BPMP Firmware Mismatch When Using --no-flash with flash.sh
We are working with a custom build for the Jetson AGX Orin Industrial module.
When we flash the board directly using the flash.sh command, the system boots successfully without any issues.
However, when we first generate the flash artifacts using the –no-flash option and later execute the generated **flashcmd.txt (**using sudo bash flashcmd.txt), the board fails to boot.
Upon investigation, we observed the following difference:
  • Direct flash (flash.sh) uses:
    bpmp_t234-TE992M-A1_prod_aligned.bin
  • Generated flash command (--no-flash) uses:
    bpmp_t234-TE990M-A1_prod_aligned.bin
This BPMP firmware mismatch appears to be the cause of the boot failure.
During further debugging, we identified that the CHIP_SKU value influences the selected BPMP firmware. It seems that the SKU detected or configured during the --no-flash flow differs from the one used during direct flashing.
Could you please clarify what is the correct CHIP_SKU value for the Jetson AGX Orin Industrial module.
Here is our .conf file
source “${LDK_DIR}/p3701.conf.common”;
BOARDID=3701
BOARDSKU=0008
RAMCODE=4
echo "Sourced custom conf"
DTB_FILE="agx-orin-custom.dtb"
TBCDTB_FILE="$DTB_FILE"
BPFDTB_FILE="tegra234-bpmp-3701-0008-3737-0000.dtb";
BADPAGEFILE="bootloader/badpage.bin";
FSIFWFILE="bootloader/fsi-lk.bin";
PINMUX_CONFIG="Orin-custom-pinmux.dtsi"
PMC_CONFIG="Orin-custom-padvoltage-default.dtsi"
PMIC_CONFIG="tegra234-mb1-bct-pmic-p3701-0008.dts";
EMMC_CFG="flash_t234_qspi_sdmmc_industrial.xml";
MISC_CONFIG="tegra234-mb1-bct-misc-p3701-0008-flash.dts";
MISC_COLD_BOOT_CONFIG="tegra234-mb1-bct-misc-p3701-0008.dts";
MB2_BCT="tegra234-custom-mb2-bct-misc.dts";
OVERLAY_DTB_FILE="L4TConfiguration.dtbo,tegra234-custom-p3737-0000+p3701-0000-dynamic.dtbo,tegra234-carveouts.dtbo,tegra-optee.dtbo";
ODMDATA="gbe-uphy-config-0,hsstp-lane-map-3,nvhs-uphy-config-0,hsio-uphy-config-0";
Jetpack Version = 6.1
BSP Version = R36.4
Thank you.
Please try this:
Chip SKU configuration when generating multispec BUP / UEFI capsule - #5 by KevinFFF
For Orin Industrial, please check process_chip_sku_version() in p3701.conf.common
Thank you,
I got the issue fixed by setting the CHIP_SKU as 00 and inserting the following line in my .conf
CHIP_SKU=00
# update_flash_args_common:
update_flash_args_common()
    # Special handling of INT-fused "p3701-0008"
    if [ "${chip_SKU}" = "00" ]; then
        BPFFILE=`echo "${BPFFILE}" | sed "s|T.*-A1|TE992M-A1|"`;
    fi;
# update_flash_args:
update_flash_args()
