ok, i’m trying to connect a ps3 controller via bluetooth to a jetson nano with an intel wifi/bt AC8265 m2 card. With my laptop it’s as simple as connect the controller via usb, open the bt interface, allow the connection and disconnect the usb, but if i rey ths on the nano i can’t connect after disconnecting the usb cable, it keeps trying to connect and disconnect. If i go to bluetoothctl i can see it trying to connect and disconnecting immediately… Is there something missing from the kernel which inhibits the connection?
thanks for the help
