Jetson agx orin customised carrier board is hanging while in boot process
i have jetson agx orin module with customised carrier board .After i flashed it with some usb 3.0 port driver code it started hanging when it is in boot process .initially it has shown nvidia logo and then going blank later its not even showing nvidia logo.when i see in minicom its showing log messages but going to sleep or getting power off in between.what should i do ??since its not showing hdmi i cant able to entre into recovery mode
If the device cannot be flashed/booted, please refer to the page to get uart log from the device:
Jetson/General debug - eLinux.org
And get logs of host PC and Jetson device for reference. If you are using custom board, you can compare uart log of developer kit and custom board to get more information.
Also please check FAQs:
Jetson AGX Orin FAQ
If possible, we would suggest follow quick start in developer guide to re-flash the system:
Quick Start — NVIDIA Jetson Linux Developer Guide 1 documentation
And see if the issue still persists on a clean-flashed system.
duplicated with Kernal_customization - #13 by nikhilkumar.
You should post out the log but not telling story by yourself.
