I have this code to get the selected prop(s).
def decorate_on_click():
ctx = omni.usd.get_context()
# returns a list of prim path strings
selection = ctx.get_selection().get_selected_prim_paths()
if selection is not None:
Not sure what to do with selection.
Hi @DataJuggler . We have the CopyPrims command for that. You can review the command in the Commands window after using Edit->Duplicate.
import omni.kit.commands
omni.kit.commands.execute('CopyPrims',
paths_from=['/World/Cube'],
duplicate_layers=False,
combine_layers=False,
flatten_references=False)
Thank you. When I get off work, I will try this.
system
Closed
November 28, 2022, 6:44pm
4
