Hello, I’m trying to rename a list of prims in a usd scene with Python script, but having trouble finding the correct method to use. Any help would be appreciated, thank you!
omni.kit.commands “MovePrim” from this post can do it if I just specify the same path before and after, but I’m wondering if there is a more straightforward method like “Rename” or “Refactor”.
I don’t quit understand what you mean about “can do it if I just specify the same path before and after”. Do you mean you can only specify path_to as the sibling node as the one you want to move? MovePrim command could support to move prim to other parent also. One thing to mention is that you need to make sure the parent of the target path is existed before move, otherwise, it will be created as al overso render will not populate it for rendering, like:
