Dear NVIDIA team,
In version Isaac-sim 4.2.0 Copy to clipboard not working when trying to copy prim path from property dialog.
Windows 10
Isaac-sim 4.2.0
Dear NVIDIA team,
Windows 10
Isaac-sim 4.2.0
Thank you for reporting this issue. I have been able to reproduce the problem with the “Copy Prim Path to Clipboard” button not functioning as expected in Isaac Sim 4.2.0.
I appreciate your patience while we work on resolving this bug. Our development team has been notified, and they will investigate the issue further.
In the meantime, please use the following workaround to copy prim paths:
This method should allow you to copy the prim path to your clipboard successfully.
This issue has been fixed, and the next version won’t have the problem. Thank you.
