Hello, I use Jetson xavier nx module in l4t R32.5.1 and want to adapt Bluetooth 5.1 function to transfer files. The models are Intel 9260NGW and Intel AX200NGW respectively. Can I use the above two models of BT5.1 devices in R32.5.1?
We don’t have device to confrim, but by searching in forum, both modules should work.
Thank you for your reply.
At present, I have updated the firmware through the following methods, but the Bluetooth still does not work. Do you have any good ideas?
https://www.intel.cn/content/www/cn/zh/support/articles/000005511/wireless.html
@carolyuu do we have the BT enable process to share? Thanks
As a reference platform, you may connect this card to Key-E slot on developer kit and give it a try:
https://www.amazon.com/Intel-Dual-Band-Wireless-Ac-8265/dp/B01MZA1AB2
