How to Report an issue with Omniverse
Getting Help for Technical Issues
Please note: if you are an Enterprise Customer, please contact your Omniverse representative for further assistance.
How to report an issue on the Fourms
The best place for getting help with any technical issues is through our Omniverse development forums (you are here!)
If you are experiencing an issue, please let us know so that we can improve your experience.
  1. Locate the post category that is related to the issue you are experiencing.
  2. Create a new forum post topic by clicking the + NEW TOPIC button.
  3. Summarize your issue for the Post Title using a brief sentence.
  4. Detail your experience in the Post Description. Please include the following information:
Information to Include
The more information you give us about your issue, the faster we will be able to help.
Please include the following:
Computer / System Environment
  • Operating System
  • GPU / GPU Driver
  • Application(s) Used / Version Number
  • Full log file (if applicable)
Log Directories
You can found the location of your Logs Directory via the Omniverse Launcher > User Icon > Settings > Logs Location
Log Directory
Omniverse Logs: %userprofile%\.nvidia-omniverse\logs\Kit
Omnivere Launcher Logs: C:\Users\<USERNAME>\.nvidia-omniverse\logs\launcher
Omniverse App Logs: C:\Users\<USERNAME>\.nvidia-omniverse\logs\Kit\<APPNAME>
Omniverse Drive logs: C:\Users\<USERNANE>\AppData\Local\NVIDIA Corporation\Omniverse\logs\Drive
Nucleus Logs %HOMEPATH%\.nvidia-omniverse\logs
Connector Logs: C:\Users\<USERNAME>\Documents\Omniverse\<CONNECTORNAME>
  • Cache Output Logs: C:\Users\<USERNAME>\AppData\Local\ov\pkg\<CACHE_VERSION>
    • Find and run the omni-cache-service.exe inside your cache folder
    • Run the capture Cache Output (or take a screenshot)
  • Console Logs: The location where logs are stored on your machine can be accessed by clicking on the folder icon in the Console tab:
  • For crashes, please zip and attach your full logs found here: C:\Users\ [YOUR NAME] \ .nvidia-omniverse\logs
Helpful Troubleshooting Tools
  • Omniverse System Monitor
    • On Windows, type Omniverse System Monitor into the search bar and hit Enter
    • Also found at :
      C:\Users\<USERNAME>\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\NVIDIA Corporation
  • Omniverse Cleanup-Tool
Troubleshooting Documentation
Developer Documentation
Helpful Links
Download NVIDIA Omniverse
Social Media Links:
Twitter | Twitch | YouTube
Does asset converter take nucleus file paths
Clear stage selection from extension
Love Create but so far it's very unstable
Running Marbles RTX on a 4090?
HydraRenderer failed to render frame after -> crash
Create and Nucleus crash for several reasons
Import "omni" coudnt be resolved
GANverse3D download Fail
Code crashes after a few frames when running Replicator
Broken extensions no longer even start up after updating Code
Nvidia assets, samples, environments etc. are not loading
Export doesn’t echo in the Commands window
Omniverse apps crashing when invoking HTTP requests in behavior scripts
Can't run default randomizing appearance example
App (Create, Code) could not launch on AWS Windows machine
Inconsistent (?) scene's state after adding/removing prims in layers
Where do we file bug reports?
Problem with installing 'Cache' and 'Nucleus'
Able to install and run Create and Code, but after installing Kit, on first run I get error saying Windows 9200 not supported. I'm on Windows 11
Extension randomly unlinks in Code
Python: error when loading >10,000 instances in Code
Failed to create Hydra Engine - Omniverse Code
Omniverse Code crashes after lauch
Code crashes after running Replicator
Strange problem when rendering with iray (black floor)
Omniverse Code hangs during install with no way out
Minimal installation guide for Code/Replicator?
Issues running Omniverse Create - crashing after less than 1 minute
Can't import .lxo or .fbx files
SKP Layer Connector bug
Bounding Boxes Not Properly Aligned
Changing the Python Version - Kit
