DOCA Version 2.8
After I encountered this error, I first checked the firmware version using
$ sudo bfvcheck
command. It showed that the firmware version do not match with the required firmware version.
So, I updated the firmware and this result showed that all errors are gone with firmware update.
But, when I ran this command,
$ dmesg | grep -i mlx5
It showed the same firmware pre initialization error.
Due to this error, the ports P0 and P1 are not detected in $ ip link show
Anyone who has encountered the same problem or knows what might be the potential reasons for this error, I request you to share the solution/comments with me.
