_dsm: dsm_probe
[ 7.723706] nvs_dsm nvs_dsm: dsm_remove
[ 7.723709] nvs_dsm nvs_dsm: dsm_probe done
[ 7.947289] Mass Storage Function, version: 2009/09/11
[ 7.947295] LUN: removable file: (no medium)
[ 7.961907] using random self ethernet address
[ 7.970674] using random host ethernet address
[ 7.986564] rndis0: HOST MAC fe:a3:53:bd:e7:3c
[ 7.986626] rndis0: MAC fe:a3:53:bd:e7:3d
[ 7.991478] usb0: HOST MAC fe:a3:53:bd:e7:3e
[ 7.991508] usb0: MAC fe:a3:53:bd:e7:3f
[ 7.991538] tegra-xudc-new 700d0000.xudc: ep 0 (type: 0, dir: out) enabled
[ 8.470046] tegra-xusb 70090000.xusb: Firmware timestamp: 2017-11-03 13:36:19 UTC, Version: 50.20 release
[ 8.470086] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 8.470105] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 1
[ 8.470944] tegra-xusb 70090000.xusb: hcc params 0x0184f525 hci version 0x100 quirks 0x00050010
[ 8.470974] tegra-xusb 70090000.xusb: irq 61, io mem 0x70090000
[ 8.471096] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 8.471100] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.471104] usb usb1: Product: xHCI Host Controller
[ 8.471107] usb usb1: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 8.471110] usb usb1: SerialNumber: 70090000.xusb
[ 8.471856] hub 1-0:1.0: USB hub found
[ 8.471891] hub 1-0:1.0: 5 ports detected
[ 8.472286] tegra-xusb 70090000.xusb: xHCI Host Controller
[ 8.472297] tegra-xusb 70090000.xusb: new USB bus registered, assigned bus number 2
[ 8.472368] usb usb2: We don’t know the algorithms for LPM for this host, disabling LPM.
[ 8.472435] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003
[ 8.472438] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.472441] usb usb2: Product: xHCI Host Controller
[ 8.472444] usb usb2: Manufacturer: Linux 4.9.140-tegra xhci-hcd
[ 8.472446] usb usb2: SerialNumber: 70090000.xusb
[ 8.472802] hub 2-0:1.0: USB hub found
[ 8.472861] hub 2-0:1.0: 4 ports detected
[ 8.574142] tegra-xusb-padctl 7009f000.xusb_padctl: power on UTMI pads 1
[ 8.574444] usb usb2: usb_suspend_both: status 0
[ 8.798077] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 8.834986] usb 1-2: New USB device found, idVendor=0bda, idProduct=5411
[ 8.834993] usb 1-2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.834996] usb 1-2: Product: 4-Port USB 2.1 Hub
[ 8.835000] usb 1-2: Manufacturer: Generic
[ 8.836463] hub 1-2:1.0: USB hub found
[ 8.837678] hub 1-2:1.0: 4 ports detected
[ 8.943224] usb 2-1: new SuperSpeed USB device number 2 using tegra-xusb
[ 8.977836] usb 2-1: New USB device found, idVendor=0bda, idProduct=0411
[ 8.977843] usb 2-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 8.977846] usb 2-1: Product: 4-Port USB 3.1 Hub
[ 8.977849] usb 2-1: Manufacturer: Generic
[ 8.983720] hub 2-1:1.0: USB hub found
[ 8.985293] hub 2-1:1.0: 4 ports detected
[ 9.009897] l4tbr0: port 1(rndis0) entered blocking state
[ 9.009901] l4tbr0: port 1(rndis0) entered disabled state
[ 9.011282] device rndis0 entered promiscuous mode
[ 9.019517] IPv6: ADDRCONF(NETDEV_UP): rndis0: link is not ready
[ 9.025466] l4tbr0: port 2(usb0) entered blocking state
[ 9.025470] l4tbr0: port 2(usb0) entered disabled state
[ 9.025647] device usb0 entered promiscuous mode
[ 9.033897] IPv6: ADDRCONF(NETDEV_UP): usb0: link is not ready
[ 9.126082] usb 1-2.1: new high-speed USB device number 3 using tegra-xusb
[ 9.146079] usb 2-1: usb_suspend_both: status 0
[ 9.146259] usb usb2: usb_suspend_both: status 0
[ 9.364556] usb 1-2.1: New USB device found, idVendor=046d, idProduct=081b
[ 9.364563] usb 1-2.1: New USB device strings: Mfr=0, Product=0, SerialNumber=2
[ 9.364567] usb 1-2.1: SerialNumber: 07D5D8A0
[ 9.749510] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 9.750920] eth0: 0xffffff800a2fe000, 00:e0:4c:68:00:48, IRQ 404
[ 9.806107] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.706855] usb 1-2.1: set resolution quirk: cval->res = 384
[ 10.786127] usb 1-2.3: new full-speed USB device number 4 using tegra-xusb
[ 10.809043] usb 1-2.3: New USB device found, idVendor=1ea7, idProduct=0064
[ 10.809054] usb 1-2.3: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 10.809060] usb 1-2.3: Product: 2.4G Mouse
[ 10.812927] input: 2.4G Mouse as /devices/70090000.xusb/usb1/1-2/1-2.3/1-2.3:1.0/0003:1EA7:0064.0001/input/input2
[ 10.813209] hid-generic 0003:1EA7:0064.0001: input,hidraw0: USB HID v1.10 Mouse [2.4G Mouse] on usb-70090000.xusb-2.3/input0
[ 10.894101] usb 1-2.4: new low-speed USB device number 5 using tegra-xusb
[ 10.921651] usb 1-2.4: New USB device found, idVendor=413c, idProduct=2003
[ 10.921672] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 10.921686] usb 1-2.4: Product: Dell USB Keyboard
[ 10.921698] usb 1-2.4: Manufacturer: Dell
[ 10.927752] input: Dell Dell USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/0003:413C:2003.0002/input/input3
[ 10.986635] hid-generic 0003:413C:2003.0002: input,hidraw1: USB HID v1.10 Keyboard [Dell Dell USB Keyboard] on usb-70090000.xusb-2.4/input0
[ 11.068551] uvcvideo: Found UVC 1.00 device (046d:081b)
[ 11.084721] uvcvideo 1-2.1:1.0: Entity type for entity Extension 4 was not initialized!
[ 11.093694] uvcvideo 1-2.1:1.0: Entity type for entity Extension 6 was not initialized!
[ 11.101906] uvcvideo 1-2.1:1.0: Entity type for entity Extension 7 was not initialized!
[ 11.110121] uvcvideo 1-2.1:1.0: Entity type for entity Processing 2 was not initialized!
[ 11.118898] uvcvideo 1-2.1:1.0: Entity type for entity Extension 3 was not initialized!
[ 11.126978] uvcvideo 1-2.1:1.0: Entity type for entity Camera 1 was not initialized!
[ 11.135092] input: UVC Camera (046d:081b) as /devices/70090000.xusb/usb1/1-2/1-2.1/1-2.1:1.0/input/input4
[ 11.136280] usbcore: registered new interface driver uvcvideo
[ 11.136284] USB Video Class driver (1.1.1)
[ 11.869572] r8168: eth0: link up
[ 11.869878] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 12.843711] tegradc tegradc.0: blank - powerdown
[ 12.843720] tegradc tegradc.1: blank - powerdown
[ 13.166406] usb 1-2.1: usb_suspend_both: status 0
[ 16.243284] usb 1-2.1: reset high-speed USB device number 3 using tegra-xusb
[ 25.990755] usb 1-2.1: usb_suspend_both: status 0
[ 161.317571] usb 1-2.1: USB disconnect, device number 3
[ 161.572617] usb 1-2.4: USB disconnect, device number 5
[ 161.883435] usb 1-2.4: new low-speed USB device number 6 using tegra-xusb
[ 161.913592] usb 1-2.4: New USB device found, idVendor=413c, idProduct=2003
[ 161.913644] usb 1-2.4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 161.913683] usb 1-2.4: Product: Dell USB Keyboard
[ 161.913718] usb 1-2.4: Manufacturer: Dell
[ 161.925128] input: Dell Dell USB Keyboard as /devices/70090000.xusb/usb1/1-2/1-2.4/1-2.4:1.0/0003:413C:2003.0003/input/input5
[ 161.983650] hid-generic 0003:413C:2003.0003: input,hidraw1: USB HID v1.10 Keyboard [Dell Dell USB Keyboard] on usb-70090000.xusb-2.4/input0
[ 177.035277] edid invalid
