I am trying to train bodyposeNet using the jupyter notebook.
I amusing the following commands: docker run --runtime=nvidia -it -v /home/dipesh/tlt_cv_samples:/workspace/tlt_cv_samples -v /var/run/docker.sock:/var/run/docker.sock -p 8889:8888 nvcr.io/nvidia/tlt-streamanalytics:v3.0-py3 I am stuck at the following step: Generate segmentation masks and tfrecords from annotations
I am getting the following error:
FileNotFoundError: [Errno 2] No such file or directory: ‘/workspace/tlt_cv_samples/bpnet/data_pose_config/coco_spec.json’
but when I try to iterate from inside the docker this file is present at workspace/tlt-cv_samples/bpnet/data_pose_config.
I ran the following command on terminal:
tlt bpnet run ls /workspace/tlt_cv_samples/bpnet/data_pose_config/coco_spec.json
and getting the following error
This is no such folder with the name: “tlt_cv_samples_vv1.1.0”
I had renamed it to tlt_cv_samples.
inside tlt_cv_samples bpnet and its spec files are present.
File “/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/bpnet/scripts/dataset_convert.py”, line 119, in
File “/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/bpnet/scripts/dataset_convert.py”, line 101, in main
FileNotFoundError: [Errno 2] No such file or directory: ‘/coco_spec.json’
File “/usr/local/bin/bpnet”, line 8, in
sys.exit(main())
File “/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/bpnet/entrypoint/bpnet.py”, line 12, in main
File “/opt/tlt/.cache/dazel/_dazel_tlt/2b81a5aac84a1d3b7a324f2a7a6f400b/execroot/ai_infra/bazel-out/k8-fastbuild/bin/magnet/packages/driveix/build_wheel.runfiles/ai_infra/driveix/common/entrypoint/entrypoint.py”, line 300, in launch_job
AssertionError: Process run failed.
2021-07-28 21:01:02,029 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
Following the upper advice, I run the below command:
2021-07-28 21:29:30,398 [INFO] root: Registry: [‘nvcr.io’]
2021-07-28 21:29:30,450 [WARNING] tlt.components.docker_handler.docker_handler:
Docker will run the commands as root. If you would like to retain your
local host permissions, please add the “user”:“UID:GID” in the
DockerOptions portion of the ~/.tlt_mounts.json file. You can obtain your
users UID and GID by using the “id -u” and “id -g” commands on the
terminal.
ls: cannot access ‘/workspace/tlt_cv_samples/bpnet/data_pose_config/coco_spec.json’: No such file or directory
2021-07-28 21:29:31,198 [INFO] tlt.components.docker_handler.docker_handler: Stopping container.
In fact the file coco_spec.json is there. I run this command:
