Booting issue
debug_boot_msgs_paas1.txt (71.9 KB)
the problem is that the SOM module is getting booted on development kit but not on custom board.
Can you once check this log and say is there any issue in the code so that we can try to narrow down where is issue is whether in software or hardware.
Have you checked the Jetson AGX Orin Platform Adaptation and Bring-Up — NVIDIA Jetson Linux Developer Guide to do the custom board bring up?
yes i have checked…
not sure what is your issue here because your log just shows it is booting into system…
This log is from our Dev-kit, when we we are trying to do on our custom board, then there boot is not happening and even the debug messages also not getting. Previously boot happened successfully but suddenly it stops. So, is there any way to debug.
Only share useful information. I don’t see any point to share a log from devkit…
If you are talking about UART gives you nothing when you power on the custom board, go back to check your hardware power sequence. That is definitely not a software side issue.
Also make sure your UART is really fine on custom board.
