Orin AGX mass flash fail on 500 G.0
Hi nvidia,
We would like to generate mfi image to for production use.
For this purpose , we create mfi image by command
$ sudo BOARDID=3701 BOARDSKU=0004 BOARDREV=G.0 ./tools/kernel_flash/l4t_initrd_flash.sh --no-flash --massflash 5 --network usb0 jetson-agx-orin-dlap411 mmcblk0p1
Carrier Board : customize carrier
BSP version : 35.2.1
Orin Module (A) : 699-13701-0004-500 G.0
Orin Module (B) : 699-13701-0004-500 F.0
Try to flash image with mfi package
1.navigate to mfi package path
2.$ sudo tools/kernel_flash/l4t_initrd_flash.sh --flash-only
Result <<
Orin Module (A) : 699-13701-0004-500 G.0 → Fail on timeout
Orin Module (B) : 699-13701-0004-500 F.0 → Successful (flash finish and boot-up successfully)
mfi-flash-G.0-log.txt (24.4 KB)
mfi-flash-F.0-log.txt (24.2 KB)
These two module both can flash with command list below and flash successful:
$ sudo ./flash.sh jetson-agx-orin-dlap411 mmcblk0p1
Need nvidia team help to check where is going wrong in mass flash package?
PS : we do modify ODMDATA to “gbe-uphy-config-0,hsstp-lane-map-3,hsio-uphy-config-16,nvhs-uphy-config-0”;
Regards
It sounds a known issue in jp5.1 which will not include the bpmp-dtb change (aka your odmata change).
Please try to use jp5.1.1 and it should be fixed.
