I import an asset, create a semantic label, and then try to visualize the output. The bounding boxes are disjointed and don’t align with the object. I imagine it has something to do with the view or position, but not sure how to troubleshoot or fix this.
Hello @MontyPy! I need a bit more information from you so that I can direct your post to the right person. What application are you using when you import the asset?
Also, if you could take a look at this post: How to Report an issue with Ominverse and give me as much information as you can, it will help us out immensely!
